Hello forum friends,
I have 4 buttons connected to PORTB and 4 LEDs to PORTB, I turn on and off with the same button for the LED but independently, with this code does not work properly any suggestions?.
Code:start: IF PORTB.0=0 then HIGH PORTB.4 WHILE PORTB.0=0 : Wend : pause 50 ENDIF IF PORTB.0=0 then LOW PORTB.4 WHILE PORTB.0=0 : Wend : pause 50 ENDIF iF PORTB.1=0 then HIGH PORTB.5 WHILE PORTB.0=0 : Wend : pause 50 ENDIF IF PORTB.1=0 then LOW PORTB.5 WHILE PORTB.0=0 : Wend : pause 50 ENDIF iF PORTB.2=0 then HIGH PORTB.6 WHILE PORTB.0=0 : Wend : pause 50 ENDIF IF PORTB.2=0 then LOW PORTB.6 WHILE PORTB.0=0 : Wend : pause 50 ENDIF iF PORTB.3=0 then HIGH PORTB.7 WHILE PORTB.0=0 : Wend : pause 50 ENDIF IF PORTB.3=0 then LOW PORTB.7 WHILE PORTB.0=0 : Wend : pause 50 ENDIF goto start
