CCP1CON and CCP2CON strange behaviour - need some advice
Results 1 to 14 of 14
    Oct 2009
    Default Re: CCP1CON and CCP2CON strange behaviour - need some advice
    It's just a passive board, with a single female header on one side and two mail headers on top
    I think I've discovered what was happening. Looking at the schematic for the RTC2 add-on board there is an SQW pin which outputs a square wave that can be used as an interrupt... when this is plugged into the header on the EasyPIC5 board this SQW pin on the header connects to PORTC.2, hence the regular pulsing.
    I didn't twig that this issue only rose it's head when I chose to use external LEDs to see what was happening as the status display LEDs for C1 and C2 on the EasyPIC5 board are covered by the 4 x 20 LCD. So much wasted time, and my apologies for wasting your time trying to troubleshoot a non-code related issue
    Jan 2006
    Istanbul
    Quote Originally Posted by Scampy View Post
    .....So much wasted time, and my apologies for wasting your time trying to troubleshoot a non-code related issue
    Nevertheless, problem solved, right? What does it matter anyway.
  1. Strange IT behaviour
    By MikeBZH in forum mel PIC BASIC Pro
    Last Post: - 10th February 2012, 09:00
  2. Strange behaviour
    Last Post: - 8th October 2009, 22:35
  3. Strange Serout Behaviour
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 04:12
  4. Strange ADC behaviour
    Last Post: - 12th December 2007, 20:03
  5. strange int behaviour
    By tom in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 15:41
