Example code for capture series of pulses, using internal timers?
Results 1 to 2 of 2
    Default Example code for capture series of pulses, using internal timers?
    Hello.
    Does anyone has some code?
    Just want to have look, how it should be done properly.
    Default Re: Example code for capture series of pulses, using internal timers?
    Most hardware timers can be setup as counters with external clock input.
    Here's a snippet using TMR1 on a 16F88. (Not verified to work but should do so....)
    TRISB.6 = 1         ' T1CKI is on RB6, make sure it's an input
    T1CON = %00000111   ' Enable TMR1 as a counter, 1:1 prescale, no sync.
      LCDOUT $FE, 1, "Pulsecount: ", DEC TMR1H*256 + TMR1L
      Pause 250
    Goto Main
  1. Moving on to 18F series.
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 4th September 2012, 05:50
  2. Synchronous pulses
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 18th October 2009, 16:32
  3. Counting Pulses
    Last Post: - 5th September 2008, 17:35
  4. Code Problem - Strings/ LCD/ internal EEPROM
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 4th February 2008, 20:24
  5. Counting pulses
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 19th November 2003, 00:54
