Two statements from assembly - trying to convert the code in PBasic Pro
Results 1 to 14 of 14
    Default Re: Two statements from assembly - trying to convert the code in PBasic Pro
    I really suck at assembly programming but I'm going to say (write) what I think, then hopefully someone will correct me if I'm wrong.
    The constant in this case is called INTHAND which is defined to contain the adress, in program memory, where the routine _ISR is located. What happens is that PCLATH (the high byte of the program counter) gets loaded with the 8 high bits of the adress of _ISR. I suspect there's also code to take the low 8 bits and put them in PCLATU. All in all, that would cause the program to jump to _ISR.
    After reading SteveB's other posts that's my understanding of it but again I might very well be wrong.
    May 2006
    Del Rio, TX, USA
    Very good deduction Henrik!
    Nov 2009
    London
    Ok it has started making sense now. But 1 weird thought is there still, this line itself is part of the ISR routine, then what do you mean by
    All in all, that would cause the program to jump to_ISR.
    May 2006
    Del Rio, TX, USA
    In PBP, the label "ISR" will be annotated in assembly as "_ISR" as a literal (i.e. constant). It represents the address of the first instruction following the label in PBP. The address is a 21 bit address. The bottom 8 bits (low byte, bits 0-7) are directly readable/writeable. The high byte (bits 8-15) and upper byte (bits 16-20) can only be read/written through the registers PCLATH and PCLATU respectively
    So... You will likely see something like this as well:
    movlw ((INTHAND) >> 16)
    movwf PCLATU
    movlw INTHAND
    movwf PCL
    When PCL is written to, the contents of PCLATH and PCLATU are written to the Program Counter along with the value to the PCL. This will cause the instruction found at that address to be the next instruction executed.
    One other thing. Since INTHAND is a constant, ((INTHAND) >> 16) and ((INTHAND) >> 8) will be evaluated when the program is compiled. So, the actual assembly will only see an 8 bit value.
    Nov 2009
    London
    Thanks for all the replies. Though I somewhat understood what you have said above.
    I just to finally confirm what you have advised still applies as the following is the whole context saving code for PIC 16F676:
    define      INTHAND     _ISR
    ' The main program starts here
    ISR:
    asm
            movwf   wsave           ; Save WREG
            swapf   STATUS, W
            clrf    STATUS           ; Point to bank 0
            movwf   ssave           ; Save STATUS
            movf    FSR,w
            movwf    fsave          ; save FSR
            movf    PCLATH, W       ; Save PCLATH
            movwf   psave
    ; No problems in understanding up to here
            ; get ready to jump within the ISR page
            movlw   ((INTHAND) >> 8) ; Set PCLATH for jump
            movwf   PCLATH
    There is no PCL related statement in the context saving. Correct me if I am wrong, does INTHAND has address 4 stored in it?
    Aug 2005
    Michigan, USA
    The PBP instruction you're looking for might be "goto INTHAND", but, I wonder if there's really any need to jump to another program area for interrupt handler code?
    Nov 2009
    London
    Hello Mike, Yes you do need to go to another location of memory when interrupts get involved.
    I read the datasheet of the 16f676 and it does say the whole memory is only one page, so I don't know why PCLATH needs touching, I also checked the ISR routine example in the datasheet and it does not mentions anything about the PCLATH. Only saves WREG & STATUS.
    Aug 2005
    Michigan, USA
    Hi Megahertz,
    Was the original assembly language program written for a 16F676? Also, what is the source for the original assembly language program, please?
    Cheerful regards, Mike
