Two statements from assembly - trying to convert the code in PBasic Pro
Results 1 to 14 of 14
    May 2006
    Del Rio, TX, USA
    Default Re: Two statements from assembly - trying to convert the code in PBasic Pro
    movlw ((INTHAND) >> 8) => Shift the constant (literal) 8 bits right (equivalent to dividing by 256) then put the value in WREG
    movwf PCLATH => Move the value in WREG into PCLATH.
    So, these two statement combined are putting INTHAND/256 into the the middle byte of the program counter.
    Nov 2009
    London
    Steve, but
    1)INTHAND is not a variable, in fact it is mentioned in the statement
    define      INTHAND     _ISR
    2)What is the basic purpose of loading value in PCLATH
    cheers
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Megahertz View Post
    Steve, but
    define      INTHAND     _ISR
    Yes, you are right. But I didn't say it was a variable.
    The PCLATH is used (along with PCLATU) to make changes to the Program Counter, which is akin to directing the the program to a new location in the code: a "Computed GOTO."
    Nov 2009
    London
    Where is the constant here?
    I really suck at assembly programming but I'm going to say (write) what I think, then hopefully someone will correct me if I'm wrong.
    The constant in this case is called INTHAND which is defined to contain the adress, in program memory, where the routine _ISR is located. What happens is that PCLATH (the high byte of the program counter) gets loaded with the 8 high bits of the adress of _ISR. I suspect there's also code to take the low 8 bits and put them in PCLATU. All in all, that would cause the program to jump to _ISR.
    After reading SteveB's other posts that's my understanding of it but again I might very well be wrong.
    May 2006
    Del Rio, TX, USA
    Very good deduction Henrik!
    Nov 2009
    London
    Ok it has started making sense now. But 1 weird thought is there still, this line itself is part of the ISR routine, then what do you mean by
    All in all, that would cause the program to jump to_ISR.
    May 2006
    Del Rio, TX, USA
    In PBP, the label "ISR" will be annotated in assembly as "_ISR" as a literal (i.e. constant). It represents the address of the first instruction following the label in PBP. The address is a 21 bit address. The bottom 8 bits (low byte, bits 0-7) are directly readable/writeable. The high byte (bits 8-15) and upper byte (bits 16-20) can only be read/written through the registers PCLATH and PCLATU respectively
    So... You will likely see something like this as well:
    movlw ((INTHAND) >> 16)
    movwf PCLATU
    movlw INTHAND
    movwf PCL
    When PCL is written to, the contents of PCLATH and PCLATU are written to the Program Counter along with the value to the PCL. This will cause the instruction found at that address to be the next instruction executed.
    One other thing. Since INTHAND is a constant, ((INTHAND) >> 16) and ((INTHAND) >> 8) will be evaluated when the program is compiled. So, the actual assembly will only see an 8 bit value.
