Ok it has started making sense now. But 1 weird thought is there still, this line itself is part of the ISR routine, then what do you mean byAll in all, that would cause the program to jump to_ISR.
In PBP, the label "ISR" will be annotated in assembly as "_ISR" as a literal (i.e. constant). It represents the address of the first instruction following the label in PBP. The address is a 21 bit address. The bottom 8 bits (low byte, bits 0-7) are directly readable/writeable. The high byte (bits 8-15) and upper byte (bits 16-20) can only be read/written through the registers PCLATH and PCLATU respectively
So... You will likely see something like this as well:
movlw ((INTHAND) >> 16)
movwf PCLATU
movlw INTHAND
movwf PCL
When PCL is written to, the contents of PCLATH and PCLATU are written to the Program Counter along with the value to the PCL. This will cause the instruction found at that address to be the next instruction executed.
One other thing. Since INTHAND is a constant, ((INTHAND) >> 16) and ((INTHAND) >> 8) will be evaluated when the program is compiled. So, the actual assembly will only see an 8 bit value.
Thanks for all the replies. Though I somewhat understood what you have said above.
I just to finally confirm what you have advised still applies as the following is the whole context saving code for PIC 16F676:
There is no PCL related statement in the context saving. Correct me if I am wrong, does INTHAND has address 4 stored in it?Code:define INTHAND _ISR ' The main program starts here goto main ISR: asm movwf wsave ; Save WREG swapf STATUS, W clrf STATUS ; Point to bank 0 movwf ssave ; Save STATUS movf FSR,w movwf fsave ; save FSR movf PCLATH, W ; Save PCLATH movwf psave ; No problems in understanding up to here ; get ready to jump within the ISR page movlw ((INTHAND) >> 8) ; Set PCLATH for jump movwf PCLATH
The PBP instruction you're looking for might be "goto INTHAND", but, I wonder if there's really any need to jump to another program area for interrupt handler code?
Hello Mike, Yes you do need to go to another location of memory when interrupts get involved.
I read the datasheet of the 16f676 and it does say the whole memory is only one page, so I don't know why PCLATH needs touching, I also checked the ISR routine example in the datasheet and it does not mentions anything about the PCLATH. Only saves WREG & STATUS.![]()
Hi Megahertz,
Was the original assembly language program written for a 16F676? Also, what is the source for the original assembly language program, please?
Cheerful regards, Mike
This was written for 16F676 only originally. The source I don't know but I got it from my friend at UNI, we both are trying to understand the context saving part of it.
