Index a bit through a portion of a port
Results 1 to 17 of 17
    Sep 2007
    Waco, Texas
    Default Re: Index a bit through a portion of a port
    It added it but ALL the LEDs came on. What I added was (can't seem to master the code posting.....) I added LED1=!!(pkt_cntr=1) and so on.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Quote Originally Posted by ecoli-557 View Post
    Do your LED's go to ground or VDD?
    If they go to VDD, only use 1 "!"
    LED1 = !(pkt_cntr=1)
    LED2 = !(pkt_cntr=2)
    LED3 = !(pkt_cntr=3)
    LED4 = !(pkt_cntr=4)
    Sep 2007
    Waco, Texas
    Thanks, They are pulled up to +5v via 1K. I just tried the single '!' and none light.The base address and offset I understood, the suggestion LED1 = !(pkt_cntr=1) and so on I do not understand. Care to enlighten?
    - Albert Einstein
    Sep 2007
    Waco, Texas
    Darrel-Your add DOES work. SOmehow my variable 'pkt_cntr' is getting weird values like $94, $46, $19, $C0. Strange for such a simple counter.I will continue to look into it.I would like to fully understand the command 'LED1 = !(pkt_cntr=1) so I can learn.....Thanks and Regards,Ecoli-557
    - Albert Einstein
    Yes, it does work.
    But you seem to come to those conclusions while I'm working on something to prove it.
    That's twice now today.
    Think about it. Then tell me how it works.
    Sep 2007
    Waco, Texas
    Sorry about my misplaced enthusiasm..... I have a few days to fool around with this without too much interruption and I get excited. My apologies.
    Re the boolian math, I get the inversion, but I don't think I get the connection written the way it is.LED1 (the port) = (will follow) ! (NOT or inverse of) (pkt_cntr=1) <-- here is where I get fuzzy.
    We take the inverse of the variable which is hard-coded but which is in a loop which is increased each time I get a packet?? I am befuddled. I will takes my whippin' now.....
    I do understans the NOT of the port pin so the LED will fire, what I don't see is the hard-code inside a loop which is increasing the var??
    - Albert Einstein
    pkt_cntr=1 gives a "Logical" result of True or False.
    Logical results can't be assigned to a BIT value.
    The ! (NOT) will convert a Logical Value to a BIT value (0 or 1), but the logic is inverted due to the NOT.
    Using two !! changes to a non-inverted bitwise value.
    With your LED's tied to VDD, you need the inverted version, which gives either a 1 or 0 according to the Logical comparison.
    So the LED will be ON when the comparison evaluates True.
    With all 4 of the LEDs given a different comparison, only one of them will be ON at a time.
