Assign different port bits to an array?
Results 1 to 5 of 5
    Mar 2010
    Question Assign different port bits to an array?
    I have several outputs that are on different ports. I would like to use an array to cycle through the outputs, turning then on and off one at a time.
    Is there a way to assign different port bits to an array?
    Something like this: (I know this won't work but this kind of shows what I want to do)
    '* Configure Variables for Lights
        Lights    VAR Bit[NoLights]
        Lights[0] VAR PORTB.1
        Lights[1] VAR PORTE.2
        Lights[2] VAR PORTE.1
        Lights[3] VAR PORTE.0
        Lights[4] VAR PORTA.5
        Lights[5] VAR PORTA.4
    Then I would do something like this:
    'turn off all the lights
        for x = 0 to NoLights
            Lights[x] = 0
        next x
    Hi vamtbrider,
    read these posts for your answer:
    http://www.picbasic.co.uk/forum/showthread.php?t=1339
    http://www.picbasic.co.uk/forum/show...t=4074&p=22065
    Use this tool to search this forum, it is a special Google engine, and you can also search 2 or 2 letter items:
    http://www.google.com/custom?hl=en&c...ch&sitesearch=
    Mar 2010
    Joe S.
    Thanks for the link, that was exactly what I was looking for. I haven't played with marcos much but this will be a good start.
    I have been searching for a couple hours using the forum search and wasn't finding any leads.
    I will now use the google link you sent.
    Thanks again for pointing me in the right direction.
    <h1>Super !</h1>
    Happy it helped ! So many times, it seems my help isn't, but I try.
    "Trying is the first step toward failure". Homer Simpson
    Sep 2005
    Campbell, CA
    This should also work for what you are trying to do.
    ' PORT OFFSETS
    '"A.0",0
    '"A.1",1
    '"A.2",2
    '"A.3",3
    '"A.4",4
    '"A.5",5
    '"A.6",6
    '"A.7",7
    '"B.0",8
    '"B.1",9
    '"B.2",10
    '"B.3",11
    '"B.4",12
    '"B.5",13
    '"B.6",14
    '"B.7",15
    '"C.0",16
    '"C.1",17
    '"C.2",18
    '"C.3",19
    '"C.4",20
    '"C.5",21
    '"C.6",22
    '"C.7",23
    '"D.0",24
    '"D.1",25
    '"D.2",26
    '"D.3",27
    '"D.4",28
    '"D.5",29
    '"D.6",30
    '"D.7",31
    '"E.0",32
    '"E.1",33
    '"E.2",34
    '"E.3",35
    '"E.4",36
    '"E.5",37
    '"E.6",38
    '"E.7",39
    '"F.0",40
    '"F.1",41
    '"F.2",42
    '"F.3",43
    '"F.4",44
    '"F.5",45
    '"F.6",46
    '"F.7",47
    '"G.0",48
    '"G.1",49
    '"G.2",50
    '"G.3",51
    '"G.4",52
    '"G.5",53
    '"G.6",54
    '"G.7",55
    '"H.0",56
    '"H.1",57
    '"H.2",58
    '"H.3",59
    '"H.4",60
    '"H.5",61
    '"H.6",62
    '"H.7",63
    '"J.0",64
    '"J.1",65
    '"J.2",66
    '"J.3",67
    '"J.4",68
    '"J.5",69
    '"J.6",70
    '"J.7",71
         For X = 0 to 10
            Lookup X,[0,1,2,5,9,10,11,12,13,15,19,70],PortValue ; Put the bits you want to modify here, use table above
            Lookup X,[1,1,0,1,1,0,1,0,0,0,0],State ; put a 1 or a 0 here to determine state.
            TRISA.0(PortValue) = 0               ;Make it an output
            PORTA.0(PortValue) = State        ;Set/Clear the bit
         Next X
    Charles Linquist
