Index a bit through a portion of a port
Results 1 to 17 of 17
    Sep 2007
    Waco, Texas
    Default Re: Index a bit through a portion of a port
    Wow, so simple. This is MUCH better than what I started with. However, the LEDs do come on one at a time until they are all on. Then they go off one at a time untill all are off.I understand what you said and are doing by using the logical NOT.Is there a way to turn on only onle LED at a time? eg, 1st packet = LED1 on and all others are off, 2nd packet in=LED2 on and all others off, 3rd packet=LED3 on all others off, 4th packet =LED4 on and all others off, 5th packet=LED1 on all others off, etc??BTW, solved my CRC16 issue - it now works!Thanks again Darrel.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    LED1 = !!(packetRcvd=1)
    LED2 = !!(packetRcvd=2)
    LED3 = !!(packetRcvd=3)
    LED4 = !!(packetRcvd=4)
    Sep 2007
    Waco, Texas
    It added it but ALL the LEDs came on. What I added was (can't seem to master the code posting.....) I added LED1=!!(pkt_cntr=1) and so on.
    - Albert Einstein
    Quote Originally Posted by ecoli-557 View Post
    Do your LED's go to ground or VDD?
    If they go to VDD, only use 1 "!"
    LED1 = !(pkt_cntr=1)
    LED2 = !(pkt_cntr=2)
    LED3 = !(pkt_cntr=3)
    LED4 = !(pkt_cntr=4)
    Sep 2007
    Waco, Texas
    Thanks, They are pulled up to +5v via 1K. I just tried the single '!' and none light.The base address and offset I understood, the suggestion LED1 = !(pkt_cntr=1) and so on I do not understand. Care to enlighten?
    - Albert Einstein
    Sep 2007
    Waco, Texas
    Darrel-Your add DOES work. SOmehow my variable 'pkt_cntr' is getting weird values like $94, $46, $19, $C0. Strange for such a simple counter.I will continue to look into it.I would like to fully understand the command 'LED1 = !(pkt_cntr=1) so I can learn.....Thanks and Regards,Ecoli-557
    - Albert Einstein
    Yes, it does work.
    But you seem to come to those conclusions while I'm working on something to prove it.
    That's twice now today.
    Think about it. Then tell me how it works.
