Pulse Counter
Results 1 to 14 of 14
Thread: Pulse Counter
    Default Re: Pulse Counter
    The code is "generic", ie you need to "fit" it to the device you're using.
    First time I've seen it but as far as I can see it uses TMR1 as a counter and TMR0 as the timebase. So the pulses should go to the T1CKI-pin, whichever that is on the particular PIC you're using - RB6 on the 16F628, RC0 on the 16F877 etc.
    Nov 2008
    Thanks Henrik.
    CharlieM
    Using PBP3
    MCSPX
    Sao Paulo - Brazil
    Hi c_moore,
    sorry for my loooong delay
    Henrik is right. BTW, thank you Henrik !
    bye
    May 2012
    how can i use this code for pic16f84a.
    can anyone send me the hex or asm code thank you
    Quote Originally Posted by daydream View Post
    16F84 has only 1 timer so it won't work, it should work in a 16f628 if you turn off the comparators
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Need help with a pulse counter project PIC18F2620
    By blackrider in forum Schematics
    Last Post: - 29th April 2009, 01:08
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  5. Pulse Counter in Assembly
    By orlandoG in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 02:23
