Pulse Counter
Results 1 to 14 of 14
Thread: Pulse Counter
    Sao Paulo - Brazil
    Post Pulse Counter
    Hi Friends,
    some time ago, Tim Box sent me an example of a Pulse Counter developped to PB Plus and was published by him on Pronton+ forum.
    I did some changes in order to compile it on PBP.
    It is working fine on a small on board computer I´ve built for my opel corsa.
    I don't know if the code can be improved or changed to improve the performance. I did some tests and the code showed good results.
    It's good to remember that the code was written by Tim and I just did some changes.
    Comments are welcome.
    my best regards for all.
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 4
    Define LCD_EREG PORTB
    Define LCD_EBIT 5
    REM Variables
    TMR0_POSTCOUNT1 var WORD ' POSTSCALER COUNTERS
    COUNT_RESULT var WORD ' THE RESULT OF THE COUNT
    REFRESHED var BIT ' FLAG TO SAY COUNT REFRESHED
    ON INTERRUPT GOTO PULSE_COUNT ' DEFINE WHERE TO JUMP TO ON AN INTERRUPT
    GOTO INITIALIZE ' JUMP ALL INT CODE
    '----- INTERRUPT CODE -------------------
    Disable
    PULSE_COUNT:
    TMR0 = TMR0 + 7 ' RELOAD THE TIMER
    TMR0_POSTCOUNT1 = TMR0_POSTCOUNT1 - 1
    IF TMR0_POSTCOUNT1 = 0 THEN
    TMR0_POSTCOUNT1 = 500 ' 1/4 sec (may need some adjust)
    T1CON.0 = 0 ' TURN OFF THE TMR1
    COUNT_RESULT.lowbyte = TMR1L ' GET THE COUNT
    COUNT_RESULT.Highbyte = TMR1H ' GET THE COUNT
    TMR1L = 0
    TMR1H = 0
    T1CON.0 = 1
    REFRESHED = 1 ' SET FLAG TO SAY COUNT READ
    INTCON.2 = 0 ' CLEAR INTTERUPT FLAG
    Resume
    enable ' RELOAD THE SYSTEM VARS
    '------ END OF INTERRUPTS CODE ----------
    '------ INTIALIzE ALL REGS --------------
    INITIALIZE:
    TMR0_POSTCOUNT1 = 500 ' INITIALZE THE POST SCALERS
    OPTION_REG.0 = 0 ' SET THE PRESCALER TO 1:1
    OPTION_REG.1 = 0
    OPTION_REG.2 = 0
    OPTION_REG.5 = 0 ' TMR0 CLOCK FROM MAIN OSC
    OPTION_REG.3 = 0 ' IN THIS INSTANCE PRESCALER IS ASSINED TO TMR0
    INTCON.2 = 0 ' CLEAR INTERRUPT FLAG
    T1CON = %00000110
    T1CON.0 = 1 ' TURN TIMER 1 ON
    TMR0 = 7 ' LOAD THE TIMER
    INTCON.5 = 1 ' ENABLE TMR0 INTERRUPTS
    REFRESHED = 0 ' DONT MAKE FIRST READ UNTIL MAIN INT HAS OCCURED
    INTCON.7 = 1 ' START THE WHOLE THING RUNNING
    COUNT_RESULT = 0
    lcdout $FE,1
    '------ MAIN CODE BELOW HERE -------------
    LOOP:
    IF REFRESHED = 1 THEN
    lcdout $fe,1,$fe,2, "Freq = ", dec (COUNT_RESULT * 4) ' Show results in pulses / Sec
    REFRESHED = 0 ' PREVENT A RE-READ UNTIL NEXT MAIN INTERRUPT
    GOTO LOOP
    Jul 2009
    Worcester South Africa
    Default Re: Pulse Counter
    Hi Srspinho, can I use this code for a revolution counter, revs per minute? I see your display is counts per second. Can I just multiply the COUNT_result with 240, that should give me pulses per min, yes?
    Nov 2008
    I must be missing something,but what pin is input?
    CharlieM
    Using PBP3
    MCSPX
    Jul 2009
    Yeah, good question, C_Moore
    Nov 2008
    I don't see where any tris registers are initialized.
    CharlieM
    Using PBP3
    MCSPX
    The code is "generic", ie you need to "fit" it to the device you're using.
    First time I've seen it but as far as I can see it uses TMR1 as a counter and TMR0 as the timebase. So the pulses should go to the T1CKI-pin, whichever that is on the particular PIC you're using - RB6 on the 16F628, RC0 on the 16F877 etc.
    Nov 2008
    Thanks Henrik.
    CharlieM
    Using PBP3
    MCSPX
    Sao Paulo - Brazil
    Hi c_moore,
    sorry for my loooong delay
    Henrik is right. BTW, thank you Henrik !
    bye
    May 2012
    how can i use this code for pic16f84a.
    can anyone send me the hex or asm code thank you
    Quote Originally Posted by daydream View Post
    16F84 has only 1 timer so it won't work, it should work in a 16f628 if you turn off the comparators
    May 2012
    hi archangel,i have pic16f628a.what are comparators?how do I turn them off?with this CMCON=7?
    and if i connect my lcd and use a 4mhz crystal and pin RB6 for input,will lcd show the freq?
    thank you so much.
    Mar 2011
    Los Angeles, California
    I am probably confused as to what the goal is here and PBP has a command called "Count" (Chapter 5.13, page 129). Best, Ed
    Nov 2008
    PBP as well as other compilers that have the COUNT command use a software loop to count pulses. which means that it's a blocking command and nothing else can happen while counting pulses. the code above uses hardware timers that can work in the background.
    CharlieM
    Using PBP3
    MCSPX
    Mar 2011
    Thanks Charlie, My knowledge is very limited and I guess when I read that you are specifying a lenght of time for "count" to run it was not any different than his "pause 500"? It just seems if you are pausing for half a second then you could be using this same amount of time for your time duration? Or did I miss something?
    Best, Ed
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Need help with a pulse counter project PIC18F2620
    By blackrider in forum Schematics
    Last Post: - 29th April 2009, 01:08
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  5. Pulse Counter in Assembly
    By orlandoG in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 02:23
