Hi Friends,
some time ago, Tim Box sent me an example of a Pulse Counter developped to PB Plus and was published by him on Pronton+ forum.
I did some changes in order to compile it on PBP.
It is working fine on a small on board computer I´ve built for my opel corsa.
I don't know if the code can be improved or changed to improve the performance. I did some tests and the code showed good results.
It's good to remember that the code was written by Tim and I just did some changes.
Comments are welcome.
my best regards for all.
Define LCD_DREG PORTA
Define LCD_DBIT 0
Define LCD_RSREG PORTB
Define LCD_RSBIT 4
Define LCD_EREG PORTB
Define LCD_EBIT 5
REM Variables
TMR0_POSTCOUNT1 var WORD ' POSTSCALER COUNTERS
COUNT_RESULT var WORD ' THE RESULT OF THE COUNT
REFRESHED var BIT ' FLAG TO SAY COUNT REFRESHED
ON INTERRUPT GOTO PULSE_COUNT ' DEFINE WHERE TO JUMP TO ON AN INTERRUPT
GOTO INITIALIZE ' JUMP ALL INT CODE
'----- INTERRUPT CODE -------------------
Disable
PULSE_COUNT:
TMR0 = TMR0 + 7 ' RELOAD THE TIMER
TMR0_POSTCOUNT1 = TMR0_POSTCOUNT1 - 1
IF TMR0_POSTCOUNT1 = 0 THEN
TMR0_POSTCOUNT1 = 500 ' 1/4 sec (may need some adjust)
T1CON.0 = 0 ' TURN OFF THE TMR1
COUNT_RESULT.lowbyte = TMR1L ' GET THE COUNT
COUNT_RESULT.Highbyte = TMR1H ' GET THE COUNT
TMR1L = 0
TMR1H = 0
T1CON.0 = 1
REFRESHED = 1 ' SET FLAG TO SAY COUNT READ
INTCON.2 = 0 ' CLEAR INTTERUPT FLAG
Resume
enable ' RELOAD THE SYSTEM VARS
'------ END OF INTERRUPTS CODE ----------
'------ INTIALIzE ALL REGS --------------
INITIALIZE:
TMR0_POSTCOUNT1 = 500 ' INITIALZE THE POST SCALERS
OPTION_REG.0 = 0 ' SET THE PRESCALER TO 1:1
OPTION_REG.1 = 0
OPTION_REG.2 = 0
OPTION_REG.5 = 0 ' TMR0 CLOCK FROM MAIN OSC
OPTION_REG.3 = 0 ' IN THIS INSTANCE PRESCALER IS ASSINED TO TMR0
INTCON.2 = 0 ' CLEAR INTERRUPT FLAG
T1CON = %00000110
T1CON.0 = 1 ' TURN TIMER 1 ON
TMR0 = 7 ' LOAD THE TIMER
INTCON.5 = 1 ' ENABLE TMR0 INTERRUPTS
REFRESHED = 0 ' DONT MAKE FIRST READ UNTIL MAIN INT HAS OCCURED
INTCON.7 = 1 ' START THE WHOLE THING RUNNING
COUNT_RESULT = 0
lcdout $FE,1
'------ MAIN CODE BELOW HERE -------------
LOOP:
IF REFRESHED = 1 THEN
lcdout $fe,1,$fe,2, "Freq = ", dec (COUNT_RESULT * 4) ' Show results in pulses / Sec
REFRESHED = 0 ' PREVENT A RE-READ UNTIL NEXT MAIN INTERRUPT
GOTO LOOP
