Two line LCD double height numbers, possible ???
Results 1 to 26 of 26
    Dec 2011
    IO93ok
    Default Re: Two line LCD double height numbers, possible ???
    Shawn, you've copyrighted and reserved the rights. Is it all right with you that I modify it and put it on here ?
    Apr 2007
    Pennsylvania, USA
    Quote Originally Posted by tasmod View Post
    Copy all you want, most of the code was copied off of this site as it is already!
    Shawn
    Dec 2011
    IO93ok
    Thanks, it's just that normally I wouldn't add the copyright notice for anything for open source public consumption.
    I'm trying to use just the seconds and 'ticks'
    Apr 2007
    Pennsylvania, USA
    MCS adds that automatically the way I have it set up. I will change that for future posts. Thanks for pointing it out.
    Shawn
    Dec 2011
    IO93ok
    OK, I have the Dt_ints stopwatch version working on my display using the thinner characters as i.e. 123:45
    This works bar one problem.
    It will not display the Character 0 code it is just an all pixel black block. So this affects the numbers 1, 4, 7.
    The code I mean is
    LCDOUT $FE,$40,$01,$01,$01,$01,$01,$01,$01,$01
    According to the sheet that came with the display it has 16 CGRAM custom character spaces available.
    I tried using Character 8 instead . i.e. LCDOUT $FE,$80,$01,$01,$01,$01,$01,$01,$01,$01
    this produced a curled 'J' character which is not part of the inbuilt set.
    I can't figure this one out??? Any ideas please ?
    Apr 2007
    Pennsylvania, USA
    You have the LCDOUT command correct to display a '1' I don't see any problems. I feel the problem is somewhere else in your code. All the other 7 characters work fine?
    Shawn
    Dec 2011
    IO93ok
    Grrr, how come when I post the problem it immediately solves itself. I just resaved the bas file under a different name and reprogrammed the chip and it works!
    Thanks for the input Shawn.
    I now have a stopwatch that works and will have easier to read characters. :-)
