Two line LCD double height numbers, possible ???
Results 1 to 26 of 26
    Apr 2007
    Pennsylvania, USA
    Default Re: Two line LCD double height numbers, possible ???
    You have the LCDOUT command correct to display a '1' I don't see any problems. I feel the problem is somewhere else in your code. All the other 7 characters work fine?
    Shawn
    Dec 2011
    IO93ok
    Grrr, how come when I post the problem it immediately solves itself. I just resaved the bas file under a different name and reprogrammed the chip and it works!
    Thanks for the input Shawn.
    I now have a stopwatch that works and will have easier to read characters. :-)
    Apr 2007
    Pennsylvania, USA
    I know what you mean!
    Shawn
    Dec 2011
    IO93ok
    Ahh, I spoke to soon. It does work but not as I would want.
    I believe it's in the assembler bit of Elapsed_Int that I need to make a change but I don't know where to start. :-(
    The 3 x seconds digits rollover at 59.99 and zero again. The digits do not continue to 60, 61 etc. the first digit stays at 0 as well. I need it to continue to 3 x seconds digits probably ending at 500 but not essential. So that 129.54 would be possible say.
    Anyone give me a clue ??
    Dec 2011
    IO93ok
    This is the code I have :-
    '*             : PIC16F628                                      *
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    define OSC 10               'oscillator setting
    define LCD_COMMANDUS 1500   'set command delay in us
    define LCD_DATAUS 50        'set data delay in us
    define LCD_DREG PORTB       'set LCD data port
    define LCD_DBIT 4           'set LCD starting data bit
    define LCD_RSREG PORTB      'define RS port
    define LCD_RSBIT 2          'define RS bit
    define LCD_EREG PORTB       'set LCD ENABLE port
    define LCD_EBIT 3           'set LCD ENABLE bit
    define LCD_BITS 4           'set LCD bits 4 or 8
    define LCD_LINES 2          'set # of LCD rows 2 or 4
    clear
    cmcon=7
    trisb=%00000000
    trisa=%11111111
    input  porta.0
    input  porta.1
    input  porta.2
    nPos  var byte
    nDig  var byte
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,1
    'setup the custom characters
    LCDOUT  $FE,$40,$01,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$11,$11,$11,$11,$11,$11,$11  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$10,$10,$10,$10,$10,$10,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$01,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$11,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #7
    LCDOUT  $FE,$80,$01,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #0
    'ELAPSED TIMER
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    lcdout $fe, CS            ' Clear screen
    MAIN:                     'Display time
      if porta.0 = 1 then GOSUB StartTimer     ' Start the Elapsed Timer
      if porta.1 = 1 then gosub StopTimer
      if porta.2 = 1 then GOSUB ResetTime      ' Reset Time
        nDig=seconds dig 2 : nPos=0 : gosub displaydigit   'hundreds
        nDig=seconds dig 1 : nPos=1 : gosub displaydigit   'tens
        ndig=seconds dig 0 : npos=2 : gosub displaydigit   'ones
        LCDOUT $FE,$C0+3,":"
        ndig=ticks dig 1 : npos=4 : gosub displaydigit     'tenths
        ndig=ticks dig 0 : npos=5 : gosub displaydigit     'hundreths
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub One
    if ndig=2 then gosub Two
    if ndig=3 then gosub Three
    if ndig=4 then gosub Four
    if ndig=5 then gosub Five
    if ndig=6 then gosub Six
    if ndig=7 then gosub Seven
    if ndig=8 then gosub Eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    Apr 2007
    Pennsylvania, USA
    The timer works like a clock. when seconds roll over from 59 it will go to 00 and minutes will advance. There is no hundreds position in the seconds.
    Shawn
    Dec 2011
    IO93ok
    Hmm, yes. But it must be possible for it to continue instead of rolling over. This is what I altered in Melanies code to do this, however that was all PBP and no assembler.
    That's where I'm lost. The code in Elapsed_INT I'm sure can be modified to continue counting the seconds into the seconds byte without a rollover, but where in the code?
