NEC IR Protocol remote decoder, help me before I kill myself!
Results 1 to 26 of 26
    Dec 2004
    Scarborough UK
    Default Re: NEC IR Protocol remote decoder, help me before I kill myself!
    Bruce, thank you :-)
    Your code worked perfectly at 4 mhz first go :-)
    So, I've hacked away at it all day and through trial & error and determination I have got it to work at 20mhz, It was a total pain I could not work out the math for the life of me, so I searched the forum and net, but everyone seems to have a different idea on how to work it out, in the end I resorted to trial & error but I got it to work at 20mhz.
    The repeatsub does not work correctly all the time, again I assum a timing error
    I show the results below for all to see, I've also tried to add the repeat (button held down) function with limited success, if you or anyone would care to comment on or improve the end result that would be awesom..
    '#CONFIG
    '__config _XT_OSC & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    '#ENDCONFIG
    'Defines for EasyPic3
    DEFINE LCD_DREG PORTB ' Define LCD registers and bits
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    INCLUDE "AllDigital.pbp" 'Set ALL ports to Digital i/o
    include "LCDDEFS.bas" 'easy lcd
    DEFINE OSC 20 'set osc to 20mhz
    Leader VAR WORD ' will be up to 900 for a 9mS leader pulse
    BtnVal VAR word[32] ' holds 32 pulse results 'NEEDS TO BE WORD VAR FOR 20Mhz
    DByte1 VAR BYTE ' address byte
    DByte2 VAR BYTE ' inverse of address byte
    DByte3 VAR BYTE ' command byte
    DByte4 VAR BYTE ' inverse of command byte
    i VAR BYTE ' loop count
    PULSIN PORTC.0,0,Leader ' leader pulse is ~9mS low-going
    IF Leader < 4400 THEN goto Main 'use 850 for 4mhz, use 4400 for 20mhz
    FOR i = 0 TO 31 ' grab 32 incoming pulses
    PULSIN PORTC.0,1,BtnVal(i) ' now measuring high-going pulse widths
    if btnval(i) > 950 then goto repeatsub 'capture repeat pulse ?
    NEXT i
    ' now we'll decode 4 bytes from 32 pulses (address)
    FOR i = 0 TO 7
    IF BtnVal[i] > 350 THEN ' > use 150 for 4mhz, use 350 for 20mhz
    DByte1.0[i]=1
    DByte1.0[i]=0
    NEXT i
    'now we'll decode 4 bytes from 32 pulses (command)
    FOR i = 16 TO 23
    DByte3.0[i-16]=1
    DByte3.0[i-16]=0
    NEXT i
    'show results on LCD, address on top line & command on bottom line
    Lcdout cmd,clss,cmd,movtoA2, "Address " , hex DByte1 'debug to LCD display
    lcdout cmd,movtoB2, "Command " , hex DByte3 'debug to LCD display
    'HSEROUT [BIN8 DByte1,13,10,BIN8 DByte2," Address",13,10,13,10]
    'HSEROUT [BIN8 DByte3,13,10,BIN8 DByte4," Command",13,10,13,10]
    PAUSE 200 'dont know why this is needed for it to work ?
    GOTO Main
    'we get to heare if button on remote is held down
    repeatsub:
    toggle porta.0 ' led to tell us that a button is held down (repeat)
    PAUSE 400 'only god knows why this is needed for it to work ?
    Thanks..
    Bruce
    Ioannas
    dhouston
    bogdan
    cncmachineguy
    jumper
    Reading the datasheet & understanding it are two different things.
    Jan 2013
    Quote Originally Posted by Bonxy View Post
    '#CONFIG
    '#ENDCONFIG
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EBIT 3
    NEXT i
    FOR i = 0 TO 7
    DByte1.0[i]=1
    DByte1.0[i]=0
    NEXT i
    FOR i = 16 TO 23
    DByte3.0[i-16]=1
    DByte3.0[i-16]=0
    NEXT i
    GOTO Main
    repeatsub:
    Thanks..
    Bruce
    Ioannas
    dhouston
    bogdan
    cncmachineguy
    jumper
    Hello friend my name es Paul, one question: what happen if I want to turn on the light with a specific key to the remote control? example, I want to turn on the light with the source button, from my samsug led tv, the codec is: E0E0807F hex, please help me.
    Nov 2006
    Murrieta, CA
    Quote Originally Posted by pull88 View Post
    I know this reply is 5 years too late.. lol. but just in case anyone else would like to control their lights. http://www.picbasic.co.uk/forum/showthread.php?t=15712
    There are 10 kinds of people. Those that know binary and those that do not.
    By the way, your signature link is not valid anymore. Are you aware of that?
    Nov 2006
    Murrieta, CA
    Bonxy,
    Thank you for figuring out 20Mhz values. i would have never thought they would be different between different oscillators.
    Pro Tip: there are new LED lights at SAM's club that have an infrared remote. the remotes operate on the NEC protocol not to mention they are color coded buttons !!!
    Gary D.
