There are much better/faster ways to do this, but this should get you started with something that's fairly easy to understand.
Assuming you have an NEC transmitter that outputs something like the top portion of the graphic below;
This should return similar results to what's shown in the serial terminal window just above.
Code:#CONFIG __config _XT_OSC & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF #ENDCONFIG DEFINE OSC 4 Leader VAR WORD ' will be up to 900 for a 9mS leader pulse BtnVal VAR BYTE[32] ' holds 32 pulse results DByte1 VAR BYTE ' address byte DByte2 VAR BYTE ' inverse of address byte DByte3 VAR BYTE ' command byte DByte4 VAR BYTE ' inverse of command byte X VAR BYTE ' loop count Main: PULSIN PORTB.0,0,Leader ' leader pulse is ~9mS low-going IF Leader < 850 THEN Main FOR X = 0 TO 31 ' grab 32 incoming pulses PULSIN PORTB.0,1,BtnVal(X) ' now measuring high-going pulse widths NEXT X ' now we'll decode 4 bytes from 32 pulses FOR X = 0 TO 7 ' sort 1st 8 pulses IF BtnVal[X] > 150 THEN ' > 150 x 10uS = > 1.5mS pulse period DByte1.0[X]=1 ELSE DByte1.0[X]=0 ENDIF NEXT X FOR X = 8 TO 15 ' sort 2nd 8 pulses, etc.... IF BtnVal[X] > 150 THEN DByte2.0[X-8]=1 ELSE DByte2.0[X-8]=0 ENDIF NEXT X FOR X = 16 TO 23 IF BtnVal[X] > 150 THEN DByte3.0[X-16]=1 ELSE DByte3.0[X-16]=0 ENDIF NEXT X FOR X = 24 TO 31 IF BtnVal[X] > 150 THEN DByte4.0[X-24]=1 ELSE DByte4.0[X-24]=0 ENDIF NEXT X HSEROUT [BIN8 DByte1,13,10,BIN8 DByte2," Address",13,10,13,10] HSEROUT [BIN8 DByte3,13,10,BIN8 DByte4," Command",13,10,13,10] PAUSE 1000 GOTO Main
