OK, I have now tried to implement the DT_INST-14 routines into my main project code. The attached code file has sufficient comments to explain what it is doing.
I am getting the following errors when I try to compile the program:
Executing: "C:\PBP\PBPMPLAB.BAT" -ampasmwin -k- -p12F683 "PICSprayer.bas"
Executing: "C:\PBP\PBPW.EXE" -ampasmwin -k- -p12F683 "PICSprayer.bas"
PICBASIC PRO(TM) Compiler 2.60C, (c) 1998, 2011 microEngineering Labs, Inc.
All Rights Reserved.
ERROR: Unable to execute mpasmwin.Error[127] C:\PBP\PROJECTS\PIC SPRAYER\PICSPRAYER.ASM 912 : Too many arguments
Error[128] C:\PBP\PROJECTS\PIC SPRAYER\PICSPRAYER.ASM 473 : Missing argument(s)
Halting build on first failure as requested.
BUILD FAILED: Fri Jul 08 11:35:51 2011
My code compiles properly without the interrupt routine for the manual switch operation. Now I just don't know where to start looking to fix these errors.
Any help would be greatly appreciated.
Cheers
Barry
PICSprayer.bas
PICSPRAYER_r6.pdf
