DT Instant Interrupts - Clarification?
Results 1 to 23 of 23
    Jan 2011
    Sydney, Australia
    Default Re: DT Instant Interrupts - Clarification?
    Thanks Bruce and Gadelhas.
    I have made the recommended changes and am pleased to advise that it now compiles correctly.
    Now to fire it up on the breadboard to see if it works as expected.
    Dave, I do no understand your comment regarding the use of code tags. Can you explain further or direct me to somewhere that will outline what I am not doing?
    Cheers
    Barry
    Jan 2011
    Sydney, Australia
    Hi All,
    I am pleased to announce that the external interrupt routine is now working properly. Thank you to all who have helped me resolve my problems - much appreciated
    To aid in my PCB layout I would like to move my ADC channels to AN1 and AN2. This will mean that I need to alter the type of interrupt from an external interrupt on GP2 to a Change on Interrupt on GP4. To do this I have changed the Interrupt Handler in DT_INST-14 from INT_INT to GPC_INT, Enable GPC_INT and enabled bit 4 of the Interrupt-On-Change GPIO Register (ie IOC.4=1). My interrupt switch is set up with a 10k pull-up resistor from GP4 to +5V and a momentary action switch from GP4 to 0V. The code compiles without error but the change on interrupt function does not work in "the real world".
    I would have thought this was a pretty straight forward change but I am obviously missing something important. Would someone please direct me to where I have gone wrong?
    Cheers
    Barry
    Hi Barry,
    In your latest attached code you have the line
    ANSEL = %01011010       ' Set Fosc/16
    Which sets GPIO.4/AN3 to analog mode. Try changing it to digital if you haven't already done that.
    Jan 2011
    Sydney, Australia
    Hi Henrik,
    Yes, I had already changed the ANSEL register
    I had changed the TRISIO register too.
    Attached is my full code listing for reference.
    Now what? I am sure it is only something simple but I just can't figure it out...PICSprayer.bas
    Cheers
    Barry
    [ code] remove the spaces in the brackets [ /code]
    It will save folks from having to download your code to look at it.
    Aug 2010
    Maryland, USA
    Unless I am not following your changes right, It seems in your ISR you are still waiting while gpio.2 is high. since that is now an analog input (I think) it might just be zooming right through the ISR making it look as though it was never called.
    -Bert
    Jan 2011
    Sydney, Australia
    Yes, it was the GPOI.2 statement in the ISR that was causing the problem.
    All fixed now
    This is a Code Space Test
    Hey, I even got the code space thing happening - I'm on fire!!!
    Thanks for all your help guys - really appreciate it.
    I will post details of the final project once it is all up and running - code, circuit diagram, PCB and some pretty pictures of the finished product.
    Cheers
    Barry
    Just continuing on from this thread i have my own question about DT Interrupts for the 12F683.
    Having looked at the example given by darrell for the generic timer the code below seems unecessary if we know what the values are for the prescaler etc?
    ;---[TMR1 reload - interrupt handler]-----------------------------------------
    ASM ; Calculate Timer Reload Constant
    ReloadInst = 8; # of Intructions used to reload timer
    if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
    if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
    error Invalid Timer Values - check "OSC", "Freq" and "Prescaler"
    error Invalid Prescaler
    Do we need this error checking if we know and are happy with osc/prescaler/freq etc or am i missing something else. It looks like it might take a fair bit of code space?
