Is there a way to see if a DS18B20 is present
Results 1 to 4 of 4
    Denmark
    Default Is there a way to see if a DS18B20 is present
    Hi
    I have to know if a DS18B20 is "brokken" missing, so is there a way to see this?
    I have try this but is just say "yes a sensor" even if I have taken the DS18B20 of?
    check_sensor:
    Low comm_pin1 'Set the data pin low to initialize
    PauseUs 500 'Wait for more than 480us
    TRISA.0=1 'Release the data pin (set to input for high)
    PauseUs 100 'Wait for more than 60us
    IF comm_pin1=1 Then
    LcdOut $FE, $1, " NO " ' Show message
    Lcdout $fe, $c0, " sensor "
    pause 2000
    Else
    LcdOut $FE, $1, " yes a " ' Show message
    pause 2000
    EndIF
    Kent
    Default Re: Is there a way to see if a DS18B20 is present
    the only way is to read the sensor chip ID ...
    something like that:
    SensID:' Sensor Identification
      OWOUT DQ, 1, [ $33 ]								' Read Chip Family code
      OWIN  DQ, 2, [ FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC]
      													' PAR Device ???
      OWOut DQ, 1, [$55, FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC, $44 ]
      OWOut DQ, 1, [ $55, FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC, $BE ]
      PAUSE 750
      OWIN    DQ, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]	' Read two bytes
      IF FAM != $FF THEN
      	IF R_Temp = $0550 OR R_Temp = $AA THEN
      		PAR = 1
      	PAR = 0
      	LCDOUT $FE,$80, 				"NO SENSOR   "
      	LCDOUT $FE,$C0,					"Chk Sens & Reset"
      	STOP
      IF FAM = $05 THEN
       	LCDOUT $FE,$80,   				"DS 2405     "
      	PAUSE 1000
      	LCDOUT $FE,$80, 				" CRC: ",HEX2 CRC," FAM: ", HEX2 FAM
      IF FAM = $10 THEN
      	LCDOUT $FE,$80, 				"DS 18S20/1820"
      	IF PAR THEN LCDOUT $FE,$88," PAR " : PAUSE 1000
      	Tempo = 250
      	PAUSE 1000
      IF FAM = $22 THEN
       	LCDOUT $FE,$80, 				"DS 1822      "
     	OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_bit]    'Skip ROM search and write N_bits
      	'                                                 resolution to scratch pad
      	PAUSE 1000
      IF FAM = $28 THEN
       	LCDOUT $FE,$80, 				"DS 18B20     "
      	PAUSE 1000
      	LCDOUT $FE,$C0," ID:",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6]
    Denmark
    Thanks Alain
    This give me some things to work with, And I got it now
    I look at the ID if all is 0 the no sensor.
    Kent
    Nov 2011
    Post Re: Is there a way to see if a DS18B20 is present
    This I use and it works well:
    Start:
    OWOUT DQ, 1, [ $33 ]                 'send read Rom command
    OWIN DQ, 2, [ FaM,skip 7]            'read sensor family code, skip ID and CRC
       if FaM = $28 then SkipOver        'if FaM = 28 then sensor is present
       goto Start                              'sensor not present so do again
    SkipOver:                                  'continue your code here
    Hebe
  1. Please help with code for DS18B20
    Last Post: - 28th April 2013, 21:12
  2. Replies: 2
    Last Post: - 16th September 2011, 04:38
  3. Ds18b20
    By ahmed_salah in forum mel PIC BASIC Pro
    Last Post: - 14th June 2009, 15:21
  4. Ds18b20..
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 18th June 2008, 16:29
  5. using the DS18B20
    Last Post: - 22nd December 2006, 13:09
