When in doubt, use debug feature.
If you don't have a debug feature (using Wordpad instead of an IDE), then make one up. Just put in a bunch of LEDs on empty ports, and then make them blink different ways in different places in your code.
Or even better, get the easiest LCD on the market, the HD44780, and send debug messages (abbreviated syntax, just for example):
We do something similar as mainframe programmers; it's called using DISPLAY statements. There is no limit to what you can use as a debug feature. If it works for you, then it's perfect.Code:LCDOUT "Program start", var1, var2 Label_A: LCDOUT "Label A", var1, var2 Program logic... IF var1 < var2 then goto Label_A Label_B: LCDOUT "Label B", var1, var2 More program logic... IF var1 < var2 then goto Label_B LCDOUT "Program end", var1, var2
