The hardest thing for me to do is to go from a technical description of a given PBP command to a real world working piece of code. Whereas, once I see how to correctly use a given PBP statement, then I can usually write my way through my own code. Where I usually have trouble is with the syntax and good examples are invaluable.
This forum, PBPGroup, Rentron.com & Melabs website are full of handy code example, take a pick, modify them, try to make them better.
To me the PBP book is perfect. It explain what a specific command do. Just build a test program around it and you're all set. There's by far worst reference book... check MPASM assembler, most (see any) API/DLL reference... list is long
Programming... It's like everything, practice makes "perfect", the more you do, the easier it gets. Call it experience if you like. It take months, years, decade... it's a never ending learning process... welcome on the dark side
