Amicus shields
Results 1 to 34 of 34
Thread: Amicus shields
    Jul 2005
    The Netherlands
    Default Re: Amicus shields
    Hi Dave & Bruce,
    I see that the shield dim PDF from me. Ik will take a look for a physical PCB layout.
    I think, Microchip get never so much ground in the open source like the Arduino. The Arduino is world famous and very very popular by hobbist, education, profs etc.
    But, it will be nice that some shields be compatible.
    Good luck, Bruce with the RF shield.
    / Gevo
    Dec 2005
    Default Re: Amicus shields (A BEGINNING EM500/GA1000 LAYOUT)
    Here is my initial layout. It lacks connections and needs a few other tweaks. I'll wait until I receive the Xino Basic board I ordered and until Tibbo releases the long-promised firmware for the EM500/GA1000 combo.
    My health won't let me do much besides the prototype. If Bruce or Lester wants to offer it, the layout is my donation. Although, if Crownhill prices the bare shield at the £1199.99 inc. VAT price their web page has for the other bare shields, I'll want a cut should they ever sell one.
    These are much larger than life-size. Maybe a moderator can reduce them a bit.
    Click image for larger version
    Jul 2005
    The Netherlands
    Nice work Dave,
    A big shield for little hardware :-)
    I work on a carrierboard with the Ami18 Stamp Module, maybe we have some place for the Tibbo module.
    Best regards,
    / Gevo
    Yes, the Crownhill shields a little expensive :-)
    Dec 2005
    A bit of progress - I've identified the terminals along top & bottom of the board and have 3V3 and GND for the EM500 & GA1000. All that I need now are to decide on TX, RX, & RESET for the EM500 and the SPI connections between the EM500 & GA1000. Are there any suggestions for RX, TX & RESET? I don't want to create any conflicts.
    The GA1000 page at Tibbo says...
    The module utilizes SPI interace and only requires five I/O line to control. Flexible mapping allows your application to use any five available I/O pins.
    This applies to EM1000/EM1202/EM1206 but it's unknown whether it will apply to EM500 until Tibbo actually releases the long-promised firmware for the EM500/GA1000 combo.
    Last edited by ScaleRobotics; - 28th May 2011 at 00:07. Reason: try at changing size of picture
    Dec 2005
    In the spirit of the Audino/Amicus/Xino/??? projects I want to make this as universal and flexible as possible.
    Looking at the pictures of the Xino Basic board I have on order, they do not have the 4-pin power connector in the upper left corner, so it looks like I need to use the 3V3 from the lower edge.
    Also, I would like to use an SMT socket beneath the board for the GA1000 as it should simplify supporting the cantilevered board (e.g. with a stick-on dot) and keep the overall height to a minimum. How much vertical clearance is there on the bottom of the shield?
    Eight of the EM500 pins are available as GPIO pins if the EM1000 is not used. I'll try to work out a through-hole pad pattern to allow LEDs or digital inputs. Does anybody make LEDs with internal resistors suitable for 3V3?
    Any other thoughts and suggestions?
    Dec 2005
    Quote Originally Posted by Gevo View Post
    I captured it, redrew all the dimensions with a larger, darker font and created a new, more readable PDF.shield_v1.pdf
    jdaniels's Avatar
    jdaniels Guest
    Thank you for posting this...
    John
