EASYPIC4 Board Giveaway
Results 1 to 40 of 52
    Aug 2010
    Maryland, USA
    Default Re: EASYPIC4 Board Giveaway
    Oh! The prize gets even better. Is anyone working on this contest? I hate to see a great prize and contest not even attempted!
    -Bert
    May 2007
    Looks like nobody else, besides yourself, has any interest in this. So post your solution and lets see if you are the winner.
    Aug 2010
    Maryland, USA
    you have shamed me into it. LOL!
    I am putting it together now, likely I will slide in just under the april 30 deadline.
    -Bert
    Aug 2010
    Maryland, USA
    Heres my code so far. It appears to work as needed, but thus far I have only tested it with a sim. I will try and put the hardware together tonight and test it in real time.
    ' Name        : RMTEO Contest 2.pbp
    ' Compiler    : PICBASIC PRO Compiler 2.6A
    ' Assembler   : MPASM
    ' Target PIC  : 16F1947
    ' Hardware    : RMTEO Contest
    ' Oscillator  : internal
    ' Keywords    :
    ' Description : PICBASIC PRO program to drive 4 LED's at independent speeds
    ' adjustable from 4 pot's. fade from 0-100-0% for each cycle
    ' Configure ports
    ANSELA = %00001111  'port A 0-3 analog 4-7 digital
    ANSELE = %00000000  'port E all digital
    ANSELF = %00000000  'port F all digital
    ANSELG = %00000000  'port G all digital
    CM1CON0 = %00000000  'No comparaters
    CM1CON1 = %00000000
    CM2CON0 = %00000000
    CM2CON1 = %00000000
    ' preload latches before setting direction
    LATB = %00000000
    LATC = %00000000
    LATD = %00000000 'LED's 0 for red, 1 FOR GREEN should start red
    LATF = %00000000 ' low nibble is drive enable. 1 disables
    LATG = %00000000
    ' I/O direction
    TRISA = %00001111'x,x,x,x,p3,p2,p1,p0
    TRISB = %00000000'x,x,x,x,led3,led2,led1,led0
    TRISC = %00000000'UNUSED
    TRISD = %00000000'UNUSED
    TRISE = %00000000'UNUSED
    TRISF = %00000000'UNUSED
    TRISG = %00000000'UNUSED
    'REMOVE THIS LINE IF NOT SETTING THE CONFIGS IN CODE SPACE
    @ __config _CONFIG1,_FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    @ __config _CONFIG2,_WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_OFF & _LVP_OFF ;_BORV_25
    '------------------Internal osc setup
    OSCCON = %11110000 'clock is 8 meg. turn on PLL for 32 meg clock
    DEFINE OSC 32
    DEFINE NO_CLRWDT 1
    'Variables
    'Port assignments
    '------------------port B
    '---------------------words
    freqs1  var word
    freqs2  var word
    freqs3  var word
    freqs4  var word
    freq1   var word
    freq2   var word
    freq3   var word
    freq4   var word
    '---------------------Bytes
    TICKS   VAR BYTE
    display VAR BYTE
    duty1   VAR BYTE
    duty2   VAR BYTE
    duty3   VAR BYTE
    duty4   VAR BYTE
    myflags var byte
    '---------------------Bits
     led1   var display.0
     led2   var display.1
     led3   var display.2
     led4   var display.3
     df1    var myflags.0
     df2    var myflags.1
     df3    var myflags.2
     df4    var myflags.3
    '---------------------INIT VARIABLE VALUE
    GOTO START
    MYINIT:
    BSR = 0
    TICKS = 0
    freqs1 = 128
    freqs2 = 256
    freqs3 = 512
    freqs4 = 1023
    duty1 = 0
    duty2 = 0
    duty3 = 0
    duty4 = 0
    display = 0
    MYFLAGS = 0
    '-------------------A/D setup
    adcon0 = %00000001
    adcon1 = %11100000
    define ADC_BITS 10
    '-------------------10uS interrupt setup
    DEFINE INTHAND _TimeBase
    PIR1.1 = 0
    PIE1.1 = 1        ; Enable Timer2 interrupts
    INTCON.6 = 1      ; enable PEIE
    INTCON.7 = 1      ; enable GIE
    T2CON = %00000100 ; Setup Timer2 AND SET PRESCALE TO 1:1. @32Mhz THE Interrupt
    PR2 = 39'                 FOR TMR2 WILL BE 10uSec
    '---------------------start of program
    START:
       GOSUB MYINIT
    MAIN:
     adcin 0,freqs1
    '-------------------------led1 math
        if ticks>duty1 then
            led1 = 0
            led1 = 1
        if freq1 > freqs1 then
            if df1 then
                duty1=duty1+1
                duty1=duty1-1
            if duty1=100 then df1=0
            if duty1=0 then df1 = 1
            freq1 = 1
     adcin 1,freqs2
    '------------------------led2 math
        if ticks>duty2 then
            led2 = 0
            led2 = 1
        if freq2 > freqs2 then
            if df2 then
                duty2=duty2+1
                duty2=duty2-1
            if duty2=100 then df2=0
            if duty2=0 then df2 = 1
            freq2 = 1
    adcin 2,freqs3
    '------------------------led3 math
    if ticks>duty3 then
            led3 = 0
            led3 = 1
        if freq3 > freqs3 then
            if df3 then
                duty3=duty3+1
                duty3=duty3-1
            if duty3=100 then df3=0
            if duty3=0 then df3 = 1
            freq3 = 1
     adcin 3,freqs4
    '---------------------------led4 math
    if ticks>duty4 then
            led4 = 0
            led4 = 1
        if freq4 > freqs4 then
            if df4 then
                duty4=duty4+1
                duty4=duty4-1
            if duty4=100 then df4=0
            if duty4=0 then df4 = 1
            freq4 = 1
        GOTO MAIN
    '-----------------------ISR
    TimeBase:
        BSR = 0
        portb = display ' update led's
        freq1 = freq1 +1
        freq2 = freq2 +1
        freq3 = freq3 +1
        freq4 = freq4 +1
        if ticks >99 then
         ticks = 0
         ticks = ticks+1
        pir1.1 = 0          ' clear interrupt
    @ RETFIE
    All comments welcome. I did this all software (no hardware PWM) as I thought it would be more fun.
    Thanks for the contest RMTEO! Sorry I seem to be the only one entering.
    -Bert
    May 2007
    Yes, it will be interesting to see how it works!
    Aug 2010
    Maryland, USA
    Well I am done at work today, so home I go and hopefully get this put together and running.
    Then to figure out about posting video - always something new and fun
    -Bert
    Aug 2010
    Maryland, USA
    OK, I have my working do-hicky video'ed. Anybody have any suggestions how to get it from my iphone4 to here?
    I know how to upload it to facebook, but what good is that?
    -Bert
