Heres my code so far. It appears to work as needed, but thus far I have only tested it with a sim. I will try and put the hardware together tonight and test it in real time.
' Name : RMTEO Contest 2.pbp
' Compiler : PICBASIC PRO Compiler 2.6A
' Assembler : MPASM
' Target PIC : 16F1947
' Hardware : RMTEO Contest
' Oscillator : internal
' Keywords :
' Description : PICBASIC PRO program to drive 4 LED's at independent speeds
' adjustable from 4 pot's. fade from 0-100-0% for each cycle
' Configure ports
ANSELA = %00001111 'port A 0-3 analog 4-7 digital
ANSELE = %00000000 'port E all digital
ANSELF = %00000000 'port F all digital
ANSELG = %00000000 'port G all digital
CM1CON0 = %00000000 'No comparaters
CM1CON1 = %00000000
CM2CON0 = %00000000
CM2CON1 = %00000000
' preload latches before setting direction
LATB = %00000000
LATC = %00000000
LATD = %00000000 'LED's 0 for red, 1 FOR GREEN should start red
LATF = %00000000 ' low nibble is drive enable. 1 disables
LATG = %00000000
' I/O direction
TRISA = %00001111'x,x,x,x,p3,p2,p1,p0
TRISB = %00000000'x,x,x,x,led3,led2,led1,led0
TRISC = %00000000'UNUSED
TRISD = %00000000'UNUSED
TRISE = %00000000'UNUSED
TRISF = %00000000'UNUSED
TRISG = %00000000'UNUSED
'REMOVE THIS LINE IF NOT SETTING THE CONFIGS IN CODE SPACE
@ __config _CONFIG1,_FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
@ __config _CONFIG2,_WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_OFF & _LVP_OFF ;_BORV_25
'------------------Internal osc setup
OSCCON = %11110000 'clock is 8 meg. turn on PLL for 32 meg clock
DEFINE OSC 32
DEFINE NO_CLRWDT 1
'Variables
'Port assignments
'------------------port B
'---------------------words
freqs1 var word
freqs2 var word
freqs3 var word
freqs4 var word
freq1 var word
freq2 var word
freq3 var word
freq4 var word
'---------------------Bytes
TICKS VAR BYTE
display VAR BYTE
duty1 VAR BYTE
duty2 VAR BYTE
duty3 VAR BYTE
duty4 VAR BYTE
myflags var byte
'---------------------Bits
led1 var display.0
led2 var display.1
led3 var display.2
led4 var display.3
df1 var myflags.0
df2 var myflags.1
df3 var myflags.2
df4 var myflags.3
'---------------------INIT VARIABLE VALUE
GOTO START
MYINIT:
BSR = 0
TICKS = 0
freqs1 = 128
freqs2 = 256
freqs3 = 512
freqs4 = 1023
duty1 = 0
duty2 = 0
duty3 = 0
duty4 = 0
display = 0
MYFLAGS = 0
'-------------------A/D setup
adcon0 = %00000001
adcon1 = %11100000
define ADC_BITS 10
'-------------------10uS interrupt setup
DEFINE INTHAND _TimeBase
PIR1.1 = 0
PIE1.1 = 1 ; Enable Timer2 interrupts
INTCON.6 = 1 ; enable PEIE
INTCON.7 = 1 ; enable GIE
T2CON = %00000100 ; Setup Timer2 AND SET PRESCALE TO 1:1. @32Mhz THE Interrupt
PR2 = 39' FOR TMR2 WILL BE 10uSec
'---------------------start of program
START:
GOSUB MYINIT
MAIN:
adcin 0,freqs1
'-------------------------led1 math
if ticks>duty1 then
led1 = 0
led1 = 1
if freq1 > freqs1 then
if df1 then
duty1=duty1+1
duty1=duty1-1
if duty1=100 then df1=0
if duty1=0 then df1 = 1
freq1 = 1
adcin 1,freqs2
'------------------------led2 math
if ticks>duty2 then
led2 = 0
led2 = 1
if freq2 > freqs2 then
if df2 then
duty2=duty2+1
duty2=duty2-1
if duty2=100 then df2=0
if duty2=0 then df2 = 1
freq2 = 1
adcin 2,freqs3
'------------------------led3 math
if ticks>duty3 then
led3 = 0
led3 = 1
if freq3 > freqs3 then
if df3 then
duty3=duty3+1
duty3=duty3-1
if duty3=100 then df3=0
if duty3=0 then df3 = 1
freq3 = 1
adcin 3,freqs4
'---------------------------led4 math
if ticks>duty4 then
led4 = 0
led4 = 1
if freq4 > freqs4 then
if df4 then
duty4=duty4+1
duty4=duty4-1
if duty4=100 then df4=0
if duty4=0 then df4 = 1
freq4 = 1
GOTO MAIN
'-----------------------ISR
TimeBase:
BSR = 0
portb = display ' update led's
freq1 = freq1 +1
freq2 = freq2 +1
freq3 = freq3 +1
freq4 = freq4 +1
if ticks >99 then
ticks = 0
ticks = ticks+1
pir1.1 = 0 ' clear interrupt
@ RETFIE
All comments welcome. I did this all software (no hardware PWM) as I thought it would be more fun.
Thanks for the contest RMTEO! Sorry I seem to be the only one entering.
