Test
Results 1 to 7 of 7
Thread: Test
    Default Re: Test
    Thanks Joe, I will try that.
    But the pretty little icons like the movie strip in the post/edit area create the (video)yourlinkhere(/video) insert, and that's what didn't work anymore. I wonder if there is a way to edit that?
    Thanks though, I will start using that. But there are probably a lot of other posts that are now non functional or at least non readable. Bummer....
    Walter
    Default Re: Test
    Walter
    You are preachin' to the quire Walter, I am a big time HTML fan, had to learn it for eBay but this is not my show, so I do as the Big Dog says or I stay on the porch, but like you said maybe those Icons properties can be changed to insert VB Code instead of HTML.
    Feb 2011
    Default Re: Test
    test posting
    Feb 2011
    South Carolina, USA
    Default Re: Test
    test
