Test
Results 1 to 7 of 7
Thread: Test
    Feb 2011
    Michigan, USA
    Default Test
    testing inserting code........
    wsave var byte bankA system	'saves W
    ssave var byte bankA system	'saves STATUS
    fsave var word bankA system	'saves FSR0
    Default no embeded video, no html
    test video embeding
    http://www.youtube.com/v/PFVfjWyK9vs
    Edit: Not very embedded....
    It looks like taking away html, also takes away embedded video. I rather liked those functions.
    Default Re: Test
    use the VB code tags like in this example : http://www.picbasic.co.uk/forum/misc...bbcode#imgcode
    WE moderators will probably have to go back in history and edit a lot of posts so things will continue to work as many people have used HTML forever. Here is Your link from above:
    Default Re: Test
    Thanks Joe, I will try that.
    But the pretty little icons like the movie strip in the post/edit area create the (video)yourlinkhere(/video) insert, and that's what didn't work anymore. I wonder if there is a way to edit that?
    Thanks though, I will start using that. But there are probably a lot of other posts that are now non functional or at least non readable. Bummer....
    Walter
    Default Re: Test
    Walter
    You are preachin' to the quire Walter, I am a big time HTML fan, had to learn it for eBay but this is not my show, so I do as the Big Dog says or I stay on the porch, but like you said maybe those Icons properties can be changed to insert VB Code instead of HTML.
    Feb 2011
    Default Re: Test
    test posting
    Feb 2011
    South Carolina, USA
    Default Re: Test
    test
