example code for DS1337
Results 1 to 26 of 26
    TONIGALEA's Avatar
    TONIGALEA Guest
    Question example code for DS1337
    Hello Folks,
    i really do need your help on this one as i have being strugling
    for the the past few days .
    Here is what i am trying to do.
    i want to use the DS1337 to display Time and date which i have
    managed to do as i upgraded from ds1307 .
    The part i struglling with is the alarm part as i haven't used this
    before .
    i want to set the alarm intb which i connected a led to when the
    after 5 minutes
    How do i check to know the alarm time is up ?
    i have tried everything (i know) with no joy so if anyone has
    used this Ds1337 please give me a helping hand
    Toni
    DEFINE LOADER_USED 1 ' uses a bootloader
    Include "Modedefs.Bas"
    Define OSC 20
    clear
    ' Setup Hardware for uart
    DEFINE HSER_BAUD 115200
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    DEFINE LCD_DREG PORTD ' Use Portd for LCD Data
    DEFINE LCD_DBIT 4 ' Use Upper(4) 4 bits of Port
    ' PORTD-4 thru PORTD-7 connects to
    ' LCD DB4 thru LCD DB-7 respectively
    DEFINE LCD_RSREG PORTE ' PORTE for RegisterSelect (RS) bit
    DEFINE LCD_RSBIT 0 ' PORTE-0 pin for LCD's RS line
    DEFINE LCD_EREG PORTE ' PORTE for Enable (E) bit
    DEFINE LCD_EBIT 1 ' PORTE-1 pin for LCD's E line
    DEFINE LCD_BITS 4 ' Using 4-bit bus
    DEFINE LCD_LINES 2 ' Using 2 line Display
    DEFINE LCD_COMMANDUS 2000 ' Command Delay (uS)
    DEFINE LCD_DATAUS 50 ' Data Delay (uS)
    @ device pic16F877, XT_osc, wdt_off, pwrt_on, protect_off
    '** DEFINE LCD Control Constants **
    I CON 254 ' Control Byte
    Clr CON 1 ' Clear the display
    Line1 CON 128 ' Point to beginning of line 1
    Line2 CON 192 ' Point to beginning of line 2
    ' Clock Defines
    DS_SCL VAR PORTC.3 ' I2C clock pin
    DS_SDA VAR PORTC.4 ' I2C data pin
    RTC CON %11010000 ' RTC device address (byte addressing)
    'Setting the RTC so we can get out 1Hz tick output
    ' -------------- RTC definitions -----------------
    SecReg CON $00 ' seconds address (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
    MinReg CON $01 ' minutes address (00 - 59)
    HourReg CON $02 ' hours address (01 - 12) or (00 - 23)
    DayReg CON $03 ' day address (1 - 7)
    DateReg CON $04 ' date address (01 - 28/29, 30, 31)
    MonthReg CON $05 ' month address (01 - 12)
    YearReg CON $06 ' year address (00 - 99)
    Alm1sec CON $07 ' Alarm 1 seconds address (00 - 59)
    Alm1min CON $08 ' Alarm 1 minutes address (00 - 59)
    Alm1hr CON $09 ' Alarm 1 hours address (01 - 12) or (00 - 23)
    Alm1Day CON $0A ' Alarm 1 day address (1 - 7)
    Alm2min CON $0B ' Alarm 2 minutes address (00 - 59)
    Alm2hr CON $0C ' Alarm 2 hours address (01 - 12) or (00 - 23)
    Alm2Day CON $0D ' Alarm 2 day address (1 - 7)
    ContReg CON $0E ' control register
    StatusReg CON $0F ' STATUS register
    RTCflag CON 0 ' RTC flag (location 0 of internal EEPROM)
    RTCset VAR BIT ' bit to check if RTC has been set
    cntrl CON %00000110 ' sets the SQW/OUT to 1Hz pulse, logic level low
    'Sta CON %00000000
    ' The variable below holds the values entered:
    ' entered by the user
    sec VAR BYTE ' seconds
    MINs VAR BYTE ' minutes
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    date VAR BYTE ' date
    mon VAR BYTE ' month
    yr VAR BYTE ' year
    'ALARM VARIABLES
    A_MINs VAR BYTE ' minutes
    A_hr VAR BYTE ' hours
    ' Initialise Hardware
    ADCON1=%00000111
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    LCDOut I,Clr:Pause 30
    LCDOut I,Line1+2," RTC TEST "
    LCDOut I,Line2+2,"..Power On.. !!"
    GoSub SetTimeAndDate
    ' Main Program Loop
    Loop:
    I2CRead DS_SDA, DS_SCL, RTC, SecReg, [sec,MINs,hr,day,date,mon,yr]
    I2CRead DS_SDA, DS_SCL, RTC, Alm2min,[A_mins,A_hr]
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    LCDOut I,Line1,"Time: ",HEX2 hr, ":", HEX2 MINs, ":", HEX2 sec
    'LCDOut I,Line2,"Date : ",HEX2 date,"-",HEX2 mon,"-",HEX2 yr
    LCDOut I,Line2,"Alarm: ",HEX2 A_hr, ":", HEX2 A_MINs
    Pause 500 ' Allow Time for user to view
    GoTo Loop
    SetTimeAndDate:
    yr=0:date =0:mon =0:day=0:hr=0:mins=0:sec=0
    ' The constants below set the RTC to: 16:30:00 on 13-08-2004
    yr=$04
    mon=$08
    date=$13
    hr=$16
    sec=$00
    mins=$30
    'SET ALARM FOR 16:35:00
    A_hr=$16
    A_mins=$35
    I2CWrite DS_SDA, DS_SCL, RTC, SecReg,[sec,mins,hr,day,date,mon,yr,cntrl]
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, Alm2min,[A_mins,A_hr,cntrl]
    Pause 10
    TONIGALEA's Avatar
    TONIGALEA Guest
    Do i have to read the status register using 12C command
    or just read the value of the register ?
    i tried to see if bit 1 is set .
    i did it as below but its i just get the value of the register as
    %00001111 and it dosen't change when the time gets to the
    alarm time.
    Define OSC 20
    clear
    ' Clock Defines
    'Alarm 1
    'Alarm2
    'set interupt on INTB
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    yr VAR BYTE ' year
    STAD VAR BYTE
    'ALARM VARIABLES
    ADCON1=%00000111
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    ' Main Program Loop
    Loop:
    pause 10
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    LCDOut I,Line2,"STATUS ",BIN8 StatusReg
    GoTo Loop
    SetTimeAndDate:
    ' The constants below set the RTC to: 16:30:40 on 13-08-2004
    yr=$04
    mon=$08
    date=$13
    hr=$16
    sec=$40
    mins=$30
    'SET ALARM FOR 16:31:00
    A_hr=$16
    A_mins=$31
    'Set the Time
    Pause 10
    'Set the Alarm 1 Time
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, StatusReg,[$00,cntrl]
    PAUSE 10
    Toni
    TONIGALEA's Avatar
    TONIGALEA Guest
    Question
    i am now trying to use the INTA but i still get the same thing
    the pin doeen't pull low when the time time matchs that of the
    alarm.
    Am i doing anything right at all ?
    i have followed the data sheet as below
    http://www.allic.net/resource/ds1337.pdf
    Toni
    Define OSC 20
    clear
    ' LCD DEFINES
    ' Clock Defines
    ' -------------- RTC Address definitions -----------------
    'Alarm 1 Address definitions
    'Alarm 2 Address definitions
    cntrl CON %00000101 ' sets the SQW/OUT to 1Hz pulse, logic level low
    'set interupt on INTB (From pg 9 of data sheet)
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    yr VAR BYTE ' year
    'ALARM1 VARIABLES
    A1sec VAR BYTE ' seconds
    A1MINs VAR BYTE ' minutes
    A1hr VAR BYTE ' hours
    A1day VAR BYTE ' day
    ADCON1=7
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    ' Main Program Loop
    Loop:
    I2CRead DS_SDA, DS_SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
    pause 10
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    LCDOut I,Line2,"Alarm: ",HEX2 A1hr, ":", HEX2 A1MINs, ":", HEX2 A1sec
    GoTo Loop
    SetTimeAndDate:
    A1sec=0:A1MINs=0:A1hr=0: A1day=0
    yr=$04
    mon=$08
    date=$13
    day=$01
    hr=$16
    sec=$40
    mins=$30
    A1hr=$16
    A1MINs=$31
    A1sec=$0
    A1day=$13
    'Set the Time
    I2CWrite DS_SDA, DS_SCL, RTC, SecReg,[sec,mins,hr,day,date,mon,yr]
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC,Alm1sec,[A1sec,A1MINs,A1hr,A1day]
    Pause 10
    'A1sec.7=0
    'A1MINs.7=1
    'A1hr.7=1
    'A1day.7=1
    'Set DT/DT bit 6 of alarm reg to date by writting 0 to it
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC,Alm1Day ,[$01]
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[%00000110]
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, StatusReg,[$00]
    PAUSE 10
    Hi Toni,
    I just looked at the DS1337 datasheet, and it looks like you need to write to bit 7 in all of the alarm1 registers to configure the alarm1 mask bits.
    A1hr=$16 ' = %00010110
    A1MINs=$31 ' = %00110001
    A1sec=$0 ' = %00000000
    A1day=$13 ' = %00010011
    Without setting bits A1M1, A1M2, A1M3, A1M4 and bit 6 in DY/DT registers your alarm output should only happen when Date, Hours, Minutes and Seconds match.
    Refer to Table 2. ALarm Mask Bits in the datasheet. If I'm interpreting the datasheet correctly, to have the alarm trigger when seconds match you would need to add 128 to whatever values you're writing to A1M2 (minutes), A1M3 (hour) and A1M4 (day/date).
    See if this works for triggering alarm1 when seconds match. I've just added 128d to each of your previous values below A1hr.
    ' A1hr=$16 ' = %00010110
    ' A1MINs=$31 ' = %00110001
    ' A1sec=$0 ' = %00000000
    ' A1day=$13 ' = %00010011
    A1hr=%00010110
    A1MINs=%10110001
    A1sec=%10000000
    A1day=%10010011
    This looks like an interesting RTC. I just ordered a few samples to tinker with. Maybe I can offer more help with a code example or two when I have one to mess with.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    TONIGALEA's Avatar
    TONIGALEA Guest
    EXCELLENT Bruce
    Works like a dream
    toni
    Santana's Avatar
    Santana Guest
    Hello Bruce & Toni
    i need your help in triggering the alarm on the DS1337
    i connected led to pin 3 of the RTC but each time the alarm time is reachDEFINE LOADER_USED 1 ' uses a bootloader
    Define OSC 20
    clear
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    ' LCD DEFINES
    ' Clock Defines
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    yr VAR BYTE ' year
    'ALARM1 VARIABLES
    ADCON1=7
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    LCDOut I,Line1+2," DS1337 TEST "
    ' Main Program Loop
    Loop:
    pause 10
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    GoTo Loop
    SetTimeAndDate:
    yr=$04
    mon=$08
    date=$13
    day=$01
    hr=$16
    sec=$40
    mins=$30
    'A1hr=$16
    'A1MINs=$31
    'A1sec=$0
    'A1day=$01
    A1hr=%00010110
    A1MINs=%10110001
    A1sec=%10000000
    A1day=%10010011
    'Set the main Time
    Pause 10
    Pause 10
    Pause 10
    PAUSE 10
    ed the led still stays ON
    could you see where i am going wrong
    All the Best
    Santana
    Are you clearing the alarm flag in the Status register after servicing the alarm?
    -Bruce
    tech at rentron.com
    Santana's Avatar
    Santana Guest
    Yes Bruce
    i do that in the main loop
    Define OSC 20
    clear
    ' LCD DEFINES
    ' Clock Defines
    cntrl CON %00000011 ' sets the SQW/OUT to 1Hz pulse, logic level low
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    yr VAR BYTE ' year
    'ALARM1 VARIABLES
    ADCON1=7
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    ' Main Program Loop
    Loop:
    pause 10
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    I2CWrite DS_SDA, DS_SCL, RTC, StatusReg,[%00000000]' clear status reg<------
    PAUSE 10
    GoTo Loop
    SetTimeAndDate:
    yr=$04
    mon=$08
    date=$13
    day=$01
    hr=$16
    sec=$40
    mins=$30
    A1hr=$16
    A1MINs=$31
    A1sec=$0
    A1day=$01
    'A1hr=%00010110
    'A1MINs=%10110001
    'A1sec=%10000000
    'A1day=%10010011
    'Set the main Time
    Pause 10
    Pause 10
    Pause 10
    PAUSE 10
    OK I see that in your second version. In the first you cleared it only on power-up when the GoSub SetTimeAndDate was used.
    Are you driving the LED directly from the alarm output pin or using a transistor?
    -Bruce
    tech at rentron.com
    Santana's Avatar
    Santana Guest
    No Bruce
    i connected as below:
    5v I----/\/\/\/\/\----- alarm1(pin 3 of ds1337)
    | | 470R
    \/ led
    --- gnd
    Is there anyone else who has used this RTC, please help if u can
    Best Regards
    Santana's Avatar
    Santana Guest
    Basically i connected a 10k pullup resistor to 5v then connected the led from pin 3 through a 470R resistor to ground
    Isn't the alarm pin "MAX" output limited to 3mA...?
    That may explain why it's not working properly when you attempt to directly drive your LED.
    Have you tried removing the LED, and testing the alarm output with a meter or logic probe? Or using a transistor to drive your LED?
    -Bruce
    tech at rentron.com
    Santana's Avatar
    Santana Guest
    yes i have done that
    i removed the led and just left the the 10k pull up resistor and then monitored this on a scope but its never pulled down.
    but i did find someexample code on maxins web site the problem
    is that its written in C
    so i am just trying to figure out what the program is doing
    http://www.maxim-ic.com/appnotes.cfm...te_number/3300
    All The Best
    Santana's Avatar
    Santana Guest
    This code now whats thanks to you bruce
    when the main time match the alarm time an interupt is generated on INTA (PIN 3)
    my led goes low then back high .
    all the time does not match the led is high
    Very Best Regards
    Define OSC 20
    clear
    ' LCD DEFINES
    ' Clock Defines
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    yr VAR BYTE ' year
    'ALARM1 VARIABLES
    ADCON1=7
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
    Pause 1000
    ' Main Program Loop
    Loop:
    pause 10
    ' Read Ds1337
    ' Display Section
    LCDOut I,Clr
    PAUSE 10
    GoTo Loop
    SetTimeAndDate:
    yr=$04
    mon=$08
    date=$13
    day=$01
    hr=$16
    sec=$40
    mins=$30
    'SET ALARM FOR 16:31:50
    A1hr=$16
    A1MINs=$31
    A1sec=$50
    A1day=$13
    'Set the main Time
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[$20]
    Pause 10
    PAUSE 10
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[5]
    Pause 10
    Mar 2009
    Colorado
    Question Ported to 18F4550...why it doesn't work?
    Quote Originally Posted by Santana View Post
    Attempted to adapt your code to the 18F4550 as listed below. Interestingly, the LED I have on Pin3 is low all the time and doesn't go high when the time should be matching the A1 alarm time. Can't figure out why this is or why the alarm doesn't work. Would you please take a look at my code & see if you can see where I am going wrong? Thanks! Will list code in another post since this one exceeds character limits.
    Mar 2009
    Colorado
    Arrow Here is the code
    Quote Originally Posted by jellis00 View Post
    Here is code:
    INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
    ASM ; 18F2550/4550, 8mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    '**--SETUP FOR USING 2x16 LCD THAT IS INSTALLED IN EASYPIC6
        '( commented out during testing of DS1337 operations)
      ' LCD DEFINES FOR USE WIH 2x16 LCD
        'DEFINE LCD_DREG PORTB       ' Use PortB for LCD Data
        'DEFINE LCD_DBIT 0           ' Use lower(4) 4 bits of PortB
                                    ' PORTB.0 thru PORTB.3 connects to
        'DEFINE LCD_RSREG PORTB      ' PORTB for RegisterSelect (RS) bit
        'DEFINE LCD_RSBIT 4          ' PORTB.4 pin for LCD's RS line
        'DEFINE LCD_EREG PORTB       ' PORTB for Enable (E) bit
        'DEFINE LCD_EBIT 5           ' PORTB.5 pin for LCD's E line
        'DEFINE LCD_BITS 4           ' Using 4-bit bus
        'DEFINE LCD_LINES 2          ' Using 2 line Display
        'DEFINE LCD_COMMANDUS 5000   ' Command Delay (uS)
        'DEFINE LCD_DATAUS 200       ' Data Delay (uS)
      ' DEFINE LCD Control Constants
        'I       CON 254           ' Control Byte
        'Clr     CON 1             ' Clear the display
        'Line1   CON 128           ' Point to beginning of line 1
        'Line2   CON 192           ' Point to beginning of line 2
    '**SETUP FOR USING DS1337 Real Time Clock-
    ' Aliased Variables for CLock
        Alarm1      VAR PORTB.4     ' Output of Alarm1 signal
        Alarm2      VAR PORTB.5     ' Output of Alarm2 signal
        DS_SCL      VAR PORTB.1     ' I2C clock pin
        DS_SDA      VAR PORTB.0     ' I2C data pin
        RTC         CON %11010000   ' RTC device write address(byte addressing)
        'contrl     CON %00000000    ' Starts oscillar, sets the SQW/OUT to
                                    ' 1Hz pulse, no Alarm interrupt enabled.
        'contrl      CON %00000001   ' Starts oscillator, sets the SQW/OUT to
                                    ' 1 HZ pulse, & enables INTA interrupt from
                                    ' A1F.
                                    ' w/ logic level low (see data sheet pg 10)
        'contrl     CON %00000010    ' Starts oscillator, sets the SQW/OUT to
                                    ' 1 HZ pulse, enables INTA interrupt from
                                    ' A2F.
        contrl     CON %00000011    ' Starts the oscillator, sets the SQW/OUT
                                    ' to 1 Hz, enables INTA interrupt from A2F
                                    ' or INTA interrupt from A1F.
        'contrl     CON %000xx100   ' Starts oscillator, no interrupts enabled.
        'contrl     CON %000xx101   ' Starts oscillator, enables INTA interrupt
                                    ' from A1F.
        'contrl     CON %000xx110   ' Starts oscillator, enables INTB interrupt
                                    ' from A2F.
        'contrl     CON %00000111   ' Starts oscillator, enables INTA interrupt
                                    ' from A1F or INTB from A2F.
    ' Alias of Clock register addresses
       ContReg     CON $0E         ' CONTROL register address
       StatusReg   CON $0F         ' STATUS register address
    ' Clock Variables
        hr          VAR BYTE  ' hours
        day         VAR BYTE  ' day
        yr          VAR BYTE  ' year
    'ALARM1 VARIABLES
    'ALARM2 VARIABLES
        A2MINs      VAR BYTE  ' minutes
        A2hr        VAR BYTE  ' hours
        A2day       VAR BYTE  ' day
    ' Initialize Hardware
        'Set registers
          TRISA =%00000000
          TRISB =%00000000
          TRISC =%00000000
          TRISD =%00000000
          TRISE.0 = 0
          TRISE.1 = 0
          TRISE.2 = 0
          INTCON2.7 = 0
        ' Initialize Display
        ' Display functions commented out due to RB0 & RB1 conflict with I2C
          'Pause 1000                         ' Delay to let LCD start up
          'LCDOut I,CLR:Pause 50              ' Clear Display
          'LCDOut I,Line1+2," RTC TEST "      ' Display "RTC TEST" on 1st line
          'Pause 500
          'LCDOut I,Line2+2,"..Power On.. !!" ' Display "Power on" on 2nd line
          'Pause 1000
    ' Main Program Loop
        ' Read the current time and ALARM settings from the DS1337
            Pause 10
            I2CREAD DS_SDA, DS_SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
            Pause 10
            I2CRead DS_SDA, DS_SCL, RTC, Alm2min,[A2MINs,A2hr,A2day]
            pause 10
        ' Display Time and ALARM2 settings
            'LCDOut I,Clr:Pause 50
            'LCDOut I,Line1,"Time: ",HEX2 hr, ":", HEX2 MINs, ":", HEX2 sec
            'PAUSE 500
            'LCDOut I,Line2,"Alarm: ",HEX2 A2hr, ":", HEX2 A2MINs, ":", HEX2 $0
            'Pause 500     ' Allow Time for user to view
        I2CWrite DS_SDA, DS_SCL, RTC, StatusReg,[$00] ' Clear STATUS register
        PAUSE 10
        GoTo Main
    ' START LIST OF SUBROUTINES
    'DisplayTest:       'Commented out during test of DS1337 code
        'LCDOut I,Line1+2," TEST "           ' Display "TEST" on 1st line
        'PAUSE 500
        'Pause 1000
        'RETURN
    SetTimeAndDate:
    ' Initialize variables to 0
        A1sec=0:A1MINs=0:A1hr=0:A1Day=0
        A2MINs=0:A2hr=0:A2day=0
    ' The constants below set the RTC to: 16:30:00 on 11-28-2009
        yr=$09
        mon=$11
        date=$28
        day=$02
        hr=$16
        mins=$30
        sec=$00
    'Define ALARM1 FOR 16:31:00 & to alarm once per second
      ' (A1xxx + $80 or A1xxx + 128d sets bit 7 in AIM1,A1M2,A1M3,A1M4 for 1Hz)
        A1hr   = $16 + $80  '$16 + $80 = $96 = 150d = %10010110
                            'Bit6 must be 0 for 24 hour clock
        A1MINs = $31 + $80  '$31 + $80 = $B1 = 177d = %10110001
        A1sec  = $00 + $80  '$00 + $80 = $80 = 128d = $10000000
        A1day  = $28 + $80  '$28 + $80 = $A8 = 168d = $10101000
                            'DY/_DT Bit6 = 0 for using Day of month alarm
    'Define ALARM2 FOR 16:32:00 'Commented out during DS1337 testing of 1Hz
        'A2hr=$16
        'A2MINs=$32
        'A2day=$28          'DY/_DT Bit6 = 0 for using Day of month alarm
    'Set the main Time
        Pause 10
        I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[%00000001] 'Clears INTCN, RS1
                                                  '& RS2 to enable 1Hz pulse &
                                                  ' INTA interrupt.
        Pause 10
        ' Sets Alarm1 once per second
        Pause 10
        'I2CRead DS_SDA, DS_SCL, RTC, Alm2min,[A2MINs,A2hr,A2day]
        Pause 10
    'Set the Alarm 2 Time   ' Commented out during test of DS1337 1Hz
        'I2CWrite DS_SDA, DS_SCL, RTC,Alm2min,[A2MINs,A2hr,A2day,contrl]
        'Pause 10
        ' Sets Alarm2 once per second
            'A2MINs.7   =1 for A2M2 = 1
            'A2hr.7     =1 for A2M3 = 1
            'A2day.7    =1 for A2M4 = 1
        I2CWrite DS_SDA, DS_SCL, RTC,Alm2min,[A2MINs,A2hr,A2day]
        Pause 10
        I2CWrite DS_SDA, DS_SCL, RTC,Alm2Day ,[$01]
        Pause 10
        'I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[contrl]
        Pause 10
        PAUSE 10
    Mentor, Ohio
    Smile
    Hi Jellis,
    I only have a few minutes before I need to go to work but I use the DS1337 quite a bit and this is all I use to set the time information and to display it. Nothing else and it works great. I will check back tonight when I get home.
    SetTimeAndDate:
        yr=0:date =0:mon =0:day=0:hr=0:mins=0:sec=0     'Clear RTC variables
        A1sec=0:A1MINs=0:A1hr=0:A1day=0
        A2MINS=0:A2hr=0:A2day=0
        yr=$08                  'This section sets the RTC Variables
        mon=$06
        date=$02
        day=$01
        hr=$19
        mins=$20
        sec=$30
        A1hr=$10
        A1MINS=$00
        A1SEC=$00
        A1day=%10000000
        A2hr=$22
        A2MINS=$00
        A2day=%10000000
        Pause 10
        wRITE 5,1       'Write TO eeprom DST flag value (0 = EST  1 = DST)
            pause 20
        I2CWrite SDA, SCL, RTC, SecReg,[sec,mins,hr,day,date,mon,yr] '**Set the main Time
            Pause 20
        I2CWrite SDA, SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day] '**Set Alarm1 Time
            Pause 20
        I2CWrite SDA, SCL, RTC, Alm2min,[A2MINs,A2hr,A2day] '**Set Alarm2 Time
           Pause 20
        I2CWrite SDA, SCL, RTC, StatusReg,[%00000000]  '**Clear Status Register
            PAUSE 20
        I2CWrite SDA, SCL, RTC, ContReg,[%00000111]   '**Set Control Register for Alarm1 & Alarm2 outputs separately
            Pause 20
    '   This routine resets the status register after an alarm event
    Clear_Status:
        I2CWrite SDA, SCL, RTC, StatusReg,[%00000000]  'Reset Alarm output from DS1337
            PAUSE 20
    Display_Time:
        B2 = 0
        I2CRead SDA, SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]           '**Get current time
            pause 20
        I2Cread SDA, SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]              '**Get Alarm1 Time
            Pause 20
        I2Cread SDA, SCL, RTC, Alm2min,[A2MINs,A2hr,A2day]                    '**Get Alarm2 Time
            serout2 LCD,Baud,[I,Clr]
            serout2 LCD,Baud,[I,Line1," ",hex2 mon,"/",hex2 date,"/",hex2 yr,"  ",HEX2 hr,":",HEX2 MINs,":",Hex2 sec]
            Serout2 LCD,Baud,[I,Line2,"Alarms: ",HEX2 A1hr,":",hex2 A1MINs," ",Hex2 A2hr,":",Hex2 A2MINs]
    HTH,
    BobK
    Mentor, Ohio
    Smile
    Hi Jellis,
    I finally got a chance to look at your program. You have the pins of PortB setup for the LCD and you are also using PortB4. & 5 for the RTC alarms and PortB.0 and 1 for the I2C connections. You need to change them and set the RTC connections on a different Port.
    BobK
    Mar 2009
    Colorado
    Thumbs down Made changes...new code still doesn't work w/ DS1337
    Quote Originally Posted by BobK View Post
    Thanks, BobK. I studied your code you posted and made some changes in my code to reflect what I saw. I have listed my latest code below. Also added a DEFINE OSC 48 statement that was pointed out to me by someone else as needed since I am using 48 MHz CPU clock derived from the 96 MHz clock for a USB interface I will also be adding to this code at later time.
    I also notice an anomally in my breadboard setup of the DS1337 circuit when I connect my oscilloscope to the SQW/INTB output:
    1) When power is applied to the DS1337 circuit but the code is erased from my controlling 18F4550 MCU, I see a 32.7787kHz clock signal on my oscilloscope at the SQW output of the DS1337.
    2) When I then program the 18F4550 the clock signal on SQW output disappears (flat line at 0 volts).
    This appears to be opposite to what should be happening. The clock should appear at SQW when the MCU is programmed, time has been set and DS1337 is clocking....this isn't happening.
    I also checked the INTA output to see if the Alarm1 was happening 30 seconds after programming and setting the DS1337 time, and it isn't happening either.
    Any ideas what may be causing all this?
    DEFINE OSC 48
    ;--- if you un-comment these, you must comment the ones in the .inc file--
    '**--SETUP FOR USING 2x16 LCD THAT IS INSTALLED IN EASYPIC6----------
      ' LCD DEFINES FOR USE WIH 2x16 LCD..commented out during testing
      ' DEFINE LCD Control Constants **
    '**-------------SETUP FOR USING DS1337 Real Time Clock------------------
           'contrl     CON %00011001    ' Sets RS1 & RS2,
                                    ' clears INTCN to enable Alarm1 & 3.2768kHz
                                    ' outputs separately.
    ' Clock Variables
        hr          VAR BYTE  ' hours
        day         VAR BYTE  ' day
        yr          VAR BYTE  ' year
    'ALARM1 VARIABLES
    'ALARM2 VARIABLES
        'Set registers
          TRISA =%00000000
          TRISB =%00000000
          TRISC =%00000000
          TRISD =%00000000
          TRISE.0 = 0
          TRISE.1 = 0
          TRISE.2 = 0
          INTCON2.7 = 0
        ' Initialize Display    ' commented out during DS1337 testing
          'Pause 500
          'PAUSE 1000
    ' Main Program Loop
            I2CRead DS_SDA, DS_SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]
            Pause 20
            Pause 20
            'I2CRead DS_SDA, DS_SCL, RTC, Alm2min,[A2MINs,A2hr,A2day] ' No Alarm2 during test
            'PAUSE 20
        ' Display Time and ALARM2 settings on the LCD display 'No LCD during test
        GoTo Main
    End     ' Insure program stops if reaches here
        'PAUSE 500
        'Pause 1000
        'RETURN
    SetTimeAndDate:
    ' Initialize clock variables to 0
        yr=0:date =0:mon =0:day=0:hr=0:MINs=0:sec=0
    ' The BCD constants below set the RTC to: 19:20:30 on 06-02-2008
        yr=$08
        mon=$06
        date=$02
        day=$01
        hr=$19
        MINs=$20
        sec=$30
    'Define ALARM1 FOR 19:21:00 & to alarm when hours, minutes, & secs match.
        ' This requires AIM1=AIM2=AIM3=0 and AIM4=1
        ' (A1xxx + $80 or A1xxx + 128d sets bit 7 in AIM1,A1M2,A1M3,A1M4)
        A1hr   = $19        ' for AIM1 = 0
        A1MINs = $21       'for AIM2 = 0
        A1sec  = $00        'for AIM3 = 0
        A1day  = $01 + $80  '$01 + $80 = $81 = 129d = $10000001 for AIM4 = 1
    'Define ALARM2 FOR 19:22:00 'Commented out during DS1337 testing of 1Hz
        'A2hr=$19
        'A2MINs=$22
        'A2day=$01          'DY/_DT Bit6 = 0 for using Day of month alarm
    'Set the main Time
        I2CWrite DS_SDA, DS_SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]
        Pause 20
    'Set the Alarm1 Time
        Pause 20
    'Set the Alarm2 Time   ' Alarm2 Commented out during testing
        'Pause 20
    ' Clear STATUS and set CONTROl registers
        I2CWrite DS_SDA,DS_SCL,RTC,StatusReg,[$00] ' Clear STATUS register
        PAUSE 20
        I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[%00011001]' Starts the oscillator, sets the SQW/OUT, enables INTA
        Pause 20
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  3. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  4. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
