Free Project - 245 LED Display
Page 1 of 6 12345 ... LastLast
Results 1 to 40 of 222
    T.Jackson's Avatar
    T.Jackson Guest
    Lightbulb Free Project - 245 LED Display
    I realize that with my time here thus far I have offered little in terms technical assistance, PIC Basic snippets and so on.
    So here's a nice BIG fish for everyone to cut their teeth on. A 245 LED, PC-programmable moving message display. Near-final cut, early last year the project was prototyped on two large PCBs and performed quite well. It's mandatory that high-intensity LEDs are used because the duty cycle is only around 2.8% for each column in the multiplex scheme. (Do NOT recommend expanding the display with more columns, the design is at its limits as is)
    The component count is quite immense. This includes a 16f628, 24LC256 EEPROM, Max RS232, Decade Counters - 4017 variety, tonne of common passives, it'll take a couple of solid days work to put together. I can't offer the PCB layout sorry.
    The zip file download includes schematics, micro controller source and Windows-based source written in Visual Basic 5.0, plus compiled executable. You will need the Virtual machine runtime DLL for the executable. This can be either msvbvm50.dll or msvbvm60.dll which are both freely obtainable.
    Best Regards,
    Trent Jackson
    Apr 2006
    New Hampshire USA
    Smile Nice Work!
    Hey Trent,
    Thanks for the nice upload. You have included a lot of detailed information. We can learn a lot from the project. Interesting.
    -Adam-
    T.Jackson's Avatar
    T.Jackson Guest
    Smile No problem
    I have also included a copy of the draft article - contains a modest amount of technical theory for the project. Sorry if some of you find it to be a bit of a hard read, it hasn't been proof read or edited, only been read by myself once or twice. In a technical sense I believe it to be accurate however.
    I do sincerely hope that someone finds the project of interest, quite a fair bit of my time was poured into its development. The software was written in a matter of just a couple of days, but the overall hardware design did take some considerable time. It was intended to be published as a full scale project in the Silicon Chip magazine. Unfortunately however it won't ever go to print. Too expensive to build, too quirky to assemble, for a project like this to be successful it needs a double sided through-hole plated PCB a long with LED modules - not 245 individual LEDs.
    All told, to make matters even more difficult, you can buy something like this pre assembled for under $100. It's just never gonna be this cheap for a KIT. But on the flip side of the coin, there is a nice learning aspect with building a big and useful project like this.
    Trent Jackson
    Apr 2007
    Hi Trent Thank you very much for posting your project. Its verrrry interesting project and I want to build one for myself.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    It's definitely worth building. Wish I still had my prototype. It was never returned to me.
    T.Jackson's Avatar
    T.Jackson Guest
    Smile
    Turns out I will be getting my prototype returned, so I can offer technical support to those keen on building it.
    Mar 2006
    INDIA
    I build this circuit with only one 5X7 led display ( Col 1,2,3,4,5 ), But not working. Is it necessary to built all 7 display ?
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by precision View Post
    Can you be a bit more specific - what exactly have you done & what's not working?
    As is, without great modification, it would be next to useless with just 35 LEDs.
    Mar 2006
    INDIA
    My controller circuit is same, But i connect only one 5x7 dot matrix display to IC3 ( cd4017)
    T.Jackson's Avatar
    T.Jackson Guest
    I see. Are you able to successfully upload a message from the Windows software to the EEPROM? If so, do any of the LEDs come on?
    (You need to describe exact symptoms - theoretically, because each character is actually 5x7, I guess the circuit should show a quick flicker of single characters on 35 LEDs. There would be noticeable pauses in between. In other words, yes I believe it should do something with just 35 LEDs.
    Mar 2006
    INDIA
    How i confirm that i successfully upload a message from the Windows software to the EEPROM?
    I also using 24c04 instead of 24c256,
    will you upload eny video of working display ?
    Are display something look like This video ?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Do you realize that the 24c04 is technically different to the 24c256? You can't just whack in the 24c04 and hope for the best - it won't work without modifying the software. The 24c04 is cumbersome to work with compared to the 24c256. Byte sized addressing and bank switching complicate a relatively simple need.
    Apr 2007
    Smile
    Greetings Trent,
    I am now starting to build your project, I'm on stage one building 4017 sequencer. I have some question, is it possible to extend it for more characters, as of now it has seven character i want to extend it for more characters. can you please guide or give some example on how to do it. Thanks in advance....
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by Dazheng View Post
    Greetings Trent,
    I don't recommend cascading anymore sections. The duty cycle is extremely low as it is. About 2.5% for each column. What this all means is that the LEDs won't be bright enough if more columns are added.
    If you want to build a really huge display with a 100 or so columns, your best bet would be to use a few PIC16f877's. Break it into 4 sections - 25 columns for ea controller. The display will be nice & bright this way. Big job!
    The hardest part will be in the software, making sure that ea section is properly synchronized with minimal latency. Shuffling data between ea section. On second thought - it's a masive job to do properly.
    T.Jackson's Avatar
    T.Jackson Guest
    Post Pictures of prototype
    I just scanned in a few pics of the original prototype - thought I'd upload them.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1563&d=1177470983" align="left">
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1564&d=1177471027">
    Not bad for a single sided PCB huh?
    Apr 2007
    Smile
    WOW... Cool and awesome design. Trent is it possible for you to feature here your PCB layout? I know how hard you work for it, just a humble and simple request... Thanks in advance.
    T.Jackson's Avatar
    T.Jackson Guest
    Unfortunately I can't offer the PCBs. Main reason, the Protel libraries that I used
    aren't mine. They are owned by Silicon Chip publications.
    T.Jackson's Avatar
    T.Jackson Guest
    Post How do they do it?
    <pre>
    Here you can buy one pre-made that's bigger, better and brighter for less money. Like I said before - DIY is history...
    </Pre>
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1572&stc=1&d=117757599 2">
    <pre>
    Few years back something like this would have cost many hundreds of dollars
    </pre>
    ismael b.'s Avatar
    ismael b. Guest
    Smile Scanner Pcb
    HELLO TRENT
    The OTHER SIDE Of the PCB is POSSIBLE SCANNEAR WHERE THEY ARE the COMPONENTS (CD4017, pic16f628, etc). OPPOSING SIDE OF THE COMPONENTS.
    DEBTOR,
    ISMAEL BRATTI BRAZIL
    T.Jackson's Avatar
    T.Jackson Guest
    Picture far right shows the main controller board with all associated digital circuitry. Suggest taking a closer look.
    Far left - the display board which houses all 245 LEDs a long with column drivers
    (Q1 - Q35). The display board is stacked on top of the controller board and wired accordingly. (see schematic) <br/>
    T.Jackson's Avatar
    T.Jackson Guest
    Post Missing Dependency File
    Someone has just brought to my attention that there's a missing dependency file in the download. This file is mscomm32.ocx and is required for serial communications. Unfortunately I can't include this in the download because I"m not licensed to do so.
    You may obtain it here:
    http://www.2ocx.com/show.php?ocx=mscomm32.ocx
    <br/>
    Apr 2007
    Talking
    Did you make a movie or something of the display working so we can see how it looks when ready? Mine is almost done!
    May 2006
    Kedah, Malaysia
    Quote Originally Posted by T.Jackson View Post
    Best Regards,
    Trent Jackson
    Trent Jackson,
    I am really interested with your project but can you please post the code here?
    I want to see the code and try to understand it.
    That is the best way for me to understanding your design.
    If cannot then fine.
    Thanks in advance.
    Ops sorry I just found the code here.
    Sorry for not looking the file properly.
    I will try this and ask you if I have any question.
    T.Jackson's Avatar
    T.Jackson Guest
    Post It's all in the download
    Everything is in the d/l - if you have any queries then just post them here.
    Apr 2007
    Question still not running right :(
    Dear Trent, i have recently installed Win XP on my comp and copyed MSCOMM32.OCX in sys32 (VB not installed) ; the aplication runs but when i press "program messege to eeprom" button, i get an Communications error "Port already in use or doesn't exist ; Chose a different port " but the com1 is free; what do i do?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Apart from suggesting that you try another comm port, it's hard-to-say because everything works fine on my end. I have Win XP with service pack 2. If there was a problem MSCOMM32.OCX, the program wouldn't run at all. So you can rule that out.
    May 2007
    Post Dear Jackson
    I have build my led matrix from the start to finish. and i have some problems... I finaly programmmeed the PIC and when i connect the 5V and the 12V and the Serial Port, and when i bush the button for program LED it doesen`t stay ON (lighting).I start the VB program to sent EEPROM the informations but when finished nothing happens. I have a link with the sheme that i construct... i hope you can help me... THX.. I will wait for your answer.
    http://www.zamfirelu.org/lm.jpg
    Mar 2006
    INDIA
    What is this ?
    Why you mount all 14 capacitor in one place ? and there are no capacitor between PIC's VCC and GND.
    T.Jackson's Avatar
    T.Jackson Guest
    Post Learn electronics first
    I'm getting emails left right & center from people telling me about their problems with this thing. It's not a simple project - in my opinion, it requires the constructor to have some sort of formal background with electronics. If you build it, you've gotta be prepared to fault find your mistakes, because you will make them, there's a lot of wires & parts and a whole range of silly little errors that could occur.
    By the way, I noticed on your photograph of the board that all the 0.1uf decoupling caps are banked up together ??? They actually need to be placed as close as possible to the power connections of each chip. (That's why there's so many of them, one for each chip) Knowing this sort of thing is relatively basic electronics and if you aren't aware of simple things like this then I highly discourage you from building it. Sorry - the truth hurts.
    skimask's Avatar
    skimask Guest
    Abso-tively Poso-lutely....the sequence should be: One blinky LED, then 245...
    But, we all know, it usually starts the other way around...
    245 non-blinky LEDs, then back to one non-blinky LED, then on to one blinky LED, then, and only then, do you get 245 blinky LEDs...(well, maybe a few extra steps in between)...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    When I've got some spare time I might write an article describing "basic" electronics and trouble shooting. So anyone that's having difficulty with the project, just put it aside until you've had a chance to read the article. It'll be a while though, I'm actually a full time student at the moment struggling to do a 4yr degree in information technology.
    May 2007
    Default Tell me pls a the possible problem...
    Tell me pls a the possible problem that the board doesen`t work. I connect the entire wires to the pics and capacitor, diodes and rezistors; i change the pic over 3 times, the eeprom 2 times but doesen`t work... i sincerily i need some help.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by magu View Post
    We all 'sincerily' need help...but...100,000+ different things can cause this to fail...
    Wiring faults (go over 100 times and you still miss that ONE wire that's wrong, programmer faults, etc.etc...
    But for one...I see the cap's in the cluster still haven't moved nearer to the chips like suggested earlier!!!
    May 2007
    tell me pls what capacitor do i ha\ve to place and where?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    The caps are the least of your worry. What about the LEDs? You've used common diffused 5mcd types, these won't be bright enough. I clearly made mention of this several times in the article and on the schematic. Unfortunately, I feel, you've bitten off more than you can chew.
    May 2007
    Those are the steps that i should follow?
    1. Install Visualbasic
    2. Connect the board to 5v and 12v
    3. Connect the serial port to board
    4. Start VB program (programing the eeprom)
    5. Push the program button (the led should stay litghing?)
    6. Program the eeprom from VB program
    Those steps are good?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Yes - sounds about right.
    May 2007
    but the problem is that the led doesn`t stay on (lighting). you know what the cause is?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    The purpose of that LED is to give a visual indication that the PIC is indeed receiving data from the PC. It should toggle on/off with every byte received.
    Initially, when the program button is pressed - the LED should be lit, assuming that the TX line from the PC to the PIC is idle (or not connected at all).
    After the PIC receives its first byte - the LED should change states. Upon receiving the second, once again changing states. It should continue to do so until the PC has finished programming it. The LED is of little importance and the message that you program should begin to scroll automatically after successful download.
    T.Jackson's Avatar
    T.Jackson Guest
    Smile A new lease on life for my prototype ...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1693&stc=1&d=118075962 7">
    <hr/>
    The fact of the matter is, after all of this - I honestly have no use for a scrolling marque display. Primarily, the project was only ever attempted in efforts to add to my collection of published projects in the Silicon Chip magazine. As I've stated before, it won't ever being seeing the light of day inside any magazine. So the question for myself was, what do I do with this bloody thing? I put so much time into it, shame to just give it the "heave-ho" in the trash can. After several moments of considerable thought it dawned on me to yes, you guessed it - turn it into a clock! Why not?, its plenty big enough, at least for a 12hr one that is. Unfortunately, however though, its a couple of columns shy for a 24hr clock, at least for me it is, since I concluded that (5x7) digits are mandatory. Much in between just doesn't quite look right. So here it is, source code and all for those of you who have built this thing and would like to turn it into a clock. I also wrote a simple VB app that is used to set the time. (See screen shot) The VB source and everything else is in the download.
       Include "modedefs.bas"    ' Include serial modes
       Define OSC 4              ' 4MHz crystal
       CMCON      = 7            ' All digital
       OPTION_REG = %10000111    ' TMRO prescale = 256
       TRISA      = %00010000    ' All outputs except RA4
       TRISB      = %00000000    ' All outputs ...
       INTCON.5   = 1            ' Enable TMR0 interrupts
       INTCON.2   = 0            ' Reset overflow flag
       on interrupt goto Clock
       '// Chrs (0-9) stored in on-chip E²PROM
       data @0,62,65,65,65,62   ' 0
       data @5,64,127,66,0,0    ' 1
       data @10,70,73,81,97,66  ' 2
       data @15,54,73,73,65,34  ' 3
       data @20,16,127,18,20,24 ' 4
       data @25,49,73,73,73,39  ' 5
       data @30,50,73,73,73,62  ' 6
       data @35,3,5,9,113,1     ' 7
       data @40,54,73,73,73,54  ' 8
       data @45,62,73,73,73,38  ' 9
       data @50,0,0,0,0,0       ' Space
       data @55,8,8,8,8,8       ' Colm
       Row_Data     VAR BYTE    ' Contains one column worth of a chr at a time
       Column_Scan  VAR BYTE    ' Current col that's active
       Digit_Pos    Var byte    ' E²PROM address pointing to current col data
       Digit_Loc    VAR Byte    ' Start E²PROM address for new chr
       Colm         var byte    ' Blinking colm ...
       Counter      VAR Word    ' Time keeping counter
       Secs_Digit1  var byte    ' Secs (1's)
       Secs_Digit2  var byte    ' Secs (10's)
       Mins_Digit1  var byte    ' Mins (1's)
       Mins_Digit2  var byte    ' Mins (10's)
       Hrs_Digit1   var byte    ' Hrs (1's)
       Hrs_Digit2   var byte    ' Hrs (10's)
       Clock_Cols   VAR PORTB.6
       Reset_Cols   VAR PORTB.5
       ROW1         VAR PORTA.2
       ROW2         VAR PORTA.3
       ROW3         VAR PORTB.4
       ROW4         VAR PORTB.3
       ROW5         VAR PORTB.0
       ROW6         VAR PORTB.2
       ROW7         VAR PORTB.1
       Prog_Button  VAR PORTA.4
       TX_To_PC     var PORTB.7
       Counter     = $7A12
       TMR0        = 0
       Column_Scan = 0
       Digit_Pos   = 0
       Secs_Digit1 = 0
       Secs_Digit2 = 0
       Mins_Digit1 = 0
       Mins_Digit2 = 0
       Hrs_Digit1  = 2
       Hrs_Digit2  = 1
       Colm        = 0
       Reset_Cols  = 1
       Reset_Cols  = 0
    LED_Display:                                         ' Scan cols & output row dat
       @ incf _Column_Scan, 1                            ' Inc col
       @ incf _Digit_Pos, 1                              ' Inc chr pos (0-4)
       Row_Data = 0                                      ' Reset
       IF Column_Scan = 37 THEN Column_Scan = 1          ' ^
       select case Column_Scan
          case 1                                         ' Secs (1's)
             Digit_Pos = 0                               ' Reset
             Digit_Loc = (Secs_Digit1 * 5)               ' Set loc
          case 6                                         ' Space
             Digit_Pos = 0
             Digit_Loc = 50
          case 7                                         ' Secs (10's)
             Digit_Pos = 0
             Digit_Loc = (Secs_Digit2 * 5)
          case 12,13                                     ' Colm
             Digit_Pos = 0
             IF Colm = 2 then                            ' Blink colm
                Digit_Loc = 55
                Digit_Loc = 50
          case 14                                        ' Mins (1's)
             Digit_Pos = 0
             Digit_Loc = (Mins_Digit1 * 5)
          case 19
             Digit_Pos = 0                               ' Space
             Digit_Loc = 50
          case 20                                        ' Mins (10's)
             Digit_Pos = 0
             Digit_Loc = (Mins_Digit2 * 5)
          case 25,26                                     ' Colm
             Digit_Pos = 0
             IF Colm = 2 then
                Digit_Loc = 55
                Digit_Loc = 50
          case 27                                        ' Hours (1's)
             Digit_Pos = 0
             Digit_Loc = (Hrs_Digit1 * 5)
          case 32                                        ' Space
             Digit_Pos = 0
             Digit_Loc = 50
          case 33                                        ' Hours (10's)
             Digit_Pos = 0
             if Hrs_digit2 = 0 then                      ' Show either 1 or nothing
                Digit_Loc = 50                           ' (12hr time only)
                Digit_Loc = 5
       end select
       read Digit_loc + Digit_Pos, Row_Data              ' Fetch portion of digit
                                                         ' One column at a time
       '// Switch off all rows before advancing the counters
       ROW1 = 0
       ROW2 = 0
       ROW3 = 0
       ROW4 = 0
       ROW5 = 0
       ROW6 = 0
       ROW7 = 0
       '// Prog button pressed?
       if Prog_Button = 0 then GOTO Set_Time
       '// Clock cascaded counters
       Clock_Cols = 1
       Clock_Cols = 0
       '// Logically AND data with row bit values and write to port asynchronously
       IF Row_Data & 1  THEN ROW1 = 1
       IF Row_Data & 2  THEN ROW2 = 1
       IF Row_Data & 4  THEN ROW3 = 1
       IF Row_Data & 8  THEN ROW4 = 1
       IF Row_Data & 16 THEN ROW5 = 1
       IF Row_Data & 32 THEN ROW6 = 1
       IF Row_Data & 64 THEN ROW7 = 1
       GOTO LED_Display                                  ' Loop back
       disable                                           ' Disable interrupts here
    Clock:                                               ' Time keeping routine
       INTCON.2 = 0                                      ' Clear TMR0 overflow flag
       Counter = Counter - $1000                         ' Dec
       IF Counter < $1000 THEN                           ' 0.5 sec elapsed?
          if colm = 2 then                               ' 1 sec elapsed
             @ incf _Secs_Digit1, 1                      ' Inc secs first digit
             If Secs_digit1 = 10 Then                    ' Secs first digit = 10?
                @ incf _Secs_Digit2, 1                   ' Inc 10's of secs
                Secs_digit1 = 0                          ' Reset first digit
                If Secs_digit1 = 0 then                  ' Has one minute elapsed?
                   if Secs_digit2 = 6 Then
                      @ incf _Mins_Digit1, 1             ' Inc mins first digit
                      Secs_digit2 = 0                    ' Reset secs second digit
                      if Mins_digit1 = 10 then           ' 10 mins elapsed?
                         @ incf _Mins_Digit2, 1          ' Inc 10's of mins
                         Mins_digit1 = 0                 ' Reset first mins digit
                         If mins_digit1 = 0 then         ' 60 mins elapsed?
                            if mins_digit2 = 6 Then      '
                               @ incf _Hrs_Digit1, 1     ' Inc hours first digit
                               mins_digit2 = 0           ' Reset mins second digit
                               if Hrs_digit1 = 10 then   ' 10 hours elapsed?
                                  Hrs_digit1 = 0         ' Set hours digits to show 10
                                  Hrs_Digit2 = 1
                               EndIf
                               if Hrs_digit1 = 3 then    ' 12 hours elapsed?
                                  if hrs_digit2 = 1 then '
                                     Hrs_digit1 = 1      ' Reset hours to 1
                                     Hrs_digit2 = 0      '
             Colm = 0                                    ' Colm off ...
          endif                                          '
          Counter = Counter + $7A12                      ' Reset counter with 0.5s
          @ incf _Colm, 1                                ' Toggle colm every 0.5s
       resume
    Set_Time:
       low Prog_Button                                   ' Set LED
       SERIN TX_To_PC, N2400, ["@"], Hrs_Digit2, Hrs_Digit1, Mins_Digit2, Mins_Digit1, Secs_Digit2, Secs_Digit1
       input Prog_Button                                 ' Resume as input for prog but
       Reset_Cols  = 1                                   ' Reset 4017 counters
       Reset_Cols  = 0                                   '
       Column_Scan = 0                                   ' Reset to start of scan
       goto LED_Display                                  ' Start clock
    Trent Jackson
    <hr/>
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1694&stc=1&d=118076150 6" align="right">
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 2
    Last Post: - 14th July 2008, 23:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
