Free Project - 245 LED Display
Results 1 to 40 of 222
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by Dazheng View Post
    Greetings Trent,
    I have some question, is it possible to extend it for more characters, as of now it has seven character i want to extend it for more characters. can you please guide or give some example on how to do it. Thanks in advance....
    I don't recommend cascading anymore sections. The duty cycle is extremely low as it is. About 2.5% for each column. What this all means is that the LEDs won't be bright enough if more columns are added.
    If you want to build a really huge display with a 100 or so columns, your best bet would be to use a few PIC16f877's. Break it into 4 sections - 25 columns for ea controller. The display will be nice & bright this way. Big job!
    The hardest part will be in the software, making sure that ea section is properly synchronized with minimal latency. Shuffling data between ea section. On second thought - it's a masive job to do properly.
    T.Jackson's Avatar
    T.Jackson Guest
    Post Pictures of prototype
    I just scanned in a few pics of the original prototype - thought I'd upload them.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1563&d=1177470983" align="left">
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1564&d=1177471027">
    Not bad for a single sided PCB huh?
    Apr 2007
    Smile
    WOW... Cool and awesome design. Trent is it possible for you to feature here your PCB layout? I know how hard you work for it, just a humble and simple request... Thanks in advance.
    T.Jackson's Avatar
    T.Jackson Guest
    Unfortunately I can't offer the PCBs. Main reason, the Protel libraries that I used
    aren't mine. They are owned by Silicon Chip publications.
    T.Jackson's Avatar
    T.Jackson Guest
    Post How do they do it?
    <pre>
    Here you can buy one pre-made that's bigger, better and brighter for less money. Like I said before - DIY is history...
    </Pre>
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1572&stc=1&d=117757599 2">
    <pre>
    Few years back something like this would have cost many hundreds of dollars
    </pre>
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
