Free Project - 245 LED Display
Results 1 to 40 of 222
    Apr 2007
    Hi Trent Thank you very much for posting your project. Its verrrry interesting project and I want to build one for myself.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    It's definitely worth building. Wish I still had my prototype. It was never returned to me.
    T.Jackson's Avatar
    T.Jackson Guest
    Smile
    Turns out I will be getting my prototype returned, so I can offer technical support to those keen on building it.
    Mar 2006
    INDIA
    I build this circuit with only one 5X7 led display ( Col 1,2,3,4,5 ), But not working. Is it necessary to built all 7 display ?
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by precision View Post
    Can you be a bit more specific - what exactly have you done & what's not working?
    As is, without great modification, it would be next to useless with just 35 LEDs.
    Mar 2006
    INDIA
    My controller circuit is same, But i connect only one 5x7 dot matrix display to IC3 ( cd4017)
    T.Jackson's Avatar
    T.Jackson Guest
    I see. Are you able to successfully upload a message from the Windows software to the EEPROM? If so, do any of the LEDs come on?
    (You need to describe exact symptoms - theoretically, because each character is actually 5x7, I guess the circuit should show a quick flicker of single characters on 35 LEDs. There would be noticeable pauses in between. In other words, yes I believe it should do something with just 35 LEDs.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 2
    Last Post: - 14th July 2008, 23:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
