Free Project - 245 LED Display
Results 1 to 40 of 222
    May 2007
    tell me pls what capacitor do i ha\ve to place and where?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Quote Originally Posted by magu View Post
    The caps are the least of your worry. What about the LEDs? You've used common diffused 5mcd types, these won't be bright enough. I clearly made mention of this several times in the article and on the schematic. Unfortunately, I feel, you've bitten off more than you can chew.
    May 2007
    Those are the steps that i should follow?
    1. Install Visualbasic
    2. Connect the board to 5v and 12v
    3. Connect the serial port to board
    4. Start VB program (programing the eeprom)
    5. Push the program button (the led should stay litghing?)
    6. Program the eeprom from VB program
    Those steps are good?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Yes - sounds about right.
    May 2007
    but the problem is that the led doesn`t stay on (lighting). you know what the cause is?
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    The purpose of that LED is to give a visual indication that the PIC is indeed receiving data from the PC. It should toggle on/off with every byte received.
    Initially, when the program button is pressed - the LED should be lit, assuming that the TX line from the PC to the PIC is idle (or not connected at all).
    After the PIC receives its first byte - the LED should change states. Upon receiving the second, once again changing states. It should continue to do so until the PC has finished programming it. The LED is of little importance and the message that you program should begin to scroll automatically after successful download.
    T.Jackson's Avatar
    T.Jackson Guest
    Smile A new lease on life for my prototype ...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1693&stc=1&d=118075962 7">
    <hr/>
    The fact of the matter is, after all of this - I honestly have no use for a scrolling marque display. Primarily, the project was only ever attempted in efforts to add to my collection of published projects in the Silicon Chip magazine. As I've stated before, it won't ever being seeing the light of day inside any magazine. So the question for myself was, what do I do with this bloody thing? I put so much time into it, shame to just give it the "heave-ho" in the trash can. After several moments of considerable thought it dawned on me to yes, you guessed it - turn it into a clock! Why not?, its plenty big enough, at least for a 12hr one that is. Unfortunately, however though, its a couple of columns shy for a 24hr clock, at least for me it is, since I concluded that (5x7) digits are mandatory. Much in between just doesn't quite look right. So here it is, source code and all for those of you who have built this thing and would like to turn it into a clock. I also wrote a simple VB app that is used to set the time. (See screen shot) The VB source and everything else is in the download.
       Include "modedefs.bas"    ' Include serial modes
       Define OSC 4              ' 4MHz crystal
       CMCON      = 7            ' All digital
       OPTION_REG = %10000111    ' TMRO prescale = 256
       TRISA      = %00010000    ' All outputs except RA4
       TRISB      = %00000000    ' All outputs ...
       INTCON.5   = 1            ' Enable TMR0 interrupts
       INTCON.2   = 0            ' Reset overflow flag
       on interrupt goto Clock
       '// Chrs (0-9) stored in on-chip E²PROM
       data @0,62,65,65,65,62   ' 0
       data @5,64,127,66,0,0    ' 1
       data @10,70,73,81,97,66  ' 2
       data @15,54,73,73,65,34  ' 3
       data @20,16,127,18,20,24 ' 4
       data @25,49,73,73,73,39  ' 5
       data @30,50,73,73,73,62  ' 6
       data @35,3,5,9,113,1     ' 7
       data @40,54,73,73,73,54  ' 8
       data @45,62,73,73,73,38  ' 9
       data @50,0,0,0,0,0       ' Space
       data @55,8,8,8,8,8       ' Colm
       Row_Data     VAR BYTE    ' Contains one column worth of a chr at a time
       Column_Scan  VAR BYTE    ' Current col that's active
       Digit_Pos    Var byte    ' E²PROM address pointing to current col data
       Digit_Loc    VAR Byte    ' Start E²PROM address for new chr
       Colm         var byte    ' Blinking colm ...
       Counter      VAR Word    ' Time keeping counter
       Secs_Digit1  var byte    ' Secs (1's)
       Secs_Digit2  var byte    ' Secs (10's)
       Mins_Digit1  var byte    ' Mins (1's)
       Mins_Digit2  var byte    ' Mins (10's)
       Hrs_Digit1   var byte    ' Hrs (1's)
       Hrs_Digit2   var byte    ' Hrs (10's)
       Clock_Cols   VAR PORTB.6
       Reset_Cols   VAR PORTB.5
       ROW1         VAR PORTA.2
       ROW2         VAR PORTA.3
       ROW3         VAR PORTB.4
       ROW4         VAR PORTB.3
       ROW5         VAR PORTB.0
       ROW6         VAR PORTB.2
       ROW7         VAR PORTB.1
       Prog_Button  VAR PORTA.4
       TX_To_PC     var PORTB.7
       Counter     = $7A12
       TMR0        = 0
       Column_Scan = 0
       Digit_Pos   = 0
       Secs_Digit1 = 0
       Secs_Digit2 = 0
       Mins_Digit1 = 0
       Mins_Digit2 = 0
       Hrs_Digit1  = 2
       Hrs_Digit2  = 1
       Colm        = 0
       Reset_Cols  = 1
       Reset_Cols  = 0
    LED_Display:                                         ' Scan cols & output row dat
       @ incf _Column_Scan, 1                            ' Inc col
       @ incf _Digit_Pos, 1                              ' Inc chr pos (0-4)
       Row_Data = 0                                      ' Reset
       IF Column_Scan = 37 THEN Column_Scan = 1          ' ^
       select case Column_Scan
          case 1                                         ' Secs (1's)
             Digit_Pos = 0                               ' Reset
             Digit_Loc = (Secs_Digit1 * 5)               ' Set loc
          case 6                                         ' Space
             Digit_Pos = 0
             Digit_Loc = 50
          case 7                                         ' Secs (10's)
             Digit_Pos = 0
             Digit_Loc = (Secs_Digit2 * 5)
          case 12,13                                     ' Colm
             Digit_Pos = 0
             IF Colm = 2 then                            ' Blink colm
                Digit_Loc = 55
                Digit_Loc = 50
          case 14                                        ' Mins (1's)
             Digit_Pos = 0
             Digit_Loc = (Mins_Digit1 * 5)
          case 19
             Digit_Pos = 0                               ' Space
             Digit_Loc = 50
          case 20                                        ' Mins (10's)
             Digit_Pos = 0
             Digit_Loc = (Mins_Digit2 * 5)
          case 25,26                                     ' Colm
             Digit_Pos = 0
             IF Colm = 2 then
                Digit_Loc = 55
                Digit_Loc = 50
          case 27                                        ' Hours (1's)
             Digit_Pos = 0
             Digit_Loc = (Hrs_Digit1 * 5)
          case 32                                        ' Space
             Digit_Pos = 0
             Digit_Loc = 50
          case 33                                        ' Hours (10's)
             Digit_Pos = 0
             if Hrs_digit2 = 0 then                      ' Show either 1 or nothing
                Digit_Loc = 50                           ' (12hr time only)
                Digit_Loc = 5
       end select
       read Digit_loc + Digit_Pos, Row_Data              ' Fetch portion of digit
                                                         ' One column at a time
       '// Switch off all rows before advancing the counters
       ROW1 = 0
       ROW2 = 0
       ROW3 = 0
       ROW4 = 0
       ROW5 = 0
       ROW6 = 0
       ROW7 = 0
       '// Prog button pressed?
       if Prog_Button = 0 then GOTO Set_Time
       '// Clock cascaded counters
       Clock_Cols = 1
       Clock_Cols = 0
       '// Logically AND data with row bit values and write to port asynchronously
       IF Row_Data & 1  THEN ROW1 = 1
       IF Row_Data & 2  THEN ROW2 = 1
       IF Row_Data & 4  THEN ROW3 = 1
       IF Row_Data & 8  THEN ROW4 = 1
       IF Row_Data & 16 THEN ROW5 = 1
       IF Row_Data & 32 THEN ROW6 = 1
       IF Row_Data & 64 THEN ROW7 = 1
       GOTO LED_Display                                  ' Loop back
       disable                                           ' Disable interrupts here
    Clock:                                               ' Time keeping routine
       INTCON.2 = 0                                      ' Clear TMR0 overflow flag
       Counter = Counter - $1000                         ' Dec
       IF Counter < $1000 THEN                           ' 0.5 sec elapsed?
          if colm = 2 then                               ' 1 sec elapsed
             @ incf _Secs_Digit1, 1                      ' Inc secs first digit
             If Secs_digit1 = 10 Then                    ' Secs first digit = 10?
                @ incf _Secs_Digit2, 1                   ' Inc 10's of secs
                Secs_digit1 = 0                          ' Reset first digit
                If Secs_digit1 = 0 then                  ' Has one minute elapsed?
                   if Secs_digit2 = 6 Then
                      @ incf _Mins_Digit1, 1             ' Inc mins first digit
                      Secs_digit2 = 0                    ' Reset secs second digit
                      if Mins_digit1 = 10 then           ' 10 mins elapsed?
                         @ incf _Mins_Digit2, 1          ' Inc 10's of mins
                         Mins_digit1 = 0                 ' Reset first mins digit
                         If mins_digit1 = 0 then         ' 60 mins elapsed?
                            if mins_digit2 = 6 Then      '
                               @ incf _Hrs_Digit1, 1     ' Inc hours first digit
                               mins_digit2 = 0           ' Reset mins second digit
                               if Hrs_digit1 = 10 then   ' 10 hours elapsed?
                                  Hrs_digit1 = 0         ' Set hours digits to show 10
                                  Hrs_Digit2 = 1
                               EndIf
                               if Hrs_digit1 = 3 then    ' 12 hours elapsed?
                                  if hrs_digit2 = 1 then '
                                     Hrs_digit1 = 1      ' Reset hours to 1
                                     Hrs_digit2 = 0      '
             Colm = 0                                    ' Colm off ...
          endif                                          '
          Counter = Counter + $7A12                      ' Reset counter with 0.5s
          @ incf _Colm, 1                                ' Toggle colm every 0.5s
       resume
    Set_Time:
       low Prog_Button                                   ' Set LED
       SERIN TX_To_PC, N2400, ["@"], Hrs_Digit2, Hrs_Digit1, Mins_Digit2, Mins_Digit1, Secs_Digit2, Secs_Digit1
       input Prog_Button                                 ' Resume as input for prog but
       Reset_Cols  = 1                                   ' Reset 4017 counters
       Reset_Cols  = 0                                   '
       Column_Scan = 0                                   ' Reset to start of scan
       goto LED_Display                                  ' Start clock
    Trent Jackson
    <hr/>
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1694&stc=1&d=118076150 6" align="right">
    May 2007
    Then tell me a program with o can program the PIC...and tell me pls if it is a setting required when program the PIC
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
