Darrel Taylor
It doesn't surprise me at all that you refuse to follow thru.
That's pretty much your normal approach. Never answer directly, make them look it up in that "Little Green Book". Examples must be modified to work, and I'm not writing it for you.
Sounds like 'Instant Gratification' rules again. Give a guy a simple direct answer for a simple problem and that same guy will be back for more 'cause that person didn't figure out how to read and/or look for something somewhere else.
And just like the way you say how other people's work won't pass by the instructors at the classes you take in the AF.
Because most of the work that I have to do almost ALWAYS involves lives and/or equipment, most of the equipment 'one-off' or 'limited asset' type, or otherwise 'secret squirrel' stuff. You have to agree that the bulk of the work/code/schematics here are done by hobbyists and not people out for a buck or two (although it would be nice), and most likely doesn't have any time constraints placed upon it, therefore, time spent researching a problem, trying to figure it out wouldn't be a bad investment by the end user.
If you were to show your only code examples linked above, to a programming instructor ... well, after he got up off the floor from laughing, he'd write a big red F on the front.
Well, I'm not in any sort of class, I don't have to show my code to an instructor, I don't have to have it pass any others criteria except my own, and my main question at the end of the day is 'Does it work right?'. And besides that, how much 'real world' experience does the average instructor actually have?
So before you start your next "It's in the book" or "if you had read the datasheet". Let's see if you can actually write a program.
Even though you've never seen the stuff in person, you know as well as others probably do, that I've got plenty of working projects out there, both posted on that webpage of mine and otherwise. I don't think I'd still be doing this if I couldn't read a manual or a datasheet. I just discovered these forums a couple of years ago. Before that, nothing, just datasheets and printouts.
Not even a program really, just one simple function that works with PBP. Not chip specific, not version specific, just PBP compatible, that covers what people would need to do to copy a string from Flash. It should also pass those "instructors".
Tell that same thing to the guys at MeLabs and Microchip... Get THOSE guys to make PBP and MPASM compile and assemble an identical copy of the same program, any program, across all of the PIC families, all of the PIC revisions. But since we're talking PBP here, get the guys at MeLabs to write PBP so it'll compile 'BLINKY' so it'll work, first time, across all PIC devices, without the end user having to change around the CONFIG fuses to get 'BLINKY' to work. I mean the most popular answer to a problem here has to be along the lines of 'Set ADCON1 to this or ANSEL to that'. That's nothing new. The answer is in the PBP manual, it's in the datasheets, it's in the FAQ here, and yet we see that same question literally a few times a week. Why hasn't anything been done about that at MeLabs or Microchip (MPASM)? Well, except for the 'new' CONFIG bit in the newer PICs for bringing up A/D ports to digital on reset, which again, is that CONFIG bit set for analog or digital by default?
As the second highest poster on this forum,
Second highest poster? Poster of what? Poster child for colons:?
you really should have at least 1 "Passing" code example.
Passing who's criteria? Yours? Mine? The next noob to register?
