Checksum problem!
Results 1 to 4 of 4
    atomski's Avatar
    atomski Guest
    Default Checksum problem!
    Greetings and salutations
    This is a sequal of this thread:
    http://www.picbasic.co.uk/forum/show...=&threadid=828
    I'll get to the problem asap, but first the code snippet:
    DEFINE OSC 20
    Rx_Data Var Byte[7]
    Rx_Byte Var Byte
    Rx_Bit Var Bit
    Ack Var Bit
    Pulse Var Word
    Csum Var Byte
    Csum_Data Var Byte
    I Var Byte
    w Var Byte
    Goto Start
    Checksum:
    Ack = 0
    FOR i = 0 TO 5
    Csum_Data = Csum_Data + Rx_Byte[i] 'Sum all bytes for checksum
    NEXT i
    Csum = Rx_Data[6]
    IF Csum = Csum_data THEN Ack = 1
    i = 0
    Start:
    Pulse = 0
    PULSIN Rx_Pin, 0, Pulse
    IF Pulse < 290 THEN Start
    Get_Data:
    FOR i = 0 to 6
    FOR w = 0 TO 5
    Pulse = 0
    If Pulse > 80 and Pulse < 120 THEN Rx_Bit = 0
    IF Pulse > 180 AND Pulse < 220 Then Rx_Bit = 1
    Rx_Byte.0 = Rx_bit
    Rx_Byte = Rx_Byte << 1
    NEXT w
    Rx_Data[i] = Rx_Byte >> 1
    NEXT i
    i = 0
    w = 0
    GOSUB Checksum
    GOSUB Send_Data
    GOTO Start
    Now, first thing's first. All my ASCII chars are represented
    with their HEX value - $30 which makes it easier for me to
    use since now all chars are only 6-bits. Less bits = shorter
    over-the-air transmission time. Here's the table:
    Character set
    ASCII NEW NEW Character
    Hex Hex Bin Value
    30 00 000000 0
    31 01 000001 1
    32 02 000010 2
    33 03 000011 3
    34 04 000100 4
    35 05 000101 5
    36 06 000110 6
    37 07 000111 7
    30 08 001000 8
    39 09 001001 9
    3A 0A 001010 : (colon)
    3B 0B 001011 ; (semi-colon)
    3C 0C 001100 < (less than)
    3D 0D 001101 = (equal sign)
    3E 0E 001110 > (greater than)
    3F 0F 001111 ? (question mark)
    40 10 010000 @ (AT symbol)
    41 11 010001 A
    42 12 010010 B
    43 13 010011 C
    44 14 010100 D
    45 15 010101 E
    46 16 010110 F
    47 17 010111 G
    48 18 011000 H
    49 19 011001 I
    4A 1A 011010 J
    4B 1B 011011 K
    4C 1C 011100 L
    4D 1D 011101 M
    4E 1E 011110 N
    4F 1F 011111 O
    50 20 100000 P
    51 21 100001 Q
    52 22 100010 R
    53 23 100011 S
    54 24 100100 T
    55 25 100101 U
    56 26 100110 V
    57 27 100111 W
    58 28 101000 X
    59 29 101001 Y
    5A 2A 101010 Z
    5B 2B 101011 Æ
    5C 2C 101100 Å
    5D 2D 101101 (reserved)
    5E 2E 101110 (reserved)
    5F 2F 101111 (reserved)
    60 30 110000 (space)
    61 31 110001 (reserved)
    62 32 110010 (reserved)
    63 33 110011 (reserved)
    64 34 110100 (reserved)
    65 35 110101 (reserved)
    66 36 110110 (reserved)
    67 37 110111 (reserved)
    68 38 111000 (reserved)
    69 39 111001 (reserved)
    6A 3A 111010 (reserved)
    6B 3B 111011 (reserved)
    6C 3C 111100 (reserved)
    6D 3D 111101 (reserved)
    6E 3E 111110 (reserved)
    6F 3F 111111 (reserved)
    However, here's where my problem lies... When my
    encoder calculates checksum by using the same method
    as described above in the Checksum subroutine, it will
    return a number spaning from %00000000 (if all my
    shifted ASCII chars are $00) to %101111010 (if all my
    shifted ASCII chars are $3F, and the result is a 9-bit
    number). Since, I'm sending only 6-bits per byte, the
    encoder will send only bits 5 to 0 of checksum.
    When I try to reconstruct that in the above subroutine,
    I run into mucho problemas. As long as the checksum falls
    into 6 bits my subroutine works, but if it exceeds 6-bits,
    Csum received won't match Csum_data I get by summing
    6 bytes of data received by the decoder.
    Any ideas on how to solve this, and still keep the 6-bit
    scheme in place?
    Thank you in advance!
    Post
    Hi Vladimir,
    Try keeping everything within 6 bits all the time. Easily done by bitwise anding with $3F. I assume that the two highest bits of Rx_Data[x] is always zero. If not you should do some anding with them too.
    /Ingvar
    Checksum:
    Ack = 0
    FOR i = 0 TO 5
    Csum_Data = Csum_Data & $3F
    NEXT i
    Csum = Rx_Data[6]
    i = 0
    atomski's Avatar
    atomski Guest
    Ingvar,
    Thanks for the reply. Rx_Data[x] bit7 and bit6 are always 0,
    but Rx_Data[x] bit5 and bit4 aren't. As you can see from the
    table, they can be e.g. %00 0000 = 0, %01 0000 = @, %10
    0000 = P or %11 0000 = space. I'll try what you've sugested
    as soon as I get back home from work. TNX!
    atomski's Avatar
    atomski Guest
    Ingvar,
    The ANDing worked just fine. Now I can enter any
    combination of characters and still get away with
    my 6-bit scheme. Thanks!
  1. NMEA CheckSum Routine
    By Tom Gonser in forum Code Examples
    Last Post: - 6th June 2015, 23:24
  2. Checksum
    Last Post: - 24th October 2009, 05:09
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  4. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 23:59
  5. Creating Checksum in PBP
    Last Post: - 16th March 2005, 05:49
