Checksum
Results 1 to 3 of 3
Thread: Checksum
    Default Checksum
    I've just started with PBP and have a checksum issue to solve.
    I have a 12 byte data packet in an ARRAY which I am sending via HSEROUT.
    The receiving hardware expects a checksum and it is calculated thus.
    " There are basically 10 data bytes per message. Before the first is the message type (AA or 87), and after the last is the checksum. You compute it by adding the other 11 bytes, negating that (2's complement), then and'ing by 0x7f. It makes the entire message add to 0 when you and by 0x7f. "
    I had a checksum working in Picaxe basic, but i'm after ideas to help convert it to PBP. My below picaxe code was for a three byte packet not twelve.
    b0 = $E6 ;Calculate Checksum Routine
    b1 = $40
    b2 = b0 + b1 ;Add all bytes of packet together b2 = value + value + value + value etc
    b2 = NOT b2 ;NOT result
    b2 = b2 + 1 ;Add 1 to result
    b2 = b2 AND $7F ;AND result and checksum in b2
    My PBP test Code at present is very limited and just recieves data into an array and squirts it back out again. I need to modify the data in the array, calculate the new checksum and then send it on.
    ' PBP BCM CODE 22/10/09 V.02 4mhz
    @ DEVICE PIC16F88,INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88,PROTECT_OFF
    @ DEVICE PIC16F88,WDT_OFF
    @ DEVICE PIC16F88,PWRT_ON
    @ DEVICE PIC16F88,MCLR_ON
    @ DEVICE PIC16F88,BOD_OFF
    @ DEVICE PIC16F88,LVP_OFF
    @ DEVICE PIC16F88,CPD_OFF
    @ DEVICE PIC16F88,DEBUG_OFF
    @ DEVICE PIC16F88,CCPMX_OFF
    'DEFINE OSC 8 			'Set oscilator speed to 8mHz
    'OSCCON=%01111000 		'8 Mhz
    DEFINE OSC 4 			'Set oscilator speed to 4mHz
    OSCCON =%01100000		'4 Mhz
    DEFINE HSER_BAUD 9600		'Set Baud rate to 9600bps
    DEFINE HSER_BITS 9		'Set to 9 bit mode
    DEFINE HSER_EVEN 1		'Set Even Parity
    DEFINE HSER_CLROERR 1 		'Clear overflow error automatically
    ANSEL = 0 			'ALL DIGITAL
    CMCON = 7 			'COMPARATORS OFF
    INTCON = 0 			'Disable interrupts
    TRISB = %00000100 		'SET PORTB RB2(RX) as input, others to OUTPUT
    TRISA = %11111111 		'SET PORTA AS INPUTS
    DATAIN VAR BYTE[12]		'Define DATAIN as a byte array (12 Bytes)
    loop: 				'Start of Communications Loop
    HSERIN [str DATAIN\12]		'Receive 12 bytes into array DATAIN
    HSEROUT [str DATAIN\12]		'Transmit 12 bytes from array DATAIN
    goto looP			'Goto Loop
    I've done a lot of searching on the forum but i'm on such a steep learning curve with the PBP syntax my head is exploding. I would be grateful for ideas or sample code. Thanks
    OK I've just tried to write some code, does this look right?
    BCMDATA VAR BYTE[12]		'Define BCMDATA as a byte array (12 Bytes)
    Count1 VAR BYTE			'Define Count1 as a byte variable (Used in For/Next Loops)
    CheckSum VAR BYTE		'Define CheckSum as a byte variable
    HSERIN [str BCMDATA\12]		'Receive 12 bytes into array BCMDATA
    Gosub CalcSum			'Gosub CalcSum to Calculate Checksum
    HSEROUT [str BCMDATA\12]	'Transmit 12 bytes from array BCMDATA
    CalcSum:			'Calculate Packet CheckSum Routine
    	For Count1 = 0 to 10	'For Count1 = 0 to 10 (Start 11 byte loop)
    	CheckSum = CheckSum + BCMDATA[Count1]	'Add Bytes
    	Next Count1		'Repeat until 11 bytes added
    	CheckSum = NOT CheckSum	'Not CheckSum
    	CheckSum = CheckSum + 1	'Add 1 to CheckSum
    	BCMDATA[12] = CheckSum AND $7F 'AND result
    	Return			'Return
    I haven't looked at this properly, but just giving it a quick glance, I think you need to zero the variable CHECKSUM before starting the FOR/NEXT loop.
    Thanks I noticed that one later but have left it out so I can call my routine with the packet start byte value pre-loaded into checksum now.
    So I call the routine after loading checksum with either $AA or $87 (My 12 byte packet start byte) I then run the routine on the array and store the checksum in the last byte making twelve in all.
    My main program - onfigs now looks like this. The checksum is commented out at present during some other testing.
    'Main Program Start
    Commloop: 					'Start of Communications Loop
    	HSERIN [WAIT($87), STR BCMDATA\11]	'Wait for packet start $87 then Receive 11 bytes into array BCMDATA
    	'CheckSum = $87				'Load Checksum with packet start byte value
    	'Gosub CalcSum				'Gosub CalcSum to Calculate Checksum
    	HSEROUT [$87,str BCMDATA\11]		'Transmit 12 bytes inc packet start byte $87
    	HSERIN [WAIT($AA), STR BCMDATA\11]	'Wait for packet start $AA then Receive 11 bytes into array BCMDATA
    	'CheckSum = $AA				'Load Checksum with packet start byte value
    	HSEROUT [$AA,str BCMDATA\11]		'Transmit 12 bytes inc packet start byte $AA
    'Data txd/rxd test outputs known values below to check transmission & reception
    	Pause 32				'Pause for 16ms
    	HSEROUT [$AA,$10,$00,$00,$00,$20,$40,$61,$10,$01,$00,$74]		'Transmit 12 bytes
    	pause 32                'Pause for 16ms
    	HSEROUT [$87,$40,$58,$15,$6E,$10,$01,$32,$2F,$2F,$04,$39]		'Transmit 12 bytes
    	goto CommlooP			'Goto Loop
    	BCMDATA[11] = CheckSum AND $7F 		'AND result
    	Return					'Return
  1. NMEA CheckSum Routine
    By Tom Gonser in forum Code Examples
    Last Post: - 6th June 2015, 23:24
  2. Can PBP & 16f88 really do 9600,8,E,1
    Last Post: - 7th November 2010, 13:12
  3. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 23:36
  4. Creating Checksum in PBP
    Last Post: - 16th March 2005, 05:49
  5. Checksum problem!
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 08:21
