writecode - problem - 18F6720
Results 1 to 4 of 4
    Tomasm's Avatar
    Tomasm Guest
    Default writecode - problem - 18F6720
    I use PBP Pro 2.45, MPLAB 6.4, and Pic 18F6720. I want to write and read from code memory. But my small sample program doesnt work:
    x var word
    ERASECODE $5000
    Pause 20
    x=123
    WRITECODE $5000, x
    Pause 20
    READCODE $5000, x
    hserout [hex x]
    hserout puts out "65535" but it should put out "123". When I read with readcode a word from the program- codespace the right content will
    be displayed.
    I disabled all protect- configurationbits.
    Any ideas where my mistake is?
    Dec 2003
    Wichita KS
    Hello Tomasm,
    Check this link out..
    Melanie did a wonderful job with examples
    http://www.picbasic.co.uk/forum/show...ight=writecode
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Tomasm's Avatar
    Tomasm Guest
    Hello Dwayne,
    i know Melanies answer in this thread, but I cant use the PBP mnemonics, because I work with a 18F6720, so I have to use MPASM.
    And the writecode example from Melanie doesnt work with my 18F6720!
    Dear Tomasm, you can use PBP to do your code. MPASM will only translate your .bas file into an .hex file to be place into your PIC.
    better for you to update MPLAB to new version 6.6x
    after that you have to do EXACTLY the following instruction to include PBP into MPLAB. This will work
    http://www.melabs.com/support/mplab.htm
    don't forget to reboot !!!
    many regards.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
