Pic to GSM Phone connection (HSerin problems)
Page 1 of 8 12345 ... LastLast
Results 1 to 40 of 289
    Jan 2004
    Thessaloniki , GREECE
    Question Pic to GSM Phone connection (HSerin problems)
    Hi!
    I am trying a project of remote control (SMS) using 16f628 connected to an Ericsson T10 mobile phone.
    My problem is with the serial communication with the phone
    I have tried everyting from software Serou/Serin to HSERIN/HDEROUT using build-in f628 USART.
    Although Sending AT commands is ok receiving the reply from the phone is very difficult.
    I think the phone response is too uick for picbasic to receive the stirng. What is your opinion. Is it possible from PBP Pro to cath-up the receiving data from the mobile?
    (Using 9600,8,n,1) with no rs232-drivers - with inverted/noninverted modes -the same problem
    Any ideas?
    P.S: I have developed a PDU decoded with the pic. If it works properly I may public the code
    Thank you all Pic-maniacs! )
    mcglacy's Avatar
    mcglacy Guest
    It is difficult to use Ericsson try to use Nokia Phones..
    try to visit this site maybe it can help you..
    www.embedtronics.com
    Mikkel's Avatar
    Mikkel Guest
    Smile SMS and Pics
    Hi I have had the same problem, mobiles are sometimes to fast
    I use the GSM engine TC 35 from siemens they can run Normaly text but run to fast for a pic too.
    so put in a larger crystal (8mhz)
    set up your programmer to HS
    if your settings is 9600 chose 2400 baud because at 8 MHZ it goes to faster
    I use serin and a timeout seqenze so i can find the end of the message
    If your modem can deal with slower speed auto matically
    try to send some AT AT at a lower speed 1200 Baud
    You won't fell the differnce since SMS messages are so short.
    Best regards Mikkel Holm
    I
    I may help you but please give some more details, as what do you expect to receive from the phone and what do you receive?
    Most of the times is a matter of sync problem.
    Feb 2004
    Germany
    I have tried it using a NOKIA Phone and it works fine.
    The Phone is connected to the HW-USART via MAX232
    Baudrate: 9600 8N1
    You need a clock spped of minimum 8MHz
    (I'm using a 12MHz resonator)
    DEFINE OSC 12
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    GSMBUFFER VAR BYTE[16]
    Caller VAR BYTE[13]
    GSMTime VAR BYTE[17]
    'Send SMS Test-Message
    HSerout ["ATZ",13,10]
    Pause 1000
    HSerout ["AT+CMGF=1",13,10] 'Set Text Mode
    Pause 500
    HSerout ["AT+CMGS=",34,"+491232456789",34,",129",13,10]
    Pause 500
    HSerout ["Test-Message",10,13]
    HSerout [26]
    Pause 500
    ' Check for new incomming Messages
    Pause 1000
    Pause 1000
    Loop:
    'List new Messages
    HSerout ["AT+CMGL",13,10]
    ' Read Caller ID, time and 16 CHARs of Message
    ' The timeout value in the HSERIN statement is important, it takes some time before the phone replies to the AT+CMGL command
    HSerin 5000,loop,[wait("UNREAD"),skip 3,STR Caller\13,skip 4,STR GSMTime\17,skip 6, STR GSMBUFFER\16\13]
    ' --- Put your code to output the result here
    ' i.e. LCDOUT . . . .
    Goto Loop:
    There are certainly better ways to do the job, this was just a quick test and it works
    Jan 2004
    Default Tex node support on Nokias
    NavMicroSystems thanks!
    I think I will go for Nokia phone as it would be better to handle!
    Anyway does al Nokia supports Text mode or only PDU format?
    P.S I have a PDU decode routine available -as soon as I will try it out I will make the code available.
    Feb 2004
    Germany
    Default Re: Tex node support on Nokias
    @ bitmaniac
    As far as I know do all NOKIA phones with embedded Modem support the text mode.
    I have successfully tested it on 62xx and 63xx series.
    The TEXT mode is easier to handle than PDU mode and it certainly saves some code space.
    anyway: I am interested in your PDU encoding / decoding routines.
    rgds
    Oct 2003
    Cyprus
    Post Pic to GSM Phone connection (HSerin problems)
    Hi people,
    I had implemented an interface with Ericsson and a 16F628 that worked fine.
    I used a T65 model and pin 4 on the RS232 connector has to be driven high for the phone to accept and issue responces. For other models this can be different. Appart from pin 4, I used 3 more pins, Ground, TX and RX.
    I used PDU mode due to the Ericsson and the fact that, any phone can be interfaced with virtually only hardware modifications.
    I sample of my code is shown below:
    @ DEVICE pic16F628, HS_OSC
    ' ---- High Speed Oscilator
    @ DEVICE pic16F628, WDT_OFF
    ' ---- Watchdog Timer=OFF
    @ DEVICE pic16F628, BOD_ON
    ' ---- Brown-Out Detect
    @ DEVICE pic16F628, LVP_OFF
    ' ---- Low-Voltage Programming=OFF
    @ DEVICE pic16F628, MCLR_OFF
    ' ---- Reset Pin=Internal
    @ DEVICE pic16F628, PWRT_ON
    ' ---- Power-On Timer=Disabled
    @ DEVICE pic16F628, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    @ DEVICE pic16F628, PROTECT_OFF
    ' Program Code Protection
    INCLUDE "modedefs.bas"
    ' ******* Definitions *******
    DEFINE OSC 16 ' Define clock Oscillator Frequency at 16Mhz
    DEFINE HSER_RCSTA 90H ' Enable Hardware USART receive
    DEFINE HSER_TXSTA 24H ' Set Hardware USART parameters
    DEFINE HSER_BAUD 9600 ' Set baud rate to 9600
    define HSER_CLROERR 1
    CMCON=%00000111 ' Make PortA digital
    ' ****** Initialise PORTs ******
    TRISA = %11110000 'Set PORTA status (Low byte=Output, for LEDs)
    TRISB = %11100010 'Set PORTB status
    PORTA = %00000000 ' Initial state of PORT A
    PORTB = %00000000 ' Initial state of PORT B
    ' ****** Variables ******
    TXD VAR PORTA.0 ' Phone not responding
    RXD VAR PORTA.1 ' Transmit to Phone
    error VAR PORTA.2 ' Receive from Phone
    deb var PORTA.3 ' Debugging led
    relay0 VAR PORTB.3 ' First Relay
    relay1 VAR PORTB.4 ' Second Relay
    CALLER var byte[8] ' Callers ID Array
    INSMS VAR BYTE[8] ' Incoming SMS message Array
    cr con 13 ' Carriage Return character
    lf con 10 ' Line Feed character
    j var byte
    goto start ' Jump to Main Program
    ' ****** SUBROUTINE AREA ******
    meminit:
    ' Instract Phone to use it's own memory for storage and SMS manipulations
    TXD = 1 ' Tx LED=ON
    HSerout ["AT+CPMS=",34,"ME",34,44,34,"ME",34,44,34]
    HSerout ["ME",34,cr] ' Command AT+CPMS="ME","ME","ME"
    Pause 600
    TXD = 0 ' TX LED=OFF
    Some other ROUTINES reside here.......
    ' ****** MAIN PROGRAM AREA ******
    Start:
    PAUSE 1000
    TXD = 1 ' Tx LED=ON
    HSerout ["at",cr] ' <----- Check for Phone presence
    RXD = 1 ' Rx LED=ON
    HSerin 400,nophone,[wait ("OK")]
    Pause 500
    TXD = 0 : RXD = 0 ' Tx & Rx LEDs=OFF
    TXD = 1
    hserout ["AT+CMGF=0",cr] ' <----- Initiate PDU Format
    pause 400 ' Not needed for Ericsson Phones
    ' hserout ["ATE0",cr] ' <----- Turn Echo OFF
    ' pause 200
    TXD = 0
    Gosub meminit ' <----- Initialise Phone's SMS memory
    TXD = 1
    hserout ["AT+CSAS",cr] ' <----- SAVE SETTINGS
    PAUSE 400
    TXD = 0
    ' ++++ Read from Phone ++++
    GOSUB meminit
    pause 3000
    TXD = 1
    HSerout ["AT+CMGL=0",cr] ' <----- Read Received and Unread Incoming messages.
    TXD = 0
    pause 2
    RXD = 1
    Hserin 800, msg_old , [wait ("+CMGL:")] ' If no +CMGL then no new SMS was read
    hserin [skip 36, str caller\8 , skip 20, str insms \8]
    RXD = 0
    'GOSUB eepwrite
    gosub meminit ' <----- Initialise Phone's SMS memory
    hserout ["AT+CMGD=1",cr] ' <----- Delete the "read message" (First SMS)
    pause 200
    I do not decode the PDU but I use it ready made All the messages were sent and read from phone via HyperTerminal. The resulting PDU coded message was used. an example is shown below.
    ++++ An Unrecognised command was received ++++
    PAUSE 400
    GOSUB meminit
    TXD = 1 : deb = 1 : PAUSE 500
    HSerout ["at+cmgs=33",cr] ' Intraction to Phone to send SMS in PDU mode
    Pause 500 ' "Unrecognised Command" Message
    HSerout ["0011000B915397490185F80000AA1455B7BC3C7E9FDDE97999 0C1ABEDBEDB09BEC02",26,cr,lf] ' PDU message of 33 bytes.
    I hope that I helped a bit
    Kypros V.
    P.S. If you developed a PDU decoding code I woould appriciate if you share it.
    Mar 2004
    Manila
    hi,
    is there any AT COMMAND to check the time of a nokia 6210.
    thanks,
    brenda
    Feb 2004
    Germany
    Hi Brenda,
    unfortunately there is no such AT-command.
    If your intention is to set an RTC on your PIC-board connected to the Phone you could do the following:
    as soon as you have received a new SMS-message write your RTC-time to some variables.
    now you have got plenty of time to decode the SMS-message.
    The message header contains the time it was delivered by the server.
    comparing this to your RTCs time gives you the offset you need to correct the RTC.
    This is certainly not perfect in terms of accuracy, but far better (+/- 1 min) than the long term accuracy of an RTC with a non-compensated clock.
    rgds.
    Mar 2004
    Manila
    thanks! That was a good idea which I didn't think off. I'll try it today.
    regards,
    Jan 2004
    Default Pic pdu encoding/decoding code
    finally here is the forum linkfor the pdu encoding.decoding routine for anyone that is interested
    http://www.picbasic.co.uk/forum/show...=&threadid=305
    Oct 2003
    Cyprus
    Cool
    Many many thanks bitmaniac.
    Kypros
    Feb 2004
    Germany
    Thanks bitmaniac !
    I'll give it a try this weekend.
    rgds
    Mar 2004
    Manila
    Default Flash SMS
    Anybody knows at command for Flash SMS.. i.e.. recipient will recieve tha sms direct to screen without opening it.
    Thankx!
    Brenda
    Oct 2003
    Cyprus
    Cool
    Hi brenda,
    There is no AT command for this. You have to use PDU mode in order to send FLASH SMS. First you must undertand how PDU works, then you should know that this function is not supported by all phones.
    Try http://www.traud.de/gsm/ and http://www.dreamfabric.com/sms/
    for more information on Flash messaging and PDU mode.
    Kypros
    Mar 2004
    Manila
    hi kypros,
    thanks for the info. I think I have to study Pdu format as what you and everybody recommend. Nice site!!! thanks again!
    brenda
    Mar 2004
    Manila
    Hi kyprus and everybody,
    Well, Its really hard to understand PDU format but I manage to understand it. Now I can send a Flash SMS. Cheers!!!! I found a nice PDU converter by Peter Sandstrom.
    http://www.spaceorbit.net/peter/proj...rk1/index.html
    Another question:
    How about sending Picture message?
    brenda
    Mar 2004
    Default SMS
    I have tried sending a SMS on a nokia 6210 with a 16f84A ( only micro I had at the time) the osc was only at 4MHz. As I was only sending AT commands I thought it would be ok. The sequence seems to hang before the SMS is completed. Has anyone tried this with a 16f84a at 4MHz?
    Oct 2003
    Cyprus
    Hi Darrenmac,
    how do you determine tha the sequence hangs?
    I sugest that you send a simple AT command and capture the answer as a first step.
    In my code example as published is:
    Pause 500
    Just convert it to SEROUT and SERIN commands since 16F84 does not have a hardware USART.
    In the above example, a sent an AT command followed by a Carriage Return character and then waited for 400 ms for the phone to respond with an “OK”. If within the 400 ms there is no answer (meaning that the phone does not respond) then program execution would continue at label “nophone” where I use a small code to indicate phone absence.
    Further to the above, I suggest you test communication at various speeds, baud rates. Try 9600 which is the standard and on unsuccessful results move down to lower speeds.
    You can also check your cable connection or the levels on your RS232 interface. Also check if you need to use True or Inverted mode in your SEROUT lines.
    I haven used the 16F84 but I cannot see any reason why it should not work ok.
    Kypros
    Mar 2004
    Thanks for the advice Kypros, I found the problem to be the lack of a comma. I found the program to be hanging by add in a couple of leds and some toggle commands between at commands.
    I used the debug command instead of the serout as I could not get the serout to work properly for some strange reason.
    Bulman's Avatar
    Bulman Guest
    Hi.
    Where can I find the Nokia protocol? I can't understand what are the AT commands for? Where can I find a comprehensive info about the commands like:
    AT
    AT+CMGF=1
    AT+CMGL
    ATZ
    AT+CMGS
    etc.
    I would like to understand the NavMicroSystems's program, but I can't without the protocol.
    Please give me some usefull links, bacause I would also like to control my PIC with a SMS.
    Feb 2004
    Germany
    GOOGLE:
    NOKIA AT COMMANDS
    and you will find all you need.
    rgds.
    Bulman's Avatar
    Bulman Guest
    Hi NavMicroSystems
    Thanx for the point.
    I still can’t understand some of your ideas, therefore I rewrote your program in a way that I think it should be. I wrote my questions like comments next to the lines which I can’t get. So could you please take a look and answer the questions.
    And do you think that this program could be used with all Nokia phones with embedded modems, or it’s for the 62xx series only?
    DEFINE OSC 20
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 115200
    GSMbuffer var Byte [12]
    Caller var Byte [12]
    GSMtime var Byte [17]
    ‘Check the connection between the phone and PIC works. Should ‘give OK. Instead you’ve used ATZ, why?
    Hserout [“AT”, 13, 10]
    Pause 1000
    HSerout ["AT+CMGF=1", 13, 10] 'Set Text Mode. Answer: OK
    Pause 500
    Hserout [“AT+CMGS=”, 34, “+359888123456”, 34, 13, 10] ‘Answer: >
    ‘Why have you put “,129” in addition. I think it’s not nessesary.
    Pause 500
    Hserout [“Test-message”, 13, 10]
    ‘Terminate the SMS by Control+Z
    ‘Here you send ASCII 26 => SUB. Is it equal with CTRL+Z?
    Hserout [26]
    ‘Answer: +CMGS: 125 - the ord. number of the SMS (0-‘255)
    Pause 500
    HSerout ["AT", 13, 10] ‘Check the connection
    Pause 1000
    Pause 1000
    Loop:
    ‘list new unread messages
    Hserout [“AT+CMGL=”, 34, “REC UNREAD”, 34, 13, 10]
    ‘Optionally: "REC READ", "ALL"
    ‘Or it must be HSerout ["AT+CMGL",13,10] ?
    ‘Answer in 3 lines should look like this:
    ‘+CMGL: 1,"REC UNREAD","+359888123456",,"04/07/21,08:03:05-00"
    ‘Test-message
    ‘OK
    HSerin 5000, Loop, [Wait("UNREAD"), skip 3, STR Caller\12, skip 4, STR GSMTime\17, skip 4, STR GSMbuffer\12]
    ‘You ‘ve written skip 6 before STR GSMuffer\12 but I think it ‘should 'be skip 4? Then you used GSMBUFFER\16\13, which must be 'GSMbuffer\12. Am I right? What \16\13 does mean?
    ‘Delete the processed SMS:
    Hserout [“AT+CMGD=1”, 13, 10]
    Goto Loop
    Feb 2004
    Germany
    @ Bulman
    --> My code example is a working program, have you given it a try?
    --> I have tested it on 62xx and 63xx series,
    --> according to the NOKIA documentation
    --> it should work on any model with embedded modem.
    DEFINE OSC 20
    --> I couldn't establish a reliable connection to the phone faster than 9600
    --> and 9600 is certainly fast enough to transfer those few bytes
    --> You are right, a simple AT would do the same job at this point
    Pause 1000
    Pause 500
    --> "129" is the "TYPE" (See NOKIA AT COMMANDS)
    Pause 500
    Hserout [26]
    --> ASCII 26 is equal to CTRL+Z
    Pause 500
    Pause 1000
    Pause 1000
    Loop:
    --> Lists all unread (new) messages
    --> I'm only interested in new "UNREAD" messages
    --> already processed MSGs have been deleted
    ‘Test-message
    ‘OK
    --> There are two additional bytes to be skipped at the end of the first line (CR LF)
    --> I did want to read the first 16 chars of the received message, --> GSMbuffer\16
    --> See PBP Manual Section 5.30
    --> stop reading if chr(13) is received if no chr(13) read max 16 chars
    --> This is exactly what I would do after the MSG has been processed
    Goto Loop
    regards
    Bulman's Avatar
    Bulman Guest
    Thank you very much NavMicroSystems.
    I'm gonna bye a Nokia and do some test.
    Thanx again.
    Bye.
    Feb 2004
    Germany
    @ Bulman
    before you buy a mobile phone
    you should have a look at at the SIEMENS TC35i GSM Terminal.
    It is more reliable and has more features.
    (i.e. remote reset and remote power on/off)
    The TC35i is available at about 150 EUR (or even less)
    see: siemens.com.
    rgds.
    LazBoy's Avatar
    LazBoy Guest
    Default Hyper Terminal & GSM AT
    I have Nokia 7110 and MBUS/FBUS dual data cable.
    (home made) I can use some Nokia GSM control
    softwares with it. (Oxygen Phone Manager, LogoManager etc)
    But, when I want to use with Hyper Terminal for AT commands,
    the phone does not answer. I am planning for secure use with
    PIC mController. But after PC tests.
    What is the wrong ? Any idea for this ?
    Mar 2004
    sounds like the data lead is working in one mode but not the other. I have 2 seperate cables, the one I use for Logo manager is different from the one I use for sms or interconect connection
    May be if you type the ATE1 command enables the echo?
    LazBoy's Avatar
    LazBoy Guest
    Default Nokia 7110
    I just learned that Nokia 7110 has not an embedded modem.
    A software driver or DLR-3P cable required.
    I am planning to use Siemens C55.
    Mar 2004
    Manila
    Default Restart
    Hello there!
    Anybody knows how to restart a nokia 6210 thru AT COMMAND or PDU format. Logo Manager has a provision for that.
    Thanks in advance
    Brenda
    stu746's Avatar
    stu746 Guest
    Smile
    gonna get a second hand 6210 to have a play at this
    do i need to use a max232 or will i be able to hook straight up to a mobile and just use the serin and serout commands?
    Bulman's Avatar
    Bulman Guest
    Nope. Nokia uses the Fbus. You must bye a RS232-to-Fbus converter, or make your own.
    See this link for additional info:
    http://www.panuworld.net/nuukiaworld...les/basics.htm
    Boyko
    stu746's Avatar
    stu746 Guest
    hi, got a nokia 6210 and a dlr-3p cable
    tried it with hyperterminal with the pc and works fine.
    i tried connecting pins 2,3 and 5 (rx,tx and gnd) to the pic and could not get it to work, i just tried connecting it to the pc with just the 3 pins connected and it would not work?
    any ideas? i thought i only needed to connect the 3 wires?
    Feb 2004
    Germany
    It is correct, to communicate with the phone you only need RX, TX and GND.
    But the Data cable has some embedded logic that is powered from the DB9 connector DTR and/or RTS pin.
    regards
    Ralph
    stu746's Avatar
    stu746 Guest
    so if i connect the dtr pin to 5v it should work?
    Feb 2004
    Germany
    Try it with both RTS and DTR on the data cable connected to +5V.
    If this doesn't work you may need a higher voltage (up to +12V)
    regards
    Ralph
    stu746's Avatar
    stu746 Guest
    not having much luck with this, have u dont this with a 6210 and dlr-3p cable yourself, or has anyone else who can let me know what they did?
    thanks, Stu
    Feb 2004
    Germany
    I can't tell wether the "Taiwan-Cable" I have used was a "DLR-3P" type or something else.
    But I think it does not really matter as you are saying your cable works with "HyperTerm".
    Do you have a DB9 "Breakout-Box" handy?
    If so:
    connect your DLR-3P cable to your PC across "Breakout-Box"
    and find out which pins are really needed by checking communication with "Hyperterm"
    Once you have identified the Pins check the Voltage Level at the "Supply" pins (DTR and/or RTS) it is most likely something between +10 an +12 V.
    Connect RX, TX and GND to your PIC
    and supply the identified "supply"-pins with the correct voltage.
    Assuming your PIC-code is ok, It should work.
    If it doesn't work, try to communicate with your PIC using "Hyperterm"
    and debug the PIC code.
    Questions:
    What type of PIC are ypu using?
    Are you using the HW USART and HSERIN/HSEROUT?
    Do you have a "MAX232" type of level shifter connected to the PIC?
    What is the PICs clock speed?
    (9600 Baud won't work with a 4MHz clock.)
    regards
    Ralph
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  4. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  5. Pic to GSM Phone connection
    By samertop in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 13:40
