Hi I have had the same problem, mobiles are sometimes to fast
I use the GSM engine TC 35 from siemens they can run Normaly text but run to fast for a pic too.
so put in a larger crystal (8mhz)
set up your programmer to HS
if your settings is 9600 chose 2400 baud because at 8 MHZ it goes to faster
I use serin and a timeout seqenze so i can find the end of the message
If your modem can deal with slower speed auto matically
try to send some AT AT at a lower speed 1200 Baud
You won't fell the differnce since SMS messages are so short.
Best regards Mikkel Holm
I
