thermometer and humidity sms
Results 1 to 17 of 17
    Apr 2008
    Default thermometer and humidity sms
    Hello friends.Please could you help me.
    How can I send sms with sht11 and pic16f876.I want send sms alarm of
    temperature and humidity with nokia 6210.If under or on regulated alarm of the
    temperature or humidity ,nokia 6210 send sms me.
    How can I make this circuit and pic software.
    The sample with regulated alarm thermometer and humidity circuit is this on
    address.http://www.imageturk.com/goster.php?...42236baae1.JPG
    which mobil phone must I use.Can I use nokia 6210.
    Thank you for your helping.Best regards.
    Circuit explanation :
    The alarm is open,ISI(temperature) ALT(under) and ISI(temperature) UST(on)
    with NEM(humidity) ALT(under) and NEM(humidity) UST(on)
    between outside.Two between alarm is closed.
    Sample : If alarm 23 - 20 between,alarm is closed.If temperature 19 alarm open.
    http://dosyayukle.info/index.php?p=d...h=VpSY4G6mywpP
    Apr 2008
    Default another sampe circuit
    another sampe circuit :http://www.imageturk.com/goster.php?...1be2ef9e1e.JPG
    How can I use this software for my regulated alarm thermometer circuit.
    asm software here:http://dosyayukle.info/index.php?p=d...h=XXeuMX84TZtc
    Thank you your helping.
    Regards.
    Sep 2006
    Mexico
    Hello, the links doesn't work, use [code ] Link [/code ] (withous spaces) for any url
    Apr 2008
    Circuit asm code.
    http://dosyayukle.info/index.php?p=download&link=1242889961&name=pic16f876.asm
    http://dosyayukle.info/index.php?p=download&link=1219524014&name=pic16f876.asm
    Apr 2008
    circuit address.
    http://img.fotoambar.com/img/5/ee15decb5a78ee50f995fe149fe6a2e5.jpg
    Apr 2008
    Default sample
    http://www.imageturk.com/goster.php?res=b3dd66fdfd2f3749bdece.JPG
    asm software here:
    http://dosyayukle.info/index.php?p=download&link=1305062103&name=pic16f876.asm
    Apr 2008
    I maked this circuit,but complate not run.
    http://www.wrankl.de/SMST4PIC/SMST4PIC.html
    here asm and hex code:
    http://www.wrankl.de/SMST4PIC/V6/SMST4PICV6B47.zip
    Apr 2008
    Default sms
    How can I unite this sample software
    http://dosyayukle.info/index.php?p=download&hash=rzskbVI8qQey
    with my software.Thank you.
    '**************** SMS SEND SAMPLE ********************
    SmsMesajTx : SerOut2 modem_tx,modem_baud,["AT+CMGF=1",13] ' Mesaj Formatı TXT için
    Pause Bek100
    SerOut2 modem_tx,modem_baud,["AT+CMGS=",34,"90532XXXXXXX",34,",145",13]
    SerIn2 modem_rx,modem_baud,5000,msghata2,[wait(">")]
    Pause Bek500
    SmsData = "A" ' Gidecek Mesaj
    For addr= 0 TO 159
    SerOut2 modem_tx,modem_baud,[SmsData]
    Next addr
    Pause Bek500
    SerOut2 modem_tx,modem_baud,[26] ' CTRL+Z
    SerIn2 modem_rx,modem_baud,35000,msghata2,[wait("+CMGS")]
    msghata2: SerOut2 modem_tx,modem_baud,["ATH",13]
    Pause Bek500
    Apr 2008
    Default unite
    How can I unite this sample software TERMONEMALRM-1.zip with my software.
    Thank you.Best regards.
    Pause Bek100
    Pause Bek500
    For addr= 0 TO 159
    Next addr
    Pause Bek500
    Pause Bek500
    Apr 2008
    circuit is here.
    Hi! I would suggest to select the Mobile terminal device of your choice first and study the specs and AT commands that accompany it. Most of the AT commands are common but each terminal might have its own special ones.
    Also I would strongly recommend to use the UART module of the PIC's and also use bidirectional communication to check that the device has replied with OK after succesful command.
    For example:
    send AT+cr+lf
    device replies OK+cr+lf
    After you establish a good command of the device you are going to use then trie to send SMS. It is a difficult task for the begginer.
    Apr 2008
    Default sms
    Do yuo know sample temparature and humidity sms send circuit.
    Could you write sample address.
    I know this address: http://www.wrankl.de/SMST4PIC/SMST4PIC.html
    I maked this circuit,but complate not run.Don't sms.
    Thank you.Regards.
    Hi! Please read my post again. What you are trying to do is a complicated project. Not for the novice. If you insist on doing it, then do it with small steps, one task at a time.
    1. Select your mobile device. READ CAREFULLY the Data Sheet and get acquainted with it.
    2. Use only the USART of your PIC (you need of course level translation like a MAX232).
    3. Try to communicate with your mobile device with simple commands like AT and wait for the answer OK.
    4. Then try more complicated tasks like sending SMS.
    Also note that some commands like deleting SMS might take some time until they respond with OK. Not all commands execute immediatly!
    skimask's Avatar
    skimask Guest
    I'm probably guessing here, but....
    Step 1.1 - Make blinky LED
    It is a good idea if he has not blink a LED up to this moment, but I did not meant so small steps!
    On the other hand, a good schematic, a BOM and the full program, debuged, is most welcome.
    skimask's Avatar
    skimask Guest
    Ok, how about this:
    Step 1.5 - make blinky LED?
    Look at all the posts... He's all about 'sample software' and 'sample schematics'. Sounds to me like it's all about 'samples' and not designing and creating.
    OK, then: http://www.samples.com/
  1. sms send sht11 pic16f876 nokia 6210
    By elektoro2009 in forum GSM
    Last Post: - 9th June 2008, 08:57
