How to calculate CRC16 checksum for iButton
Results 1 to 14 of 14
    Default How to calculate CRC16 checksum for iButton
    I have made small iButton project. I want to calculate CRC-16 checksum in which polynomial is x^16 + x^15 + x^2 + 1. If I use 'writePagePacket' function for writing data on iButton then it gets automatically calculated, how will I get CRC checksum using 'write' function only?
    Default Crc16
    Hi there
    I am mot famiriar with the ibutton you work on but here are my code i use in a modbus protocol to calculate CRC16 cheksums
    Calcul_CRC16:
    CRC16=$FFFF
    For i=0 to (DataAmount -3)
    CRC16=CRC16^DATACRC[i]
    For j=1 to 8
    IF CRC16.Bit0=1 Then
    CRC16=$A001^(CRC16>>1)
    Else
    CRC16=CRC16>>1
    EndIF
    Next j
    Next i
    hope it helps
    And if you change the
    For j=1 to 8
    to
    For j=0 to 7
    you will gain and a few memory bytes!
    i am not sure only one way to find out try and try again
    Dallas CRC16 Routines (Tom Estes)
    https://www.picbasic.co.uk/forum/showthread.php?t=1745
    I haven't used the CRC16 routines, but Tom's CRC8 worked great on a project of mine.
    <br>
    Default Calculation of CRC 16 checksum
    Thanks for replying me.
    I tried the given code, but I am not able to write it in C#.Net. As I don't know the varaible type of CRC16. Can you please explain me?
  1. Checksum
    Last Post: - 24th October 2009, 04:09
  2. Calculate Byte Value Checksum in PBP Pro
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 8th July 2009, 22:50
  3. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 15:29
  4. Checksum problem!
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:21
  5. Checksum / CRC8 / CRC16
    By treitmey in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 14:40
