How to calculate CRC16 checksum for iButton
Results 1 to 14 of 14
    Default Calculation of CRC 16 checksum
    Thanks for replying me.
    I tried the given code, but I am not able to write it in C#.Net. As I don't know the varaible type of CRC16. Can you please explain me?
    Feb 2008
    Dear Andre
    i need the sample code for implementing modbus slave on a PIC16F877A
    please help me
    here is the code i used on a 16f627
    Hope it helps
    Feb 2008
    Dear Andre
    thank you for the code you have posted,actually i am trying to use the PIC16F877A
    another thing i have copy and pasted your code to proton+ compiler and i got some error messages one of them was
    for this part of the code:
    IF CRC16.Bit0=1 Then '<------ error here is saying Invalid Cast for this type of variable
    CRC16=$A001^(CRC16>>1)
    Else
    CRC16=CRC16>>1
    EndIF
    i don't know what does that means,please help me.
    Best Regards
    First of all this is PBP forum list not Proton.
    Second, as this is PBP, all examples are for this compiler. The syntax is a little different.
    The syntax of the line IF CRC16.Bit0=1 Then means: Set bit 0 of the word variable CRC16.
    You have to open your manual and find how this can be accomplished in your Compiler.
    Feb 2008
    Daer Andre
    can you please post the circuit schematic for such code?
    i want to know what is the use for the
    PORTB.4 = 1
    PORTB.5 = 0
    any clue?
    best regards
    Have you read the document emplementing modbus on serial comms,
    You can get it at www.modbus.org
  1. Checksum
    Last Post: - 24th October 2009, 04:09
  2. Calculate Byte Value Checksum in PBP Pro
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 8th July 2009, 22:50
  3. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 15:29
  4. Checksum problem!
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:21
  5. Checksum / CRC8 / CRC16
    By treitmey in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 14:40
