variables and gosubs???
Results 1 to 39 of 39
    Oct 2006
    Default variables and gosubs???
    Hi guys,
    i've never used varibles in pbp before, so im trying to do 2 things here:
    what i want to do is this:
    i = 0
    while(i < 10){
    Variable = i
    gosub ("subName" + Variable)
    i = i  +1
    subName1:
    subName2:
    subName3:
    subName4:
    its a bit of a mix of picbasic, and php, but im sure someone will get what im trying to do
    Is it possible?
    Thanks very much.
    Hi guest_05,
    You can use the BRANCH or BRANCHL command for that.
    Something like this...
    i        VAR BYTE
    Variable VAR BYTE
        i = 0
        while(i < 5)
            Variable = i
            gosub SubSwitcher
            i = i  +1
        wend
    SubSwitcher:
        BRANCHL  variable,[subName0, subName1, subName2, subName3, subName4]
    subName0:
    subName1:
    subName2:
    subName3:
    subName4:
    Jan 2006
    Istanbul
    DT, you are my teacher and I learn a lot from you here. With all my respect to you, please allow me to make a point;
    BRANCHL will cause the program to jump. Thus, "return" with a "subroutine" will not work.
    I made my point as below.
    i   VAR BYTE
        FOR i = 0 to 4
            BRANCHL  i,[subName0, subName1, subName2, subName3, subName4]
            Sayzers_Point:  'continue from where we were.
        NEXT i
    GOTO main
    subName0:
    GOTO Sayzers_Point
    subName1:
    GOTO Sayzers_Point
    subName2:
    GOTO Sayzers_Point
    subName3:
    GOTO Sayzers_Point
    subName4:
    goto Sayzers_Point
    or another example could be as below.
    i   VAR BYTE
        FOR i = 0 to 4
            SELECT CASE i
               CASE 0
                    'do something
               CASE 1
                    'do something else
               CASE 2
                    'do something more
               CASE 3
                    'do something interesting
               CASE 4
                    'do something bro
             END SELECT
        NEXT i
    GOTO main
    Nope..it will perfectly work dude and what Darrel did it's really clever.
    When you'll meet the Return, it will automatically RETURN at the main... but not at SubSwitcher.
    It's a kind of On YourVar Gosub.
    Try it...
    That's why the GOSUB was placed inside the while loop.
    That gosub calls the SubSwitcher: which then redirects to the appropriate subroutine. Then the subroutine does the return.
    The return in the SubSwitcher: is only there in case the variable is larger than the number of available subroutines. Otherwise, it would run subName0 which would be in error.
    The subroutines don't return to the SubSwitcher, they return back to the while loop.
    HTH,
    How dare you reply exactly at the same time
    That seems to happen alot with us Steve.
    I should also note here, that Sayzer's examples will work just fine too.
    Just different ways to skin a dog.
    (sorry, I'm a cat person)
    <br>
    Jan 2006
    Istanbul
    Quote Originally Posted by Darrel Taylor
    If there is no typo here, did I misunderstand this statement then ?
    Mar 2005
    Iowa, USA
    Question
    I'm a little confused as well. I guess as a test, you can put a statement under the branch instruction to flash an LED or something to see what happens. The way I read it is it will return back to the while loop because there is nothing else in the SubSwitcher routine to execute after the branch statement, just another return back to the while loop.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
