variables and gosubs???
Results 1 to 39 of 39
    Ok guys, sit back, take a breath, give me a little while to come up with a better answer.
    All will be revealed. Or further confused. We'll see.
    I'll try something...
    StartPoint:
        Gosub Somewhere
    Label1:
        Pause 100
        Goto Start
    Somewhere:
        Pause 1
    Nothing hard here right? after the Return... you return to Label1 ... right?
    Now...
    StartPoint:
        Gosub Somewhere
    Label1:
        Pause 100
        Goto Start
    Somewhere:
        Goto SomewhereElse
        z: goto z
    SomewhereElse:
    Same thing happen here...
    This said...
    Start:
          for routines=0 to 3
    StartPoint:
              gosub subselect
    ReturnPoint:
              pause 200
              next
        goto start
    SubSelect:
              branchl routines, [Routine0, Routine1, Routine2, Routine3]
    Routine0:
    Where the Return of Routine0 leads you?... to ReturnPoint
    I know i'm a pretty bad teacher...
    Jan 2006
    Istanbul
    and I am a good student.
    I thought that once the program jumps, then it will forget where it was and will return to an unknown place. So that it will never be 100% precise.
    Gosub and Return are good friends...
    As long as you have a GOSUB... you can insert 2789423564875634275624365 432956345634564326586324957243657 234596243652 43656243756243654 356437856 46582436587243657 26435726435 2436 (+/- 1) goto in-between. And when you'll use Return, it will return just under the GOSUB.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by sayzer
    To be even more specific, the GOSUB will put a return address on the top of the "Stack" It will remain there forever (as long as the PIC is not reset) until a RETURN is executed. So, Steve's 2.7894235e+128 GOTOs do nothing to modify the address on the top of the stack. And, no matter when the RETURN is executed, the program will return to that address.
    HTH,
    Steve B
    Default That's a better explanation indeed !!!
    SteveB....SteveB....SteveB....
    Whizzz... Woohoo...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1198&stc=1&d=116388100 4">
    So much for my fancy reply. Too slow.
    Got it Sayzer??
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Darrel Taylor
    Ahhhhhhh , I was really looking forward to it. My stab at it was just a down and dirty continuation of what Steve was getting at. We'll let Sayzer and Ryan weigh in on whether it worked for them.
    May 2006
    Del Rio, TX, USA
    Steve,
    ROFL, Great picture!
    Jan 2006
    Istanbul
    I have a new teacher now!
    Thanks for this simple and clear explanation SteveB.
    I was expecting DT to come up with really complex explanations. heheh
