mmm... not complex Sayzer, let's say detailled.
I was going more for ... Cool!
Well, since we don't need the explanation anymore, I'll leave it at this, since it's already done.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1199&stc=1&d=116388436 9">
Cool indeed!!! You're going to have to share with us your posting techniques!
Wisdom is knowing what path to take next... Integrity is taking it.
Ryan Miller
Thanks guys,
Piece of cake (with the right software).Originally Posted by rhino
Alt-Print Screen (windows XP, screen capture)
MS Paint to import and crop
Selteco Bannershop GIF animator. http://www.selteco.com/bannershop/
and about an hour creating 58 animation frames.
I'll have to try it again sometime.
Oh, Ta,
I see you added another question to post#13. Almost missed it.
and one more question, im trying to use this code to make a sort of clock.
i'm using the pins LOW to make the circuit, but i dont really want to use HIGH to stop the circuit, is there anway to just turn the pin off, like when the program is run at the start?
Thanks againEither of those will return the pin to High-Impedance state.Code:INPUT PORTB.0 ' --- OR --- TRISB.0 = 1
HTH,
Well, what d'ya know!? I Make a run for something to throw on the grill and the next thing I know, Darrel has raised the bar when in comes to posting code explainations!
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1202&d=1163898624">
Now that's what I was looking forward to!!!
Darrel not only came up with a quite elegent solution for the origianl problem in a matter of minutes, but then went over the top in showing how it works.
Way to Go!
Steve B
Very cool Darrel. I'm sure we're going to start seeing some interesting posts from now on. Thanks again, and keep raising the bar!
Ryan Miller
Holy Gif!
DT, I can't believe you made it within half an hour!
What can I say? It is just as you said it was.
rhino,
I now see that you were in a different page then I was.
But, you had your answer and I had mine.
Thanks to all.
I enjoyed watching posts coming in and out, too.
Especially this last post by DT!
Edit: I just realized that it has been two hrs....
Darrel...Darrel...Darrel...
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1198&d=1163881004">Darrel...Darrel...Darrel...
Woohoo..Whizz..ROCK AND ROLL!!!
