I just started using the pics and pbp 2.46. I programmed a pic12f683 using adcin to read the value of a couple of pots. I noticed that there is a time lag from the moment when I turn the pot and the response of the pic, which in this case is oscillating the pic with the SOUND command.
I'll turn the pot to adjust the frequency of the note, a new note will sound but only after a time lag. Is this just the nature of using adcin? I thought it was supposed to be very fast and accurate when compared to using the POT or RCTIME commands. Would these other commands be better for reading the value of a pot?
Also, I was wondering if you could use adcin with a different circuit other than a voltage divider circuit.
Thanks in adavance.
Tony
