Hi, I wrote a program and I was wandering if it is better to use the Pot command or the Adcin command ?
Also , I wrote this small program. I have two potentiometer, I connected them to the input pin and to the positive supply . Is this good ?
I get somewhat good result with one, but when i put two, the second pot stays at 255..
'TRANSMIT PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
' Define ADCIN parameters
ADCON1 = %11000001 ' Set PORTA analog and RIGHT justify result
ADCON0 = %00000001 ' Configure and turn on A/D Module
TRISB = 0
TRISA = 1
'27
temp var word : right var byte : left var Byte : oldright var byte : oldleft var byte
encoded1 var word
'Leftwheel =CW : Rightwheel= CW '---- $66 = 01 10 01 10
'Leftwheel =CW : Rightwheel= CCW '---- $56 = 01 01 01 10
'Leftwheel =CCW : Rightwheel= CW '---- $5a = 01 01 10 10
'Leftwheel =CCW : Rightwheel= CCW '---- $65 = 01 10 01 01
loop:
ADCON0.2 = 1 'Start Conversion
oldright = right 'Pot reading 1
oldleft = left 'Pot reading 2
ADCIN 0, right 'Read channel PORTA.0
pause 50
ADCIN 1, left 'Read channel PORTA.1
pause 50
right = (right +oldright)/2 'Reducing the fluctuating output by taking an average
left = (left +oldleft)/2
Lcdout $fe, 1 'Clear screen
Lcdout "Right: ", Dec right 'Display the decimal value
Lcdout $fe, $C0, "Left: ", DEC left 'Display the decimal value
goto loop
