High Resolution Timer & Speed Calculator
Results 1 to 5 of 5
Threaded View
    Jan 2010
    PHILADELPHIA, PA - USA
    Default High Resolution Timer & Speed Calculator
    This PBP project is a high precision timer and Speed Calculator.
    Its designed to be used with a 2 sensor optical gate, though it can accurately measure the time of any single pulse.
    It is mostly an experiment to carry as much precision as possible.
    But also a useful gadget in it's own right.
    It uses Darrel' Taylor's Instant Interrupts and N-Bit Math (64-Bits) throughout.
    The core program is based on an implementation of CCP1, TIMER-1 Interrupts that was originally developed by Bruce from Rentron.
    http://www.picbasic.co.uk/forum/show...01&postcount=3
    Here is the Start of the Code:
    '*********************[ High-Resolution Timer ]********************
    '**  Author  : Robert Wozniak,   Robert.Wozniak -at- gmail.com   **
    '**  Notice  : This code may be freely used and distributed      **
    '**            for use in non-commercial applications            **
    '**  Version : 6.10 : Feb 06, 2010                               **
    '**  Date    : JAN 14, 2010                                      **
    '**  Versions:                                                   **
    '**   6.0 : All 64 bit MATH, 99 min limit                        **
    '**   5.0 : Working Timer and Speed Calculator with 64 bit math  **
    '**   Hardware Tested: PIC18F4680 @20MHz                         **
    '**   4x16 Parallel LCD Module                                   **
    '**   PBP 2.60 / MPLAB IDE 8.40.000                              **
    '**   Compiled with: [-n -ampasmwin] Build Options               **
    '**   32 BIT LONG SIGNED INTEGER                                 **
    '** Thanks to Darrel & Bruce at MEL PB Forums for Code examples  **
    '**           Alexander for N-Bit Math...Excellent ASM code      **
    '**  MAX OVRFLO=457763, COUNTS=44041 for 99min:59.9999998sec     **
    '**  MIN OVRFLO=0, COUNTS=261 for 9999.999MPH                    **
    PRECISION CON 8 SYSTEM        ; Set 8 bytes = 64-bit Precision for N-Bit_Math.pbp
    INCLUDE "N-BIT_Math.pbp"    ; Include Alexander Avtanski's Multibyte Arithmetic
                    ; Assembly Library Wrapped for PBP by Darrel Taylor [Version:1.3 Beta (JAN 07,2010)]
                    ; Version:1.3 Beta (1/7/2010)
    INCLUDE "DT_INTS-18.bas"    ; Include Darrel Taylor's Base Interrupt System for PIC18F [Version:3.3 (MAR 24, 2008)]
    INCLUDE "ReEnterPBP-18.bas"   ; Include Darrel Taylor's PBP interrupts for PIC18F [Version:1.4 (MAR 24, 2008)]
    DEFINE OSC 20
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 57600     ' 38400 BAUD N-8-1, PORT C6
    DEFINE DEBUG_MODE 1     ' 1 = inverted, 0 = true
    DEFINE LCD_DREG PORTA       ' Set LCD Data port
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTA      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 3           ' Set LCD Enable bit
    DEFINE LCD_BITS 4           ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4          ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us (2000)
    DEFINE LCD_DATAUS 50        ' Set data delay time in us (50)
    TRISA=%00000000             ' SET to Output
    TRISC.2=1               ' SET to Input
    ADCON0=%11000000
    ADCON1=%00000111
    T1CON.7=1         ' Set Timer1 to 16 bit mode
    LED         VAR PORTD.1       ' Alias PORTD.0 to LED
    I       VAR BYTE
    J       VAR BYTE
    OVRFLO      VAR LONG        ' Timer1 Overflow total
    COUNTS      VAR WORD        ' Timer1 Counts after falling edge capture
    PRESET      VAR BYTE
    OVFLS32     VAR LONG
    COUNTS32      VAR LONG
    TSEC32        VAR LONG
    OVFLS64       VAR BYTE[PRECISION]
    OVFLS64M      VAR BYTE[PRECISION]
    COUNTS64      VAR BYTE[PRECISION]
    TSEC64        VAR BYTE[PRECISION]
    BITS16      VAR LONG
    BITS1664      VAR BYTE[PRECISION]
    TMIN64      VAR BYTE[PRECISION]
    TSECINT64     VAR BYTE[PRECISION]
    TSECDEC64     VAR BYTE[PRECISION]
    CONVSEC     VAR LONG
    CONVSEC64     VAR BYTE[PRECISION]
    AA32      VAR LONG
    AA64        VAR BYTE[PRECISION]
    BB32      VAR LONG
    BB64      VAR BYTE[PRECISION]
    CC32      VAR LONG
    CC64        VAR BYTE[PRECISION]
    TMIN        VAR LONG
    TSEC        VAR LONG
    TSECINT       VAR LONG
    TSECDEC       VAR LONG
    DISTINCH      VAR LONG
    DISTFT      VAR LONG
    DISTFT64    VAR BYTE[PRECISION]
    DISTFT64M   VAR BYTE[PRECISION]
    FPS32     VAR LONG
    FPS64         VAR BYTE[PRECISION]
    FPSINT      VAR LONG
    FPSINT64        VAR BYTE[PRECISION]
    FPSDEC      VAR LONG
    FPSDEC64      VAR BYTE[PRECISION]
    MPH64     VAR BYTE[PRECISION]
    MPHINT64    VAR BYTE[PRECISION]
    MPHDEC64    VAR BYTE[PRECISION]
    MPH32     VAR LONG
    MPHINT      VAR LONG
    MPHDEC      VAR LONG
    ' ****** Setup Variables with Initial Parameters and 64-BIT Constants
    I = 0
    J = 1
    PRESET = 3              '  ********** PER OVERFLOW LOOP TICS CORRECTION **********
    BITS16 = 65536 * 2          '  ********** COUNTS MAX * 200 NS PER TIC**********
    @  MOVE?LP  _BITS16, _BITS1664
    DISTINCH = 6000           ' ********** 6.000 inches  (MAX = 65.535 in) **********
    DISTFT = ((DISTINCH*10000)/12)
    @  MOVE?LP  _DISTFT, _DISTFT64      '  ********** CONVERT TO FEET **********
    AA32 = 1000000            '  ********** BUMP UP RESOLUTION
    @  MOVE?LP  _AA32, _AA64
    @  MATH_MUL  _DISTFT64, _AA64, _DISTFT64M '  ********** BUMP UP DISTANCE DIGITS
    CONVSEC = 600000000
    @  MOVE?LP  _CONVSEC, _CONVSEC64            '  ********** BUMP UP TIME DIGITS
    Pause 500
    LCDOUT $FE,1
    LCDOUT $FE,$80,"HIGH-RESOLUTION "
    LCDOUT $FE,$C0,"     TIMER      "
    LCDOUT $FE,$90,"  Version 6.10  "
    LCDOUT $FE,$D0," Robert Wozniak "
    DEBUG 10,13,10,13,10,13
    DEBUG "HIGH-RESOLUTION ",10,13
    DEBUG "     TIMER      ",10,13
    DEBUG "  Version 6.10  ",10,13
    DEBUG " Robert Wozniak ",10,13,10,13,10,13
    For I = 1 to 5
    HIGH LED        ' Turn ON LED connected to PORTD.1
    Pause 50
    LOW LED
    PAUSE 50    ' Turn OFF LED connected to PORTD.1
    NEXT I
    I = 0
    ;----[High Priority Interrupts (DT_INTS_18)]----------------------------------------
    INT_LIST  macro    ; IntSource,   Label,   Type, ResetFlag?
      INT_Handler   CCP1_INT,  _Capture,  PBP,  yes
      INT_Handler   TMR1_INT,  _Timer1,   PBP,  yes
        INT_CREATE               ; Creates the High Priority interrupt processor
    CCP1CON = %00000101     ' Capture mode, capture on rising edge
    T1CON = 0               ' TMR1 prescale=1, clock=Fosc/4, TMR1=off (200nS per count @20MHz)
    @    INT_ENABLE  CCP1_INT    ; enable Capture interrupts
    to be concluded in next post due to length limitations.
    The timer has a 200 nS resolution and can go for 99Minutes: 99.9999999Seconds.
    Here is the Schematic of the setup
    The Full Resolution PDF file is here:
    http://www.picbasic.co.uk/forum/atta...1&d=1265519692
    Here is an photo of the actual Circuit:
    This timer was developed to use an input pulse from the 2-Beam Pulse Generator Circuit which I presented here:http://www.picbasic.co.uk/forum/showthread.php?t=12614
    While this code looks like an abomination, it's actually pretty cool that all the math is done with 64 bit precision.
    I'm pretty new at all this, so I'd really like to hear your comments or criticism.
    This is a work in progress. I have several features I'm still planning to include.
    I'll follow up with a post with some comments and limitations.
    Many thanks to Darrel, Bruce and Alexander for their excellent Code examples.
    Wozzy-2010
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 16:23
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
