Simple RF remote control code
Results 1 to 14 of 14
    Default Simple RF remote control code
    This is a simple example showing how to work with el-cheapo type RF modules using PBP SEROUT2/SERIN2, and showing how to break-out of a SERIN2 line, with interrupts, for a remote control decoder that operates in momentary mode.
    The interrupt resets the decoder output pins if no data is received on time, or the encoder button is released.
    It's really simple stuff, but rock-solid, and shows how easy it is to use simple PBP serial commands with RF applications.
    Note: Please don't ask how to change this for a different PIC type without first reading its data sheet, and learning how to setup different onboard peripherals. It should work pretty much the same with any PIC type if you just do a little research first...;o)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    erwin.zeez's Avatar
    erwin.zeez Guest
    well nice find
    thanks for sharing this
    Jul 2010
    Default Question over change PIC
    Hi Bruce , thanks you by sharing I have question , I start in PIC No more than two months into this , is possible change PIC by PIC16F628A is only by availability in local trade I live in CHILE - South America . Thanks you Regards..
    Jul 2010
    Quote Originally Posted by kaos40 View Post
    Sorry, do not read well in English, I just saw the PIC information exchange, I read the information 16F628A Thanks for sharing.
    Jan 2012
    Default Re: Simple RF remote control code
    Hi bruce,
    thanks for the code, but as I tried to compile it, I downloaded a trial version PBP I encountered problems "errors!".
    I realised the code is Picbasic not Picbasicpro. I looked for Picbasic compiler here but I get the information:
    Product 'PBC' is not available at this time!
    I found the Proton Amicus18, no chance! The Pic12f635 is not included!
    I looked again for another I found the Lite version but it seems to support Pic16f628 or so!
    Can you help by providing me with the Hex data for the Encoder and the decoder?
    Thanks in advance.
    PBP v3 is available here:
    http://melabs.com/
    Bruce hasn't been here since 29th November 2012 06:54.
    Jan 2012
    Thanks again for the reply Robert.
    I think that Bruce's code is a prototype not tested!???
    I haven't undertaken any changes I supposed the code works alright and I wanted to test it at the outset, I thought I would take it as is if it is OK.
    I have downloaded and ran the PBP3, the latest! I simply wanted to compile Bruce's code into Hex data.
    I supposed opening the code after saving it in a file, select the right device namely pic12f635, and click on compile would work!
    I also learned from here that an A is missing in IOC
    http://www.picbasic.co.uk/forum/showthread.php?t=16819
    I corrected that but still compilation doesn't work.
    I get Illegal Opcode
    If I write it this way:
    @ __CONFIG _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _BOD_OFF & _PWRTE_ON & _FCMEN_OFF & _IESO_OFF & _WUREN_OFF
    It didn't work either
    I tried the code from there I mean here:
    after adding the A, I still get errors
    Finally
    It only worked once I delete the whole @ _config................... line!
    I have to find out how to edit it properly.
    Sep 2010
    Las Vegas, NV
    If you'll look in the PBP3 manual there's a fine example of how to write a config statement. This if for a different chip but you see the context of how it should be written.
    'Config for 16F877A
    __config _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    Enjoy.
    Are you using PM assembler?
    If yes, make sure to point to MPASM assembler in the Microcode assembler settings.
    It was most likely in the Microcode Studio download or get it here:
    http://www.microchip.com/stellent/id...&part=SW007002
    Jan 2012
    Thanks Robert! I did download it as I'm looking for solutions in Assembly, C and Basic both Microchip Pic and Atmel AVR.
    I haven't programmed in PICbasic for some years. But now I capture the familiarity.
    Again thank you very much.
    Jan 2012
    Quote Originally Posted by AvionicsMaster1 View Post
    'Config for 16F877A
    Enjoy.
    Thanks a lot AvionicsMaster1, I downloaded it and I was busy skimming through things from the beginning like how to enable pull ups etc. because some of my own codes I wrote back in 2008 haven't worked. So I spent the night looking for the new changes in the manual and I had a look on some examples. But thanks to you, you cut the way through for me with the config thing. Now I'm on the right track.
  1. DTMF and PIC for Remote Control
    By doggitz in forum mel PIC BASIC Pro
    Last Post: - 30th March 2010, 11:42
  2. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  3. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 13:55
  4. Remote Control World !
    By iugmoh in forum General
    Last Post: - 22nd April 2008, 23:03
  5. Port control code Yelp!!
    By andyf in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 22:36
