Picbasic Pro compiler 2.60 error
Results 1 to 11 of 11
    Feb 2009
    Southern California
    Default Picbasic Pro compiler 2.60 error
    I recently loaded a program that I had compiled with v 2.47 with no problems, when I tried compiling with 2.60 I get a "fatal: out of memory (pbpw.exe)", this is after microcode studio reports it is not responding. When I switch back to 2.47 all compiles fine.
    Here is the line that causes the problem
    in_stream   var byte[20]
        write 1, (in_stream[0] - " ")
    as a side note when I changed the "-" to "+" I do get other compiler errors about mismatched array delimeters (]
    I am fairly confident the code worked as expected originally. I can fix the problem with a temp variable then "write 1, temp", but wanted to see if this is a real error with the compiler or am I just not understanding what I'm doing
    David
    Perth, Australia
    does it still give you errors if you change it to this?
    WRITE 1,(in_stream[0]-32)
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Just remove the outer parenthesis and it should work.
    Make sure you have another WRITE somewhere in your program that writes a BYTE without any formulas.
    It doesn't have to actually execute, but it needs to be somewhere in the program.
    <br>
    Feb 2009
    Southern California
    Smile
    Thanks for the replies.
    yes it does
    DTs two comments were both required to get it working.
    Do you know is this considered and error that will be fixed in future releases? It seems like you should be able to have any number of parenthesis (within reason) as it previously did in 2.47 and the extra write statement seems like a clever patch, but definitely you should never have to write code that won't be used to make other code work. It is good to know how to solve the problem. Hopefully this thread will help someone else, though I am pretty sure I have read your write one byte comment in a previous thread a long time ago and just forgot all about it until you restated it. As always thanks for the help.
    David
    They are known issues with PBP 2.60.
    The EEPROM commands were modified considerably to allow WORDs and LONGs.
    A couple errors crept in, and they are supposed to be fixed in the next patch.
    Keep an eye on this page ...
    Known issues in PICBASIC PRO Compiler 2.60
    http://melabs.com/support/pbpissues.htm
    <br>
    Hi, Darrel
    I catch the thread in flight ...
    As you have somewhat modified the PbP files ( DT Goodies i.e. ...) there should be a little problem with patches ( ??? corrected wayyyyy before the patch comes, I suppose ....) and upgrades ...
    For us ... patch refuses to apply if files have been modified, so we get a brand new full installation !!!
    How do you proceed not to loose or forget the mods each time a new upgrade comes ???
    ehhmmm,... make notes in a notepad maybe???
    Yeah this is an issue that bothers me too. I got 2.50 but never replaced my old installation just because I am lazy to find which files I modified...
  1. Experimenting with the PicBasic Pro Compiler
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 17th May 2016, 19:17
  2. Replies: 7
    Last Post: - 17th May 2016, 19:03
  3. Replies: 3
    Last Post: - 20th December 2009, 12:57
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  5. Replies: 3
    Last Post: - 1st July 2008, 21:07
