Picbasic Pro compiler 2.60 error
Results 1 to 11 of 11
    Talking
    ehhmmm,... make notes in a notepad maybe???
    Hi, Ioannis
    May we suppose it's new year Humour ...
    ROFL
    Alain, we need it don't we?
    If you think any way of mking updates less painful, do tell us.
    When Darrel wakes I am sure he would give an idea on this.
    After all I bet he has the most modified PBP directory!
    Feb 2009
    Southern California
    Maybe instead of using the word "patch" I should have said "band-aid solution"
    the patch I was referring to would be in my files, not the compiler files. ie a
    write 0,0
    at the end of the program that never gets called.
    David
    Quote Originally Posted by Acetronics
    For us ... patch refuses to apply if files have been modified, so we get a brand new full installation !!!
    Oh hello, I'm awake now. 10PM
    Actually, for each patch or version level, I create another whole installation from the CD, then apply the patch.
    That way I can test for people's problems related to the specific version/patches.
    Talk about a mess ...
    I've got 9 PBP folders. Each one with different levels of modification.
    I'm constantly commenting out config lines in .inc files.
    I guess, for anyone that only wants one installation, the procedure is the same. (Patch a clean installation)
    Just delete the old installation when you're finished. NOT
    But some day ... you'll want something that was in that folder.
    Some day will be 3-days after you delete it.
    How do you proceed not to loose or forget the mods each time a new upgrade comes ???
    I don't. I figure it out again when something doesn't work.
    Cause it may be for a different reason now.
  1. Experimenting with the PicBasic Pro Compiler
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 17th May 2016, 20:17
  2. Replies: 7
    Last Post: - 17th May 2016, 20:03
  3. Replies: 3
    Last Post: - 20th December 2009, 13:57
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  5. Replies: 3
    Last Post: - 1st July 2008, 22:07
