Voltmeter : 12F675 & Nokia 3310 display
Results 1 to 12 of 12
    Dec 2008
    Ploiesti, ROMANIA
    Default Voltmeter : 12F675 & Nokia 3310 display
    Hi to all !
    I intend to build one milivoltmeter, using 12F675 & N3310 display.
    I made this schematic and I wrote this code. But, once again !, I see nothing on display. Suggestions ?
    Thanks in advance for every reply !
    May 2008
    Italy
    I strongly hope you have powered your pic with 3.3 V and not with 5 V.
    If you did, than there is a high possibility that the display is burned.
    If you powered pic correctly then add to your circuit 2 pullup resistors (4.7 K)
    from +3.3 to SDA and from +3.3 to SCL.
    Add DEFINE I2C_HOLD 1 to your code.
    Al.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply ! I powered PIC with 5V and display with 3V. I made the modiffications You sugest. Still nothing on display...
    Dec 2008
    Ploiesti, ROMANIA
    Working schematic and code. New suggestions are welcome !
    Mar 2005
    CROATIA
    why you don't write lcd test code first.... to see if lcd is working and to be shure connection and subrutines are ok. then when working, put in whole code....
    I never used this type of pic, so i'm not shure for trisio i allwais used biger pic which ave trisa trisb and so, is your trisio keword correct ? another thing is; submit your code in visible format, many readers of forum have no time, to download looking and comment code when is not visible directly from site....
    sorry for my horible english, i hope is at least funny :-)
    Dec 2008
    Ploiesti, ROMANIA
    My variant of voltmeter, for max. 50 Volts. Limit of text is 10000 characters. My code have 10570 characters. Open and read. All the best !
    Mar 2005
    CROATIA
    vedo che qua si puo proseguire anche in italiano :-), per me e stesso non scrivo benne ne italiano ne iglesse... siete italiani no ?
    Dec 2008
    Ploiesti, ROMANIA
    Better variant. Some minor modification. Enjoy !
    Sep 2008
    Stockholm
    Damn I *HATE* 12F with their different names on everything..
    Have been trying to convert this code into some useful PIC, like 16F887 but with no success.. I realize that I fumbeling around in the darkness here.. but..
    Crap, cannot post all the code in code-tags neither :P
    link: http://www.repulsiv.se/pic/nokv10.bas
    Connections are changed like you can see in the sourcecode:
    D_C PORTB.0
    SDIN PORTA.3
    SCK PORTA.2
    (Choosen to match the connection that I already had for a nokia LCD on another testrig)
    Any thoughts of what I missed ? ..as I said, I already know I'm fumbeling in the dark
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Default Re: Voltmeter : 12F675 & Nokia 3310 display
    Hola, antes que nada, gracias por el ejemplo, ya que se puede usar como base y o libreria para otros proyectos... Anoche me puse largo y tendido entender el programa y ver el error...
    Tengo en mente hacer una mini fuente de poder (tipo variable por medio de PWM en segundo plano) y emplear el display para ver tension y corriente... ya tengo algo a medio camino, ahora me falta hacer el filtro y ver como hago el calculo para que segun la lectura de una entrada analoica, me genere una salida de 0 a 5Vcc...
    Bueno, para no irme del tema. para modificar tu programa y que funcione, configura 1ero los puertos de esta manera:
    D_C var PORTB.0
    RST VAR PORTB.1
    SCK var PORTB.2
    SDIN var PORTB.3
    SCE VAR PORTB.4
    luego, en la seccion de control del display nokia3310, coloca esta seccion (corregi reset y sce):
    InicializaLCD:
        D_C=1          ' Seleccionamos el registro de datos en RAM
        SCE=1         ' Anulamos la seleccion del chip
        pause 100         ' Hacemos una pausa de 100 ms
        gosub Reset_LCD   ' Reseteamos el LCD
    Reset_LCD:
        RST=0   ' Damos un pulso de reset durante 100 ms
        RST=1
        SCE=0
    CursorHome:
                      SCK = 1
                    LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:
                   offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
    PrintDataLcd:
                        for x = 1 to 8
                        SDIN = LcdReg.7
                        SCK = 1
                        LcdReg = LcdReg << 1
                        SCK = 0
                    next x
                    D_C = 1
    LCD_Clear:
                    PosX=0:PosY=0:Gosub LCD_GotoXY
                    D_C = 1
                    FOR Chr=1 TO 252
                        LcdData=0:Gosub LCD_ByteOut
                    next Chr
    LCD_GotoXY:
                    D_C = 0
                    LcdData=%01000000 | PosY :Gosub LCD_ByteOut
                    LcdData=%10000000 | PosX :Gosub LCD_ByteOut
    LCD_ByteOut:
                    SHIFTOUT SDIN,SCK,1,[LcdData]
    Border_line:
    '~~~~~~~~~~~~~~~~~  RAND 0
                    LcdReg  =  %10000000            ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor  Y
                    call    PrintCtrlLcd
        for y = 0 to 83
        LOokup y, [$FF,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,_         ' UP-side "DIGITAL"
                   $01,$01,$01,$F9,$F9,$F9,$09,$09,$F9,$F9,$F1,$01,_
                   $01,$F9,$F9,$F9,$01,$01,$F1,$F9,$F9,$09,$09,$19,_
                   $19,$11,$01,$01,$F9,$F9,$F9,$01,$09,$09,$09,$F9,$F9,$F9,_
                   $09,$09,$09,$01,$F1,$F9,$F9,$09,$09,$F9,$F9,$F1,$01,$01,_
    	         $F9,$F9,$F9,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,_
    	         $01,$01,$01,$01,$01,$FF] ,LcdReg
                   call    PrintDataLcd
        next y
    '~~~~~~~~~~~~~~~~~  RAND 1
                    call    PrintCtrlLcd
                    LcdReg  =  %01000001            ' cursor  Y
                    call    PrintCtrlLcd
        for y = 0 to 83
        LOokup y, [$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_         ' DOWN-side "DIGITAL"
                   $00,$00,$00,$1F,$1F,$1F,$10,$10,$1F,$1F,$0F,$00,$00,_
                   $1F,$1F,$1F,$00,$00,$0F,$1F,$1F,$10,$11,$1F,$1F,_
                   $0F,$00,$00,$1F,$1F,$1F,$00,$00,$00,$00,$1F,$1F,$1F,$00,_
    	         $00,$00,$00,$1F,$1F,$1F,$01,$01,$1F,$1F,$1F,$00,$00,$1F,$1F,_
    	         $1F,$10,$10,$10,$10,$00,$00,$00,$00,$00,$00,$00,_
    	         $00,$00,$00,$00,$00,$FF] ,LcdReg
                   call    PrintDataLcd
        next y
    '===================================  RAND 2
                    call    PrintCtrlLcd
                    LcdReg  =  %01000010            ' cursor  Y
                    call    PrintCtrlLcd
        LOokup 0, [$FF] , LcdReg
                    call    PrintDataLcd
                    LcdReg  =  %10000000 + 83       ' cursor  X
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
                    call    PrintDataLcd
    '===================================  RAND 3
                    call    PrintCtrlLcd
                    LcdReg  =  %01000011            ' cursor  Y
                    call    PrintCtrlLcd
                    call    PrintDataLcd
                    LcdReg  =  %10000000 + 48       ' cursor  X
                    call    PrintCtrlLcd
                   for y = 0 to 35
       LOokup y, [$18,$38,$60,$60,$38,$18,_								' "VOLT"
                  $00,$30,$78,$48,$78,$30,_
                $00,$78,$78,$40,$40,_
              $00,$08,$08,$78,$78,$08,$08,$00,_
                $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF] ,LcdReg
                    call    PrintDataLcd
                    next y
    '===================================  RAND 4
                    call    PrintCtrlLcd
                    LcdReg  =  %01000100            ' cursor  Y
                    call    PrintCtrlLcd
                    call    PrintDataLcd
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
                    call    PrintDataLcd
    '===================================  JOS
                    call    PrintCtrlLcd
                    LcdReg  =  %01000101            ' cursor  Y
                    call    PrintCtrlLcd
                    for y = 0 to 83
        LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
    	         $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
    		   $80,$80,$80,$80,$80,$80,$80,$80,$FF] ,LcdReg
                    call    PrintDataLcd
                    next y
    End             'of program
    Aug 2012
    respecto a la visualizacion de los caracteres, eso seria asi:
     LcdReg  =  %10100000 + 17          ' cursor  X
                   call    PrintCtrlLcd
                    LcdReg  =  %01000010 +40           ' cursor  Y
                    call    PrintCtrlLcd
    '~~~~~~~~~~~~~~~~~ now display results
                    Char = (VOLT dig 1)
                    call    PrintChar
                    Char = (VOLT dig 0)
                    call    PrintChar
                    Char = 12
                    call    PrintChar
                    Char = (MV dig 0)
                    call    PrintChar
                    ;Char = (MV dig 1)
                    ;call    PrintChar
                    Char = 14
                    call    PrintChar
    '~~~~~~~~~~~~~~~~~  cursor display amp
                    call    PrintCtrlLcd
                    LcdReg  =  %01000010 + 50           ' cursor  Y
                    call    PrintCtrlLcd
                     Char = (amper dig 1)
                     call    PrintChar
                     Char = (amper dig 0)
                     call    PrintChar
                     Char = 12
                     call    PrintChar
                     Char = (Ma dig 1)
                     call    PrintChar
                     Char = 13
                     call    PrintChar
    saludos
    Aug 2012
    Veamos si le gusta.... su voltimetro con un graficador de señal (no es un osciloscopio)
    Let's see if you like .... your voltmeter with a graphing signal (not a oscilloscope)
    no esta funcional el 100%, pero quizas entre todos le podramos dar un poco de forma... asi como esta, hasta 100Hz lee y grafica... Tambien faltaria corregir la lectura en caso de señales sinuidales (SEN-COS) asi no da falsas lecturas
    100% is not work, but perhaps among all We could give him a little way ... as well as this, to 100Hz graph ... also read and correct reading would fail if sinuidales signals (SEN-COS) so no giving false readings
    ;**************** ADC chanel setting  ************************
    DEFINE ADC_BITS 8
    ;******************* DEGISKENLER  ********************
    INTCON   = 0
    CMCON=7
    ADCON1 = 0
    ;ADCON1=%10000010
    TRISA=%00001111
    TRISB=%00000000
    TRISC=%00000000
    PORTA=0
    PORTB=0
    PORTC=0
    DEFINE LCD_DREG     PORTC
    DEFINE LCD_DBIT     4
    DEFINE LCD_EREG     PORTC
    DEFINE LCD_EBIT     1
    DEFINE LCD_RSREG    PORTC
    DEFINE LCD_RSBIT    0
    DEFINE LCD_LINES    2
    D_C      var     PORTB.0
    RST      VAR     PORTB.1
    SCK      var     PORTB.2
    SDIN     var     PORTB.3
    SCE      VAR     PORTB.4
    'Variables usadas por las rutinas del LCD
    ascii       var byte
    Grafico     var byte
    valor_a     VAR BYTE
    valor_b     var word
    LCD_f       var word
    Fuente      var byte
    Fuente1     var byte
    lcd_chr	    var	word
    numero      VAR WORD
    dato        var byte
    PosX        var byte
    PosY        var byte
    X           var BYTE
    Y           var byte
    i           var BYTE
    j           var BYTE
    k           var BYTE
    n           var byte
    f           var byte
    z           var BYTE    'No usar en otra parte, se usa en rutina "DibujaPunto"
    Invertido   var bit
    canal_a     var byte[70]
    canal_b     var byte[70]
    a var byte
    Offset          var  byte
    HAM var word
    HAM2 VAR WORD
    X1   VAR WORD
    DUTY VAR BYTE
     Char            var  byte
    VOLT    VAR  WORD
    HVD     var  word
    AMPER   var  word
    MV      VAR  BYTE
    MA      VAR BYTE
                        DATA @0,$3E,$51,$49,$45,$3E,_       ';// 0
                                $00,$42,$7F,$40,$00,_       ';// 1
                                $42,$61,$51,$49,$46,_       ';// 2
                                $21,$41,$45,$4B,$31,_       ';// 3
                                $18,$14,$12,$7F,$10,_       ';// 4
                                $27,$45,$45,$45,$39,_       ';// 5
                                $3C,$4A,$49,$49,$30,_       ';// 6
                                $01,$71,$09,$05,$03,_       ';// 7
                                $36,$49,$49,$49,$36,_       ';// 8
                                $06,$49,$49,$29,$1E,_       ';// 9
                                $08,$08,$3E,$08,$08,_       ';// +
                                $08,$08,$08,$08,$08,_       ';// -
                                $00,$60,$60,$00,$00,_       ';// .
                                $7E,$11,$11,$11,$7E,_       ';// A
                                $1F,$20,$40,$20,$1F,_       ';// V
                                $7F,$09,$09,$09,$01        ';// F
    Inicio:
        X=0
        Y=0
        Pause 100         ' Hacemos una pausa de 100 ms para estabilizar todo
        gosub InicializaLCD
        gosub ConfiguraLCD
        gosub borra_lcd
        gosub cursor_origen
    ciclo:
    LCDOUT $FE,1
        call  Border_line
        GOSUB  F_VOLT
        gosub Pantalla
        gosub muestreo
        gosub Pantalla
       ; GOSUB F_AMP
        ;pause 100
        gosub borra_lcd
        goto ciclo
    F_VOLT
    adcin 0 , valor_b
    mv=(5*valor_b)*/255
    volt=(5*valor_b)/255
    mv=mv*10/2
     LCDOUT $FE,$02,"VOLT =",DEC VOLT,",",DEC1 MV
          gosub N3310
    ;F_AMP:     ;HESAPA:
     ;      HVD=(HAM+1)*/250
      ;     AMPER=HVD/100
       ;    MA=HVD//100
        ;   RETURN
    N3310:
    '~~~~~~~~~~~~~~~~~ cursor display volt
                    lcd_chr  =  %10100000 + 17          ' cursor  X
                   call    lCD_cmd
                    lcd_chr  =  %01000010 +40           ' cursor  Y
                    call    lCD_cmd
                    char = (VOLT dig 1)
                    ;call lcd_data
                    call    PrintChar
                    char = (VOLT dig 0)
                    call    PrintChar
                    ;call lcd_data
                    char = 12
                    ;call lcd_data
                    call    PrintChar
                    char = (MV dig 0)
                    ;call lcd_data
                    call    PrintChar
                    ;Char = (MV dig 1)
                    ;call    PrintChar
                    char = 14
                    call    PrintChar
                    ;call lcd_data
    'Rutina para muestreo y almacenamiento de medición en RAM.
    Muestreo:
        for i = 0 to 69
            adcin 0, valor_a
            canal_a[i]= valor_a/8
            pause 20
        next i
    'Esta rutina muestra las dos señales en el LCD.
    Pantalla:
        x=0
        for i = 0 to 69
            y=canal_a[i] ;+5
            gosub Dibujapunto
            pause 1
            x = x+1
        next i
    'Esta rutina grafica un punto en la pantalla
    'siguiendo coordenadas X,Y (X:0-83; y:0-47).
    DibujaPunto:
         if Y<=7 then
            z=7-Y
            dato = %00000001 << z
            posy=5
        if Y>=8 AND Y<=15 then
            z=15-Y
            posy=4
        if Y>=16 AND Y<=23 then
            posy=3
            z=23-Y
        if Y>=24 and Y<=31 then
            posy=2
            z=31-Y
        if Y>=32 AND Y<=39 then
            posy=1
            z=39-Y
        if Y>=40 AND Y<=47 then
            posy=0
            z=47-Y
        PosX = X
        gosub cursor_xy
        lcd_chr = dato
        gosub lcd_data
    '                           RUTINAS GESTION LCD NOKIA 3310
    InicializaLCD:
        ;Pin_VCC=1            ' Damos alimentacion al LCD
    ConfiguraLCD:
        lcd_chr=%00100001 ' Chip Activo, Direccionamiento horizontal, uso de instrucciones extendidas
        gosub lCD_cmd
        lcd_chr=$B5       ' Configura el voltage de operacion del LCD (Contraste)
        gosub lCD_cmd
        lcd_chr=$13       ' Configura bias mux rate a 1:48
        gosub lCD_cmd
        lcd_chr=%00100000 ' Chip Activo, Direccionamiento horizontal,uso de instrucciones basicas
        gosub lCD_cmd
        gosub Segmentos_ON   ' Configura el display (Todos los segmentos ON)
        gosub Display_Normal ' Configura el display (modo Normal)
        gosub direccionamiento_vertical
    Display_Blanco:
        lcd_chr=%00001000 ' Display Blanco
        gosub lCD_cmd
    Display_Inverso:
        lcd_chr=%00001101 ' Display Inverso
        gosub lCD_cmd
    Display_Normal:
        lcd_chr=%00001100 ' Display Normal
        gosub lCD_cmd
    Segmentos_ON:
        lcd_chr=%00001001 ' Segmentos ON
        gosub lCD_cmd
    Direccionamiento_Vertical:
        lcd_chr=%00100010 ' Chip Activo, Direccionamiento Vertical,uso de instrucciones basicas
        gosub lCD_cmd
    Direccionamiento_Horizonal:
        lcd_chr=%00100000 ' Chip Activo, Direccionamiento Vertical,uso de instrucciones basicas
        gosub lCD_cmd
    Borra_LCD:
        gosub Cursor_Origen  ' Colocamos el cursor en el origen
        for LCD_f=0 to 503       ' Recorremos todas las posiciones del LCD colocando ceros
            lcd_chr=0
            gosub LCD_Data
        next LCD_f
    Cursor_Origen:
        lcd_chr=%01000000 ' Ponemos la direccion Y a 0 (01000yyy)
        gosub lCD_cmd
        lcd_chr=%10000000 ' Ponemos la direccion X a 0 (1xxxxxxx)
        gosub lCD_cmd
    Cursor_XY:
        lcd_chr=%10000000 | PosX
        Gosub lCD_cmd	  ' Envia Posicion X
        lcd_chr=%01000000 | PosY
        Gosub lCD_cmd	  ' Envia Posicion Y
    Reset_LCD:
        RST=1
    lCD_cmd:
        D_C=0    ' Seleccionamos el registro de comandos
        goto Data_Out
    LCD_Data:
        D_C=1   ' Seleccionamos el registro de datos de RAM
        if Invertido=1 then   ' Comprobamos si se invierte el dato para la representacion
            lcd_chr = lcd_chr ^ $FF
        goto Data_Out
    Data_Out:
        SCE=0   ' Seleccionamos el chip del LCD
        SCK=0  ' Ponemos a cero la señal de reloj
        shiftout SDIN,SCK,1,[lcd_chr\8] 'Enviamos los datos en modo SPI
        SCE=1   ' Deseleccionamos el chip para liberar el bus
    PrintChar:
                   ;dato = %00000001
                  offset = char * 5
                 for a = 1 to 5
                 ;lcd_chr=char
                read offset, lcd_chr
               call  LCD_Data
              offset = offset + 1
             next a
             lcd_chr=char
     ;lcd_chr = 0
          call    LCD_Data
     Border_line:
                    lcd_chr  =  %10000000            ' cursor  X
                    call    lCD_cmd
                    lcd_chr  =  %01000000            ' cursor  Y
                    call    lCD_cmd
        for y = 0 to 83
    	         $01,$01,$01,$01,$01,$FF] ,lcd_chr
                   call    LCD_Data
        next y
                    call    lCD_cmd
                    lcd_chr  =  %01000001            ' cursor  Y
                    call    lCD_cmd
        for y = 0 to 83
    	         $00,$00,$00,$00,$00,$FF] ,lcd_chr
                   call    LCD_Data
        next y
                    call    lCD_cmd
                    lcd_chr  =  %01000010            ' cursor  Y
                    call    lCD_cmd
        LOokup 0, [$FF] , lcd_chr
                    call    LCD_Data
                    lcd_chr  =  %10000000 + 83       ' cursor  X
                    call    lCD_cmd
                    call    lCD_cmd
                    call    LCD_Data
                    call    lCD_cmd
                    lcd_chr  =  %01000100            ' cursor  Y
                    call    lCD_cmd
                    call    LCD_Data
                    call    lCD_cmd
                    call    lCD_cmd
                    call    LCD_Data
                    call    lCD_cmd
                    lcd_chr  =  %01000101            ' cursor  Y
                    call    lCD_cmd
                    for y = 0 to 83
    		   $80,$80,$80,$80,$80,$80,$80,$80,$FF] ,lcd_chr
                    call    LCD_Data
                    next y
    se que se puede optimizar aun mas, pero estoy parado en ver como puedo solucionar el tema de las lecturas que no son lineales
    which I can be further optimized, but I stand to see how I solve the issue of non-linear readings
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 20:07
  2. Interfacing Nokia 3310 Lcd Using PIC16f877a
    By reianjim in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 13:54
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  5. nokia 3310 lcd!! (help)
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 12:20
